Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Tue Sep 02, 2014 2:53 am Post subject: |
I think the idea of the larger engine is to get specs to obtain the qualities you want. Of course a larger engine will have more friction and pumping losses than a smaller one -if they have the same standard parts. It's a crying shame performance parts aren't readily available for the 1300, as I love what manufacturers such as Audi and BMW have done with small engines. Imagine if we could get the chamber shape and compression we want with a 1300, or even experiment with roots and centrifugal blowers? _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
jeff68 Samba Member
Joined: November 02, 2007 Posts: 298 Location: Sarasota, Florida
Posted: Tue Sep 02, 2014 5:24 am Post subject: |
For more information on a "mileage motor"......If you have a subscription to HotVw's I think they will send you a link for a digital article on building a mileage engine. It is basically a compilation of what the magazine did when building theirs. They did tests on various products, carburetors, efi, Berg's jetavator, gearing, etc. Seemed like a good source of information to get ideas from at the very least. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Tue Sep 02, 2014 5:39 am Post subject: |
HVw did two Mileage motors one back in the 70' with 40 idf's ,, but the newer version did fuel injection,, Guess which was better????? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Tue Sep 02, 2014 6:14 am Post subject: |
Juanito84 wrote: |
Danwvw wrote: |
I like the Idea of the 1300! But I would do one of the following maybe.
74mm Stroke
88mm bore |
I like the idea of a 1300 too! But why jump from such a small engine to such a large one? I personally don't understand why some guys recommend a bigger engine for more fuel mileage. Just look at the specs on the different VW engine sizes. The smaller the engine the better the effciency. The only exception is when you compare an engine with a better AFR and timing curve like the Digifant engine with one that doesn't. Imagine what MPGs a 1200cc Digifant engine would get! If a 1300SP gets 28.5mpg and a 1600SP gets 26.1mpg then I'm betting your stroked and bored engine will get even less.
I don't think it's engine size as much as vehicle speed. The MPG specs VW lists was at top cruising speed. Which is much lower for the smaller engines. Considering the cars are the same other than the engines, to push the VW 65mph takes the same HP regardless of engine size or potential. Push the VW up to 75mph, and it's going to take more fuel. If you drove the larger engine VW's to pace the smaller engine cars at their slower speeds, i'd bet the MPG figures would be pretty similar.
Just as an example, my 2276 when N/A was able to get 39.98 MPG holding 70mph for an hour cruise. (all done with GPS to track mileage and speed). The car still ran low 12's at the track, it wasn't built for MPG's.
IMHO, it's more about the tune than engine size, and to some extent, engine combo. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Tue Sep 02, 2014 7:54 am Post subject: |
VW didn't test at full speed. My 1971 manual says right in it that the fuel mileage test was at 60mph, whereas the maximum speed is 81mph. Yes, the older ones were tested a bit slower, like 58mph in a 1966 model.
Like I said, the tune will give the most results. But mathmatically, a smaller engine has more potential for better fuel mileage.
If you were to do the math and draw a graph with the maximum possible efficiency from idle to full throttle at X amount of RPM you would see you start with 0% efficiency at idle, which slowly climbs to peak efficiency at full throttle. (Of course the lower the RPM, the better the efficiency too.) The only reason efficiency tends to drop off in the real world at full throttle is because of the need for enrichment. But still, more open is better. Both smaller engines and higher gearing will help keep that throttle open more, therefore increasing efficiency. It's all in the math.
I have done tests that span over 600 miles through mountains and on highways going 75mph and have gotten 48mpg total for the whole trip in a gasoline powered 1.6L Mazda with the only change to the tune being I advanced the timing. That's a lot better than 39.99mpg for an hour. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Danwvw Samba Member
Posted: Tue Sep 02, 2014 11:10 am Post subject: |
What I always liked was the in town millage of the 36 horse engines. Seems like I used to fill up about once a month and they were about 29 MPG around town. The 1300 could probably do the same, perhaps a 1300 with a little tiny Solex like the 28PICT-1 or FRD or Kadron-Solex or something, the W-100 cam would be a good performance cam for it but the scat C-20 or C-25 cam would probably be the right cam for MPG's.
