reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1927 Location: Bloomington, IN
Posted: Thu Aug 28, 2014 7:37 pm Post subject: Frozen Ball joint nuts |
Help! After finally getting the fuel system to work correctly, replacing all the fuel lines etc. I am trying to get the front end done and the nuts on the lower ball-joints are nut coming off. I have been putting PB blaster on the nuts for 2 days I stopped just short of stripping the bottom end that has allows you to hold it still while turning the nut. Since these things are unobtainium I need to have a good way to loosen these without causing damage. I do have access to a torch and freezing spray if that can be useful.
Thanks _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Fri Aug 29, 2014 7:09 am Post subject: |
Please...do not do either the freezing spray or heat. The main bearing and alignment feature inside of the ball joints.....just like tie rod ends....is a nylon cup. It has a cup with a flat spot on top for the spring to push against. I cant remember if it has a lower cup or if the ball rides on polished metal. I have one sectioned I can look at when I get home.
Either way extreme heat or cold below -60f can damage nylon. Extreme heat for nylon...is like 250F.
So...you can get new nuts. I would use either a nut splitter carefully....or use a dremel on one side only....just ro get some tension off of the nut. Then pb blaster....and whack the nut sharply on the side with a chisel while soqking.
jn future...always use anti-sieze. Ray |
Posted: Fri Aug 29, 2014 9:15 pm Post subject: |
I am getting a nut splitter this weekend. if that does not work, then i will use a dremel. thanks for the advice. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
