Terry Gaudet Samba Member
Joined: March 11, 2004 Posts: 399 Location: New Brunswick, Canada
Posted: Sat Aug 30, 2014 2:32 pm Post subject: Help with front sway bar - aftermarket |
So I bought a new 3/4 inch sway bar for my 56 bus and have been struggling with getting it on. It seems that the clamps that came with the kit are not working. See photo and let me know if you have had the same problem and how you solved it. I might have to buy one of those stainless steel clamps.
_________________ Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab |
quartermilecamel Samba Member
Posted: Sat Aug 30, 2014 6:12 pm Post subject: |
That looks like you have the king and link pin stock front end, so my question is: Is that sway bar also for a link pin bus suspension? Also, It appears as it bolts through the lower control arm as does mine. Do you have it bolted in place? If the sway bar isn't in the right position in relation to your lower suspension arm it will be hell to get that clamp on. I have a 68/69 ball joint front end from a bay window, so not sure if the split window aftermarket sway bar bolts onto the arm also. It also appears as if you have the red urethane bushings on backwards. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
schnidlee Samba Member
Posted: Sat Aug 30, 2014 6:23 pm Post subject: |
I installed one of these on my bay and it was an absolute pig of a job. I found it easier with the wheels on the ground, it just mad the angles nicer. You will need a pit or alternatively, try parking with one wheel on a curb. Good luck, you will love it once it's on. |
Posted: Sat Aug 30, 2014 6:36 pm Post subject: |
that's odd as mine went right on. I don't remember if I did it front end raised or not. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sat Aug 30, 2014 6:49 pm Post subject: |
I wonder if it has to do with it being a wolfsburg bus? Don't quote me but it seems that I heard that the wolfsburg beams were slightly different shape in the mount area. Maybe that is a factor. I think most people say its a bugger to get the clamps on. Hope you are enjoying the bus. |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Sat Aug 30, 2014 11:25 pm Post subject: |
who sells aftermarket sway bars? |
Posted: Sun Aug 31, 2014 3:50 am Post subject: |
Thanks for all the comments. The packaging said that the sway bar fits both k&L and b/j front ends. There is not hole however on the ends to bolt to the lower control arm like on the b/j beams. This is why I suspect this is for a k&L beam. I will try to fit it with wheels on the ground and see if it makes a difference. As for being a Wolfsburg bus, not sure if that is the issue. I bought this sway bar from CIP.
Eric, I'm driving this bus almost every day. Getting it ready for a Texas road trip in October....;0) _________________ Terry Gaudet
1965 Double Cab |
Posted: Sun Aug 31, 2014 4:52 am Post subject: |
Terry Gaudet wrote: |
Eric, I'm driving this bus almost every day. Getting it ready for a Texas road trip in October....;0) |
Good to hear. Hope your trip goes well.
I do remember one member on here stating there appeared to be a difference in shape of the arm on his wolfsburg bus vs. hannover production, again not sure if it would make any difference on this install. I just dragged out a stock sway bar to put on my '58 so I'll give that a go and let you know if it was as challenging. |
Posted: Sun Aug 31, 2014 2:39 pm Post subject: |
Hey Eric,
Just read that thread and i'm going to just buy a couple of stainless T-bolt clamps. I might even try to source the smaller brackets for the end. I'm sure they are there for a reason....;0) _________________ Terry Gaudet
1965 Double Cab |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Mon Sep 01, 2014 6:20 am Post subject: |
It looks to me like a 7/8" sway bar and clamps for a 3/4" sway bar.
I recall having a devil of a time mounting the aftermarket 7/8" sway bar on my bus and wound up strategically shaving some of the urethane to get the clamp to fit.
This was on a late beam in a 61 bus.
I also recall vehemently cursing the perfect void of any aftermarket engineering on the product and the utter contempt the designers, marketers, distributors and profiteers had for their customers on that job more than just about any other I have done on my bus. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Mon Sep 01, 2014 2:40 pm Post subject: |
Riff Raff wrote: |
I also recall vehemently cursing the perfect void of any aftermarket engineering on the product and the utter contempt the designers, marketers, distributors and profiteers had for their customers on that job more than just about any other I have done on my bus. |
But was it worth it Keith..... |
SambaUser1M Samba Member
Joined: October 27, 2012 Posts: 135 Location: Irvine, CA
RobzKombi Samba Member
Posted: Thu Sep 04, 2014 11:56 am Post subject: |
I have a sway-bar (like the one pictured above) installed on my bus and unlike some of the OG sway-bars mine did not come with end clamps like the ones pictured below. Are these clamps available aftermarket? I've done some searching and can't seem to find any. Are they even needed? |
