videoguy009 Samba Member
Joined: March 31, 2008 Posts: 711 Location: Saint John N.B. Canada
Posted: Mon Sep 01, 2014 11:34 am Post subject: 1973 Dual Muffler Stock exhaust |
I have the divided header on my 73 thing.I was looking at buying the stock dual muffler system.I have a 1776 with a 110 cam.Will this new exhaust be more restrictive and will it be quieter than the divided header. _________________ 1971 Super Beetle |
quartermilecamel Samba Member
Posted: Mon Sep 01, 2014 12:39 pm Post subject: |
I would guess quieter than non stock but any pictures? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Mon Sep 01, 2014 1:02 pm Post subject: |
You can see a pic at www.cip1.ca part no. C23-35181.There is one for each side. _________________ 1971 Super Beetle |
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Mon Sep 01, 2014 5:20 pm Post subject: |
videoguy009 wrote: |
You can see a pic at www.cip1.ca part no. C23-35181.There is one for each side. |
and part # C23-35182 for the right side. _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
Posted: Mon Sep 01, 2014 6:12 pm Post subject: |
Kafer,Will this setup work ok as far as my original question. _________________ 1971 Super Beetle |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Mon Sep 01, 2014 7:55 pm Post subject: |
I would give up a little top end for a little quietness.The pipe diameter is 1 3/8 on the divided and it looks the same on the duals.My ports on the motor are 35 intake and 40 exhaust.40 exhaust is approx. that diameter of the pipe.I should be okay with very little restriction. _________________ 1971 Super Beetle |
IHC Samba Member
Joined: April 30, 2012 Posts: 204 Location: Washington state
Posted: Mon Sep 01, 2014 8:33 pm Post subject: |
The one at cip is for the 74 with heater boxes not the73. You can use it with j pipes on the 73.You can purchase the correct 73 exhaust from The Thing Shop.Go to their web site and look at the stock 73 exhaust. |
randybriscoe Samba Member
Joined: December 26, 2007 Posts: 241 Location: chicago
Posted: Mon Sep 01, 2014 8:46 pm Post subject: |
Top is the available OEM muffler, as of 2014. The one below is an original '73 muffler from my car. These are similar in concept to the WWII mufflers on the Type 82, designed for ground clearance/angle of departure. It's a credit to VW engineers that they were flexable enough to design body clearance for both. Also the HP ratings on the thing were the same as the sedan. But a well designed/tuned 4-in-to-one header will give you more power up top. I wonder if these don't increase cylinder head temp with there proximity to the valve covers? |
Posted: Mon Sep 01, 2014 8:50 pm Post subject: |
Posted: Mon Sep 01, 2014 8:56 pm Post subject: |
Wait, just noticed the 110 cam and the valve size...now I want to say something more. First a question, you have big valve heads? Any port work? Who's heads are those? And we need to know induction, what carbs? Is this an all the time street car? I got's to know. |
Posted: Tue Sep 02, 2014 12:27 am Post subject: |
wow just looked at the dual headers. I figured you had some aftermarket loud dual mufflers on there. Im honestly not sure if the single header muffler dual tip would be quieter or not. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Tue Sep 02, 2014 4:31 am Post subject: |
As far as increasing head temp because of the location,nothing can be any closer than the divided header system.I am running an empi 40mm single carb with a 019 Mechanical distributor.There was no port work done and the heads are rb 042.For some reason the Thing Shop only shows the divided header system and no other mufflers.The part numbers I gave at CIP is the stock 73 without heater boxes. _________________ 1971 Super Beetle |
Posted: Tue Sep 02, 2014 4:32 am Post subject: |
Sorry forgot to add that this is a street car. _________________ 1971 Super Beetle |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Tue Sep 02, 2014 10:08 am Post subject: Air filter |
Hey Videoguy009,
Just to note,
when I got my 73 with the stock style exhaust, it was LOUD,
after i started putting it back to more of a stock look, (in the form of a oil bath air filter), thats when I noticed it got quiet big time.
i know the exhaust will change the sound level but I was supprised that
going from a small chrome air filter to the stock style made as much difference as it did.
After a tune up it was even better, and I even researched a "quiet tire" to try to eliminate as much noise as possible, you couldnt even talk to your passenger without yelling it was so loud before.
now, you can talk fairly normal.
Just 2 cents if it will help, not sure what type of air filter intake system you have but a lot of engine noise does seem to come from there.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Posted: Tue Sep 02, 2014 11:07 am Post subject: |
Thanks,I do agree as to how the air is handled coming into the carb. I had that experiment on my beetles.I have the stock empi 40mm idf carb so I am pretty well stuck to the air filter it came with.I spoke to German Motor Works,who own 6 Things and they said the stock 73 exhaust worked really well on his 1776 and that it was fairly quiet compared to the divided header system which is Chinese junk. It is simply two hollow cans.The German stock exhaust was engineered with internal baffles,Etc. Alot of people do not realize the divided header exhaust is made in China. _________________ 1971 Super Beetle |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Tue Sep 02, 2014 8:31 pm Post subject: |
here is a picture of the inside of a stock 73 exhaust
after market 73 exhaust
stock 73 exhaust |
Posted: Wed Sep 03, 2014 5:54 pm Post subject: |
How is the stock exhaust for valve adjustment? _________________ 1971 Super Beetle |
Posted: Wed Sep 03, 2014 8:19 pm Post subject: |
Tight but you do not need to remove the exhaust. The stock exhaust will effect your power in a negative way you can not increase the valve size and the amount of fuel going in to the engine and not increase the size of the exhaust. Remember the exhaust pipe coming out of the stock exhaust is only 1 inch.
Jonny Rock Samba Member
Joined: October 18, 2013 Posts: 52 Location: Tulsa, Oklahoma, USA
Posted: Thu Sep 04, 2014 6:50 am Post subject: |
My stock replacement 73 exhaust doesn't seem to be too loud, but I am also running the stock oil bath cleaner.
I believe mine is the linked replacement kit, as my mufflers have a round, can type of exterior vs the originals with the two flat weld seams.
http://www.jbugs.com/product/181251053G.html?Category_Code=vw-thing-stock-exhausts
Adjusting the valves is still quite easy with this exhaust. |
