pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Fri Aug 29, 2014 9:43 am Post subject: Ticking noise from newly rebuilt 67 type 1 transmission |
I have a ticking noise coming from newly rebuilt 67 type 1 transmission. It is from a reputable builder. It shifts fine. Its tight in the gearing. I drove it 60 miles with no issues but this ticking noise. It only happens when the car is in gear and the clutch is depressed. It is quicker paced in 1st gear and slower paced in 4th gear. I have turned the engine off, and coasted with the same results, to eliminate the clutch components. The clutch was functioning fine before the swap. I used the 66 axles, however I used the 66 differential's, in hind sight, I'm not sure if that a good move. Re assembly of the axle's went smooth. I'm sure the fulcrum plates are in the correct position. I have jacked up the beetle and cannot duplicate the sound at all. Could it be the position of the axles? I'm really stumped. I want to find out why it is doing this, before I send it back to the builder. I have found this post
http://www.thesamba.com/vw/forum/viewtopic.php?t=522377&highlight=trans+ticking+noise
Edit: Just to add more information it does not tick when the car is sitting still and the clutch depressed and the engine is running. When I start to put it in gear the ticking starts before it's fully engaged in a gear
He has not responded to my pm
I really need the transmission experts on this one.
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4857 Location: sanger ca
Posted: Fri Aug 29, 2014 10:06 am Post subject: |
If it was axle related it would be faster in fourth gear. Some thing on the mainshaft assy, from the spinning clutch disk to the m/s bearing. How is the pilot bearing in the gland nut?
Also if the clutch is in, the bearing in the gland nut is spinning at a different rate than the engine, and is spinning faster in first than fourth. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Fri Aug 29, 2014 11:45 am Post subject: |
mcmscott wrote: |
Also if the clutch is in, the bearing in the gland nut is spinning at a different rate than the engine, and is spinning faster in first than fourth. |
I didn't touch the gland nut when I pulled the engine, it is older, and when the clutch is out the engine and tranny are turning at the same speed which equals no click. It is something I should look into. thanks
Edit: There is no noise when I'm sitting still, clutch depressed, engine running. Only when moving and the clutch is depressed. |
Posted: Fri Aug 29, 2014 11:59 am Post subject: Re: Ticking noise from newly rebuilt 67 type 1 transmission |
pwmcguire wrote: |
I really need the transmission experts on this one. |
Edit: Just to add more information it does not tick when the car is sitting still and the clutch depressed and the engine is running. When I start to put it in gear. while rolling, the ticking starts before it's fully engaged in a gear |
tkelley Samba Member
Joined: January 10, 2006 Posts: 1597 Location: Where Pterodactyls crash and burn...
Posted: Fri Aug 29, 2014 12:51 pm Post subject: |
The exact same thing happened to me...and I had contacted the re-builder
3 times trying different axles, fulcrums, etc....even tried their recommended gear oil that they sent free of charge.
After I had tried all this with the same result...I said screw it and just drove it. I ended up putting over 45k miles
on it with no issue, even drove it on a 2,300 mile road trip and had no issues, nor did the clicking get any worse/louder.
The car is still driving around with the same trans with still no issues...probably 75k on it by now.
Tom _________________ When the sun doesn't rise, we'll replace it
with an H-bomb explosion or a painted jail cell... |
Posted: Fri Aug 29, 2014 1:02 pm Post subject: |
tkelley wrote: |
Tom |
That's interesting to know, The noise is a bit annoying. The builder agreed to take it back and make me happy, if I ship it to him. I don't think he will know what to fix. and I know he has no other 67's to change out. I took mine to him. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Fri Aug 29, 2014 4:33 pm Post subject: |
What oil are you using? Synthetic may help. How loud is the noise? |
Posted: Fri Aug 29, 2014 6:01 pm Post subject: |
chrisflstf wrote: |
I dont remember what oil. I know It was gl4. It's hard to say how loud. like i said, It's enough to be annoying. Here is a video of the noise
Posted: Sat Aug 30, 2014 12:03 pm Post subject: |
Sounds like a bad bearing to me |
Posted: Sat Aug 30, 2014 1:59 pm Post subject: |
chrisflstf wrote: |
But I dont hear anything when I'm driving, of course the noise level goes up,
and I'm told you cannot hear it outside the car. |
Posted: Mon Sep 01, 2014 6:53 pm Post subject: |
Any one else want to take a stab? |
Motor60 Samba Member
Posted: Mon Sep 01, 2014 7:58 pm Post subject: |
Did you use gaskets when you installed the empi exhaust? Sounds like it's leaking. It's not your tranny |
jcmyers Samba Member
Joined: March 09, 2012 Posts: 184 Location: United States
Posted: Tue Sep 02, 2014 1:42 pm Post subject: |
Motor60 wrote: |
a friend of mine blew out a nice piece of exhaust gasket, taking my sandrail for a spin. he pulled up and I was like WTF did you do!
we pulled the head, looked over the pistons before we realized it was just an exhaust gasket
edit: although from that video, this doesn't sound like an exhaust leak or motor related at all to me. sounds like the joker playing card in the wheel spokes |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Tue Sep 02, 2014 4:40 pm Post subject: |
mcmscott wrote: |
yep, I think your gland nut has no bearing in it. |
morymob Samba Member
Posted: Thu Sep 04, 2014 4:15 am Post subject: |
I had one like this yrs ago, not a vw but possible. Ended being 1 tooth broken off on input shaft gear, hi gear only one quiet as this a direct conn thru trans. |
Posted: Sat Sep 06, 2014 6:40 pm Post subject: |
Motor60 wrote: |
leaking when the engine is off. Thats Brilliant |
SlightlyStock Samba Member
Joined: September 06, 2012 Posts: 4 Location: Orange, California
Posted: Sat Jul 25, 2015 12:02 pm Post subject: |
pwmcguire wrote: |
chrisflstf wrote: |
Hello Samba,
I have a freeway flyer 3 Rib in my own 1970 VW that recently developed a noise that sounds very similar to your ticking. I'm planning on taking look at my gland nut, but did this resolve your problem? Did you find any other information on regarding the cause? Any wisdom is very much appreciated |
