vegpedlr Samba Member
Posted: Mon Sep 01, 2014 8:42 am Post subject: Stranded in Flagstaff, AZ |
So my Westy and I made the epic drive from Tahoe to Needles, down the Eastern Sierra, over several 7500+ ft passes, across the desert, past the burnt out meth labs, not a hiccup.
Yesterday, leave Needles, start meandering my way up I-40, until near Seligman, the temp gauge goes bananas. The oil light came on, and I pulled the ripcord. Looked under the van to see coolant pouring out and smelled a few drips of oil. Main coolant tank empty.
I had checked out Roadhaus ahead of time and knew there some VW shops in Flagstaff, but of course, on a holiday weekend, nobody there. One reviewer told their story of how the Flag KOA people helped, so I called them. "Sure, no problem, we've got room, you can tow it right in. Don't worry, you're not first VW to be towed in this weekend."
The staff is filled VW fanatics. They gave me a VW discount because they like to look after their VW people. Turns out they host a VW event, the High Country Kampout every July.
I've had better trips, but I've also had worse. There are far worse things than to be stranded in Flagstaff, and a Westy is not a bad vehicle to be stranded in.
Thanks Jim and Janyel! The nicest, most helpful folks around. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon Sep 01, 2014 10:15 am Post subject: |
FYI, the oil smell is most likely the steam cleaning effect of hot coolant and steam getting existing oil on the engine to activate its evaporative smelling components. Unless you are actually seeing oil from something. So, focus on what is causing the coolant leak, then recheck for any oil leaks.
Sounds like you are not asking for any help? So good luck with it and glad you are in a good spot that is good for all of us to know about. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
LandSailor Samba Member
Joined: October 30, 2009 Posts: 315 Location: Las Vegas, NV
Posted: Mon Sep 01, 2014 11:00 am Post subject: |
Too bad the KOA land was sold after the owner died to be turned into a supermarket.
They're great folks! |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Sep 01, 2014 11:25 am Post subject: |
Oil light or maybe it was the alt light? Have you been under the hatch for a look?
Could be you just threw a belt - the alt belt also drives the water pump. Losing that belt
stops both, giving you both the alt light and soon thereafter your overheating event.
Check it out... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Sep 04, 2014 6:37 pm Post subject: T junction, now what? |
Got into R&R Automotive Flagstaff right away Tues morning, a pressure test revealed a busted T junction, which was suspected. Fixed, refilled, tested, good to go. Drove to Sedona and around for a couple of days. This morning, a nice puddle of coolant, drip, drip. Traced it to the hose from the radiator to the housing where the thermostat is. Tightened the hose clamp, leak stopped. Time for another top off and bleed.
I could probably get around Four Corners faster on my bike. Instead, I tour VW mechanics.
I remain optimistic, I WILL get this cooling system dialed in. |
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Thu Sep 04, 2014 6:40 pm Post subject: |
Only the strong survive a Vanagon _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Posted: Fri Sep 05, 2014 6:30 pm Post subject: Two Bleeds |
First shop I called and asked if they could top off and bleed a Vanagon replied that they needed to see it to know. Second shop checked and said no problem. Except the mechanic got it wrong. Five miles later it puked out all its coolant. Again. Sent it back and this time they did their homework.
Why does my van pass pressure tests, then puke coolant?
Is the cooling system such that you must test multiple times in different places? |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Fri Sep 05, 2014 8:01 pm Post subject: It's a 30-year old car! |
FWIW, there was a thread recently where somebody was experiencing a series of blowouts and leaks which came to a stop when he replaced the coolant reservoir pressure cap. Apparently the old one was clamping down pretty tight and the pressure exceeded normal. Might be a cheap fix. Do any of the rest of you miss your old air-cooled rigs? I never had to worry about a coolant leak with mine. |
?Waldo? Samba Member
Posted: Fri Sep 05, 2014 8:20 pm Post subject: |
Combustion gases could also be entering the cooling system. Pressure testing might not show it as combustion pressures are MUCH higher and might leak into the cooling system where the coolant pressure doesn't leak out. |
Posted: Sat Sep 06, 2014 4:34 pm Post subject: |
I saw the pressure cap thread, but mine is less than a year old. I have the receipt, and fond the old one in the rear cabinet. As for exhaust gases entering the system, that sounds pretty mysterious to diagnose. Any tips about where to look?
