Motor60 Samba Member
Posted: Mon Sep 01, 2014 10:08 am Post subject: CB linkage binding on alternator |
How do I get the hex bar not to rub on alternator? I'm using the lower holes on carb bases. Bought these from a guy who had them installed on a bus. Could the bases be wrong size? Also seems as if hex bar is too short |
Posted: Mon Sep 01, 2014 10:15 am Post subject: |
Posted: Mon Sep 01, 2014 11:01 am Post subject: |
The bar length is 20 1/8" |
ChadCook Samba Member
Joined: January 09, 2011 Posts: 764 Location: Charles Town
The first engine I clearance the bar slightly. The second one I drilled and tapped a third pair of holes in the middle of the original holes. |
Posted: Mon Sep 01, 2014 11:07 am Post subject: |
What about bar length? |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Mon Sep 01, 2014 11:43 am Post subject: |
Your going to raise them to the top holes _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Bugzilla Samba Member
Joined: February 08, 2004 Posts: 240 Location: Rapid City, SD
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Mon Sep 01, 2014 12:38 pm Post subject: |
Your bar may have been already cut down for a narrower engine. As far as the alternator rubbing, it's obvious. Either buy taller manifolds, or move them up to the higher location. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Mon Sep 01, 2014 12:46 pm Post subject: |
Why not space the end pieces on the carbs, up higher? _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Mon Sep 01, 2014 12:47 pm Post subject: |
I bought the cb offset manifolds. They supposed to be made for this linkage right?? If I move them to top holes, now I face throttle cable bind. Bar was not cut. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Mon Sep 01, 2014 2:11 pm Post subject: |
Do you have shims under your cylinders ? could be the bus had a narrower engine without shims.
Nothing aftermarket will fit completely 100% properly except on the exact same engine for which it was designed.
The alternator housing is mostly aluminum and not amazingly structural - some PO has ground a hole in the side of mine and then re-filled it with JB weld to provide carburettor clearance at some time in the past.
You can probably file a shallow groove in the top of the alternator without going through the metal, or put some thicker spacers (you may find the original installations of that linkage used spacers) under the carburettors. |
hsosa1 Samba Member
Posted: Mon Sep 01, 2014 2:35 pm Post subject: |
Motor60 wrote: |
raise it to the top hole your going to need to buy the longer threaded cb throttle arms so you wont bind. You can also ad a throtle cable extender if u need more length. _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Posted: Mon Sep 01, 2014 3:45 pm Post subject: |
I don't know if it has shims. It's a mofoco motor 1776. 8:1 compression |
Posted: Mon Sep 01, 2014 4:28 pm Post subject: |
How does everybody else mount this linkage?? |
babysnakes Samba Member
Posted: Mon Sep 01, 2014 4:41 pm Post subject: |
I had a similar issue. I went to the bicycle store and bought an old 90's style pulley with a sealed bearing. The type that were after market and used at the rear derailer. I fabbed an easy bracket and pop riveted it to the shroud.
( the rats nest has since been tidied up ) I'll take a better pick tomorrow when it's light outside.. |
Posted: Mon Sep 01, 2014 6:28 pm Post subject: |
What's with that clevis connection at the right carb?? _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Mon Sep 01, 2014 8:03 pm Post subject: |
Does anybody use CB linkage anymore? Or am I just spinning my wheels. I gotta get this motor back in the car. |
mightymouse Samba Member
Posted: Mon Sep 01, 2014 8:15 pm Post subject: |
i suggest a new hex bar since yours was cut so small. And then you can use an aluminum burr and put a small channel in the alternator body and remove some from the hex bar and it will clear with ease.
Looks like you may only need to clearance the hex itself.
Thats how mine is done.
Not much has to be removed. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Sep 01, 2014 9:07 pm Post subject: |
Longer bar and use upper holes in brackets ... Shazzam.... It works...
Everything else looks ok....But move arms on hex bar out to as close to carbs as possible so link rod is as close to vertical as possible...
74 Thing Samba Member
Posted: Tue Sep 02, 2014 7:07 am Post subject: |
Or you can get thicker gaskets between the carbs and manifolds-I know you are running Webbers. I run Dells and they have thicker gaskets to eliminate the whistle that those carbs are known for. http://vwparts.aircooled.net/Dellorto-DRLA-Anti-Wh...gasket.htm
Are you sure your shroud is all the way down and that the alternator stand and alternator are not causing a problem keeping the alternator a bit higher (I had a Chinese alternator with a German alternator stand that has a round nub facing the rear that aligns with the cut out in the alternator. Unfortunately the cut out in the alternator was off a bit so the alternator would not sit down so I had to get the dremel out and do some modification work.). |
