MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon Sep 01, 2014 2:07 pm Post subject: Ebrake flipper...mod |
How many times have you had that little button spring out of the ebrake handle? Could be one click too many. Not adjusted the cables.
Here is a 32 second mod that is worth doing. All it will cost you is a roll pin or a cotter key. Figure out the travel on the little pawl and then drill a hole and pop a cotter key in there. (The first hole was just an engineering experiment ) LOL.
No more button ejection!!!
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Sep 01, 2014 5:04 pm Post subject: |
That.... is just too easy....
Nice.. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
EVfun Samba Member
Posted: Mon Sep 01, 2014 5:30 pm Post subject: |
Don't you have to over-lift the handle to initially install the spring loaded guts? It's been a few years since I had to put one back together. It could be a pain to get a roll pin in or out with the handle in place. The cotter pin looks easy, but could be a issue with some covers.
One other option would be a small screw. Drill through the handle with the appropriate drill size for a 4mm or 8-32 tap and tap. Then open the other side with the close fit clearance hole for the threads. Put the screw in the threaded side have it long enough to be supported by the other side, but not stick through (tap from the clearance hole side too, to help keep the tap strait.) _________________
Wildthings wrote: |
FarmerJohn Samba Member
Joined: December 16, 2007 Posts: 417 Location: Long Island NY
Posted: Mon Sep 01, 2014 6:56 pm Post subject: |
I think I'm going to have to do this . Great Idea !! _________________ Now I Drive A Hard Top Buggy ! |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Mon Sep 01, 2014 7:30 pm Post subject: |
MURZI wrote: |
No more button ejection!!! |
Like! |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Mon Sep 01, 2014 8:10 pm Post subject: |
Yo Murzi, I hear EMPI's already got a kit coming out in their next catalog!!! _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Tue Sep 02, 2014 1:50 am Post subject: |
Brilliant! And in my price range too. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
MURZI Samba Member
Posted: Tue Sep 02, 2014 5:22 am Post subject: |
Lo Cash John wrote: |
Yo Murzi, I hear EMPI's already got a kit coming out in their next catalog!!! |
I bet..... _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
