Greg Knister Samba Member
Joined: July 30, 2011 Posts: 47 Location: Alberta Canada
Posted: Thu Aug 28, 2014 12:08 pm Post subject: repaint over old paint |
what is the process for doing this . Ruff old paint hit with primer,sand smooth. hit with primer again and paint.
Any help would be appreciated.
Thanks Greg |
Posted: Thu Aug 28, 2014 12:25 pm Post subject: |
What I need to know is what grit paper to use and how much I have to rough it up and what grit to do the primer sanding . I am using a single stage paint
Thanks Greg |
jspbtown Samba Member
Posted: Thu Aug 28, 2014 12:34 pm Post subject: |
Well alot depends on the quality of the surface. If the paint is intact and its just a re-shoot you can scuff (400-600 grit), shoot some sealer and spray away. |
Posted: Thu Aug 28, 2014 1:21 pm Post subject: |
Could I use primer as a sealer |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Thu Aug 28, 2014 2:53 pm Post subject: |
Shooting primer as sealer depends - check your primer and paint tech sheet.
What grit to prep sand depends - check your primer and paint tech sheets.
Rust repairs? Dent repairs? Chipped paint repairs? Bare metal? - These will all affect what type of primer(s) you will need. _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Tue Sep 02, 2014 5:20 pm Post subject: |
The quality of the old paint is important. If it is perfect and just sand with 400 to 600 grit is spot on. I would spray a sealer coat so you have good adhesion. For the new paint. |
