kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sat Aug 30, 2014 7:08 pm Post subject: How much tire/fender clearance and what size tire to go with |
How much clearance should i have between tire and the inside lip of the fender of a bug?
i have a 6 inch wide wheel with 3 1/4" back space. Im going to narrow beam and dont want to have the real narrowed look. Im going for a 2 1/2" drop with spindles. Currently with stock beam im 1/4 - 1/2" from outside fender. Currently have 195/60/14s thst will get replaced soon.
Wheels are 14x6, what tire should i run up in front for a 2 1/2 drop. This will be on my 55. 195, 205?
Thanks _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Tue Sep 02, 2014 10:35 pm Post subject: |
Nobody has input? _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Wed Sep 10, 2014 5:35 am Post subject: |
How much is the beam narrowed? That makes a difference there... |
Posted: Thu Sep 11, 2014 1:15 pm Post subject: |
I would like to know what clearance works without rubbing? So i can then know how much to narrow the beam. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sat Sep 13, 2014 9:59 am Post subject: |
I would run a slightly narrower tire; a 175/65-14 is 23" tall, but Tirerack only shows 1 tire in the "high performance all season" category (Bridgestone Potenza R32) and no summer tires in this size (6 in the "standard touring all season" though). 185/60's are 22.8" tall and there's more selection- 5 grand touring all season, 3 high performance all season and 2 extreme performance summer. There are other brands, I know, but Tirerack's website makes it easy to compare- http://www.tirerack.com/tires/TireSearchResults.js...unFlat=All
I'm not a huge fan of going any wider on the front, but that's me.
I would think that narrowing your beam 2 or 2 1/2" a side would be enough; that takes into account the offset of the spindles and using a slightly narrower tire and would give 1- 1 1/2" fender clearance. It would be nice if those rims had a little more backspacing, but you're working with what you have...
As usual, just my 2 1/2 cents (I'm Canadian, eh). Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
