TheStanfordWagen Samba Member
Joined: October 06, 2013 Posts: 99 Location: Dresden, Ohio United States
Posted: Mon Sep 01, 2014 6:51 am Post subject: 68 Beetle Acceleration Problem |
While accelerating, my 68 Beetle's engine will "pause" for a split second and then continue to accelerate and then "pause" again for another split second. What would be causing this to happen? Valves, Carburetor, Timing..... _________________ 1968 Type 1 - Royal Red --- Built: September, 1967
1600 Single Port Engine - F1950480 (VW Exchange) Made January 16th, 1970
113-905-205K
Solex 30 PICT-3
Fahrgest.-Nr. 118096544 |
gt1953 Samba Member
Posted: Mon Sep 01, 2014 7:28 am Post subject: |
Hello
Tell more bout the engine. size, carb type, distributor type/numbers on it, state of tune on the engine as well. With that some written assistance will show up. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Sep 01, 2014 8:50 am Post subject: |
After checking for the part numbers I discovered that the bolt attaching the carb to the intake manifold had become loose, causing a vacuum leak. Thanks for your help! _________________ 1968 Type 1 - Royal Red --- Built: September, 1967
113-905-205K
Solex 30 PICT-3
