adigitalshot Samba Member
Joined: August 02, 2014 Posts: 4 Location: North Carolina
Posted: Wed Aug 27, 2014 1:37 pm Post subject: Green Light Staying On After The Car Is Off |
I've got a '73 beetle with a '66 beetle's engine. Just a few days ago we put in a new starter and it did good until now. Now the green light stays on after the car is off and it seems that it is draining the battery. Any suggestions? |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Wed Aug 27, 2014 2:51 pm Post subject: |
what green light? _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Wed Aug 27, 2014 3:08 pm Post subject: |
I'm going to guess you mean the Gen light in the speedo.
This usually indicates the VR had failed and is sending voltage backwards along the #61 wire. If you still have the original generator the VR will be below the rear seat. If you've upgraded to an alternator the problem is likely internal to the alternator.
Until you get it fixed you need to disconnect the battery while the engine is OFF or the Gen light will drain the battery. _________________ AshMan40
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Wed Aug 27, 2014 3:12 pm Post subject: |
Gen with a Volt Reg or Alt with an external or internal Reg.
Late yr car with a early engine can have different Elect charging systems.
Generally a light still on after a key is turned off means the Volt Reg points inside are sticking.
A light tap with a wooden handle should make the light go off.
Some times that will be the solution and not repeat itself then again a sign the Volt Reg needs to be replaced....kinda hard not knowing exactly what you have. Capeche? |
