on tap Samba Member
Posted: Sun Aug 31, 2014 8:37 pm Post subject: Vent Window |
I installed the vent wing window in my 63 bug. Question - is there a way to line up / adjust the vent window.?? The top of my vent window is off by a hair, the top hits the division bar...so there for it doesn't close. The top of the division bar holes are not slotted (so no adjustment).....Thanks in advance |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sun Aug 31, 2014 11:14 pm Post subject: |
Unless the shape of the door has changed, I would check that the wing glass is fully seated in the wing frame. I don't remember any adjustment in the positioning of the wing on a stock replacement. _________________ Plate of shrimp |
on tap Samba Member
Posted: Mon Sep 01, 2014 9:36 am Post subject: |
Cooooo, thanks. I think the glass is in. It's a newly purchased from WW, not re-doing one |
wayne1230cars Samba Member
Posted: Mon Sep 01, 2014 12:49 pm Post subject: |
http://www.classicvwbugs.com/2012/10/25/classic-vw...-part-1-3/
That is a job that I have done on my '60 and it can be a challenge. Make sure that the vent rubber seal is fully seated. One variable can be the quality of the seal itself. Chris at Classicvwbugs.com has a 3 part video on door assembly which I found to be very helpful. Part 3 addresses your question. Chris suggests leaving the division bar and window regulator screws loose and after winding up the window and assuring everything is aligned OK, then tighten everything up. I did this and it helped but in my case the major challenge I had was the fit of the rubber seal. _________________ 1960 beetle
1970 beetle convertible |
on tap Samba Member
Posted: Mon Sep 01, 2014 3:51 pm Post subject: |
Ya, everything is loose & I have been following the 3 step classic vw bug videos. What about the vent window bracket (the one that goes inside the door) how does it go..? is there a R & L side..? I think I have it right but now im doubting myself |
Posted: Mon Sep 01, 2014 4:38 pm Post subject: |
If this is what you are referring to, it fits both left and right. Is it a new rubber seal? In my case, the passenger side vent installed easily. I had to really fight with the driver's side. Eventually I got a good fit. As a last resort, could the holes in the bar be elongated enough to create some adjustment room? Not sure if that would work. Again I would make sure that the seal is completely seated. Good luck in getting this sorted out.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111837685 _________________ 1960 beetle
on tap Samba Member
Posted: Mon Sep 01, 2014 4:49 pm Post subject: |
ya that's it, I think I have it right. The flat (errr) side sits on the inside of the door. I have to try & figure something out to make it work. Im going to do the driver side, taking a break from the passenger side |
Gary Haberman Samba Member
Joined: October 18, 2013 Posts: 70 Location: Farmingdale, NY
Posted: Thu Oct 30, 2014 6:45 pm Post subject: Vent window post misalignment |
I am having the same issue with the driver's side vent window post on my '62. Viewing it from the outside, the glass overhangs the post by about 1/16". New window with frame, post and seal all from WW. I followed Chris's video (thank goodness for him!) and I was able to get the seal in after some time but the post seems to be misaligned. While there is some "wiggle room" for the bottom of the post, none exists at the top. I am going to take a break from this for a while but am considering opening up the holes at the top of the post to move it over a bit. BTW, I have found that parts from WW can sometimes be not manufactured the same as the originals-I purchased door stops from them and the holes that the screws go in were off a bit (ended up cleaning up the original part); similar thing happened when I purchased door strikes-part was manufactured incorrectly. I may have to check the vent window I purchased from them to see if it is not the same as the original..or maybe it's the post? Meanwhile, anyone have some encouraging thoughts? |
Posted: Fri Oct 31, 2014 10:51 am Post subject: vent window misalignment |
A follow-up to my previous post-I tried reinstalling the original vent window and it resulted in the same issue. Removed the new seal and compared it to the old one...the new one was longer by about 1/2" and of course, thicker. Installed the old seal back (wasn't all that bad) and everything fit nicely. So I ended up with new door scrapers, new vent window and divider, new window felt channels...only took two days but I did learn a lot about my car. BTW, the old seal is in many ways better as it is notched (can't think of a better description) around the turn so that it fits a lot better. |