Thanks gang. |
Posted: Sat Sep 06, 2014 4:40 pm Post subject: |
Any FLAPS will have a test kit for exhaust gases in the coolant. |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1391 Location: Taos NM
Posted: Sat Sep 06, 2014 4:56 pm Post subject: |
vegpedlr wrote: |
Thanks gang. |
Those pressure caps are notorious for defects right off the shelf. |
Posted: Sun Sep 21, 2014 8:50 pm Post subject: Now what? |
OK-
Busted t-junction, fixed.
Loose hose clamp tightened.
Cracked radiator hose, replaced
New expansion tank and pressure cap
New belts (why not?)
Bled more than a medieval leech. (doctor)
NOW, drove it up to the Jerome Jamboree and ran a bit hot, temp a bit high, a couple flashes as I idled around looking for a campsite after a steep climb. Same problem driving up Oak Creek Canyon. Gave the van a nice rest, finished the climb to Flagstaff, running a little hot, but not bad. No coolant leaks . . .
EXCEPT the overflow tank is over flowing, way above the max line, dripping a bit out the cap, not enough to make a puddle. Meanwhile, the main tank is at minimum.
Any thoughts?
I'm also a little tired of the air cooled guys just shaking their heads at me. |
human compass Samba Member
Joined: June 04, 2013 Posts: 423 Location: Flagstaff,AZ
Posted: Sun Sep 21, 2014 8:57 pm Post subject: |
No thoughts but I have a great mechanic in Flag if your still around here. He used to be a VW factory mechanic during the time vanagons were produced and now owns his own shop. He has done very very solid work for me and a few other vanagon owners up here.
wilson's automotive _________________ 84 Westy Syncro- 3.3L SVX stage 2 tune,subaru gears 6speed with tbd, front locker, porche brakes x4, aux tank, radflo susp |
Posted: Sun Sep 21, 2014 9:04 pm Post subject: Thanks |
human compass wrote: |
wilson's automotive |
Thanks. Yes, I'm in Flag tonight. I will call in the morning, who should I ask for? |
Posted: Sun Sep 21, 2014 9:10 pm Post subject: |
Ask for Jim Wilson. Let him know Mike Hudson referred you. If you need a hand with anything or some workshop space please PM me and I'll do what I can.
cheers _________________ 84 Westy Syncro- 3.3L SVX stage 2 tune,subaru gears 6speed with tbd, front locker, porche brakes x4, aux tank, radflo susp |
danfromsyr Samba Member
Posted: Mon Sep 22, 2014 6:26 am Post subject: |
air-cooled buses leak coolant all the time.. they jut can't see it because it's invisible
that is untill they drop a valve seat or stretch the head off of a valve..
and if air-cooled are soo reliable and easy to work on. why are they working on them all the time too?
ask them about their heat? maybe 15% would have some...
some that fogs up the glass in the rain/humid air cold air.
Quote: |
I'm also a little tired of the air cooled guys just shaking their heads at me |
Abscate wrote: |
Posted: Mon Sep 22, 2014 8:07 am Post subject: |
danfromsyr wrote: |
True. My WBX may puke coolant, but they puke oil. Seems like it's one or the other. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Mon Sep 22, 2014 10:14 am Post subject: |
had a great time in jerome this year! we'll have to meet up one of these shows, veg
if it's really running hot then it sounds like the system is working perfectly fine.
turn the engine off and it will pull coolant back into the pressure tank. right?
you wouldn't have done something like have the belt in the wrong spot on the crank pulley, would you?
just askin... _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon Sep 22, 2014 11:04 am Post subject: |
borninabus wrote: |
just askin... |
The problem is the coolant is in the wrong tank. The expansion tank is low, and the overflow tank is way too full. For some reason, the coolant isn't flowing back into the main tank when it cools down. The blest, and everything else was done by a pro. Will continue to investigate further tomorrow morning.
Jerome was great. Hoping to make it to Havasu in Jan. |