Scat C-20 Cam .350" 234' @ .050"
Scat C-25 Cam .365" 234' @ .050"
W-100 Cam .420" 236' @ .050" _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Tue Sep 02, 2014 1:28 pm Post subject: |
Juanito84 wrote: |
We'll have to agree to disagree on this part. _________________ Eric Allred
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15279 Location: Deep in the 405
Posted: Tue Sep 02, 2014 3:42 pm Post subject: |
Back in the 70's you could safely drive 55-60 MPH anywhere in the country and enjoy life. There were many years back in the 70's when the National speed limit was 55 MPH and a 1300 had no problem keeping up. Today speeds are hitting 75-80 MPH. A 1300 can be dangerously slow and driving 60 MPH can flat out get you killed on many highways today. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Tue Sep 02, 2014 4:43 pm Post subject: |
Eaallred wrote: |
Juanito84 wrote: |
Danwvw wrote: |
74mm Stroke
88mm bore |
IMHO, it's more about the tune than engine size, and to some extent, engine combo. |
Man, I know I am a newb but I find that hard to believe.....
2276, 40mpg, and 70mph can't all go in the same sentence. Can it? That's incredible.
Madmike, which ONE WON? The HVw article is what got me thinking about the motor. I have it on my iPad and have been reading up on it. I would think the efi would have beat the carbs with better atomization.
On a side note:
Is that why peeps don't like the "step" on the later heads? I believe the step was supposed to provide a better quench area and better efficiency right?
I dunno, maybe I think too much-lol
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Tue Sep 02, 2014 4:52 pm Post subject: |
It's called closed-loop fuel injection. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
bdub475 Samba Member
Joined: April 05, 2009 Posts: 577 Location: Los Lunas, New Mexico
Posted: Tue Sep 02, 2014 5:16 pm Post subject: |
It's called building an engine with parts that work together and tuning it correctly. |
TURBOEDVW Samba Member
Posted: Tue Sep 02, 2014 8:51 pm Post subject: |
I know this is about building an efficient motor but there are plenty of other variables to consider when making a vehicle fuel efficient. Such as running thin oil such as 0w-20 and running narrow tires with plenty of air pressure. |
Posted: Tue Sep 02, 2014 9:00 pm Post subject: |
There is a whole lot more to good MPG then just the engine. Remove your roof rack and you will gain 2-3 MPG. Add a Harold Helper and you can gain another 1-2 MPG. Take all your junk out of the trunk and magically there is another 2 MPG. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Brian Samba Moderator
Posted: Tue Sep 02, 2014 9:01 pm Post subject: |
Isn't there a running thread about how to get max mpgs? It was something along the lines of; run stock everything, lower the car an inch and don't drive like you're from Californy _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Danwvw Samba Member
Posted: Tue Sep 02, 2014 9:18 pm Post subject: |
It should be possible to get 40 MPH on a big engine for example the New Beetle is 2.5 Liters and I think it will get 40 MPG under Ideal conditions. Probably more like 32 MPG Highway though on the New beetle as well as the old Beetle Milage Master.
When I was a Kid I was driving around a Studebaker 6 cylinder 170 CI or 2.8L, (OHV) Model with 112 HP 1962 model I think. It was tough to get it up to speed on the freeway before running out of ramp. Then I got a VW Beetle 1300 and It would zip right up to freeway speeds no problem. There is really hardly any difference in the performance of the stock 1966 1300 beetle and the stock 1971 1600! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
GTV Samba Member
Posted: Tue Sep 02, 2014 11:02 pm Post subject: |
vwracerdave wrote: |
The only thing that did for me was raise my oil temps. _________________ EMPI Power Rules! |
Posted: Tue Sep 02, 2014 11:25 pm Post subject: |
Danwvw wrote: |
under Ideal conditions. |
Variables man. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Tue Sep 02, 2014 11:29 pm Post subject: |
If you go with ACN you could build a super squishy piston engine, 94mm x 69mm (= hi compression; low heat) and get both, lots of power and great MPG, it would be a super efficient engine and if you wanted to you could have a bit of fun getting onto the freeway, if it worked out, I bet it would be something a vw magazine may be interested in…
IMO you would recoup the $650 pistons + Barrels investment with the better mpg if your really drove it as a DD for several years. _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
Posted: Wed Sep 03, 2014 4:31 am Post subject: |
Hey 67, I'll have to dig threw my HVW library But I thought it was the IDF's ,also remember we had REAL fuel back then ,not the cat piss they pass off as fuel now days:lol: _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Wed Sep 03, 2014 7:16 am Post subject: |
The last bus I had, with small nut reduction boxes got 31.11 mpg doing 65mph which was 4000 rpm.
So when someone says "small displacement", and "lower the rpms" to get good mileage, I do disagree. I've proven both wrong. _________________ Eric Allred
