Fitment help please
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
TX-73
TX-73 is offline
PostPosted: Sat Aug 30, 2014 10:19 am    Post subject: Fitment help please Reply with quote
I like these Sprint Stars but I'm not too sure about the fit with the advertised backspacing?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C32-SPR41-B
These are going on my stock height bug, stock brakes on the back and CBP disc brake setup on the front. No tires selected yet. I'm not sure if they will clear the brake calipers?
Advice is appreciated - thank you!
My 1973 Standard Beetle Build SOLD
Click to view image
Mike Fisher
Mike Fisher is offline
PostPosted: Sat Aug 30, 2014 10:36 am    Post subject: Reply with quote
They will fit at stock height. If the calipers were to rub you can grind on the caliper a little or run a spacer. I wouldn't put bigger than 185 tires on them?
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
TX-73
TX-73 is offline
PostPosted: Sat Aug 30, 2014 12:08 pm    Post subject: Reply with quote
Thanks Mike. I think I'll go ahead with buying them.
These are the wheels (15") that are currently on the car as "roll-arounds". They were fine with drums all the way around, currently they do rub against the calipers, but just barely. Tire size is 205/75/15 without any issues rubbing, I had also liked how they helped fill the fenderwells. But I can look at sizing from 185 to 205 I think after I get the rims.
Click to view image
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
