PastDown Samba Member
Posted: Thu Aug 28, 2014 4:56 am Post subject: Barndoor front bean with adjuster |
Hi all,
Has any one fitted an adjuster to the standard BD beam? If so, did you use a normal bus or bug adjuster?
Any help would be grateful.
Thanks
Rob |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Thu Aug 28, 2014 7:12 am Post subject: |
You use a bus adjuster, though I would recommend constructing or purchasing a beam that uses later spindles(64-67). Beam tube spacing between tubes is the same. Save your original beam for restoration. Later spindles have better brakes and less expensive parts. The the higher price of parts to overhaul the OG bd brakes and kingpins just once will pay for a proper lowered beam using later components |
Ian 68 Samba Member
Joined: March 14, 2011 Posts: 176 Location: From Bristol UK now in Australia.
Posted: Thu Aug 28, 2014 10:51 pm Post subject: |
Ultramoron wrote: |
The whole issue of lowering the front end is something I'm very interested in.
Ive asked questions, done searches and got few points of view on how to go about it but I'd be interested to know where you maybe able to buy a beam ready to go in BD ...have you got any info or links please as that could help a lot of people I reckon.
Best
Ian |
kermie Samba Member
Joined: July 24, 2007 Posts: 39 Location: The Netherlands
Posted: Fri Aug 29, 2014 12:03 am Post subject: |
Have a chat with Erwin @ Volksprojects, I believe he ships worldwide.
Ian 68 Samba Member
Posted: Fri Aug 29, 2014 1:49 pm Post subject: |
Thank you. |
