grandpa pete Samba Member
Posted: Sun Aug 31, 2014 10:00 am Post subject: What am i missing here |
I am trying to put this directional switch on . I didn't take it apart and I have parts missing . The switch was purchased from Samba Classifieds .
I went to the hardware store and found a screw to fit the side hole and had to grind the top edges off for it to fit (see photo )
The bently talks about a " brass washer "...and a spring
Am I missing something where the pink tape is ??
Anyone have a how to fix this thread??? I tried SEARCH _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
notsnarb Samba Member
Posted: Sun Aug 31, 2014 10:37 am Post subject: |
You are missing the little clamp plate - the end of the screw is peened over to make it captive. I guess yours wasn't
Posted: Sun Aug 31, 2014 3:46 pm Post subject: |
thanks branston ;
SO here is what I have
Steering column
steering wheel
directional switch missing captive screwplate thingie.....Thanks to a samba vendor who sold me a broken part
Wolfsburg west catalog diagram shows 3 pieces without ordering numbers between the bushing I don't have and the steering wheel
Anyone have a better drawing ? _________________ 63 two fold rag
Posted: Sun Aug 31, 2014 8:35 pm Post subject: |
It would be simply enough yet fiddly to make the little plate, drill & thread and trim to size and bend. I'll get you the dimensions if you want to try.
If I had a spare plate I'd drop you one in the mail. But I don't think I do. |
Posted: Wed Sep 03, 2014 10:37 am Post subject: |
Here's the dimension of the little clip.
The screw forces it against the steering column. you may have to bend it ato suit, as the bends follow the inside diameter of the turn signal body.
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Sep 03, 2014 11:29 am Post subject: |
http://www.trfastenings.com/pages/rectangular+flat+nuts
Go to your local hardware store and look thru their assortment of these.
You can probably find one to do the job, I have. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
