Greg Greer Samba Member
Joined: September 19, 2013 Posts: 7 Location: Boone, NC
Posted: Mon Sep 01, 2014 6:34 pm Post subject: Mystery Screw Needs ID, Please |
1966 Porsche 912 with 1968 engine. We have these ports coming off the inside-side of the manifolds. Each one has what seems to be hardened rubber tube (not sure if it was always hard or if it's just hardened with age) ending in a screw coming off of it. You can see pictures of it with and without. It's not actually part of the carb. I can't locate it in either of our manuals (912 Handbook and Clymer). Our best guess at this point is something to do with the primitive emissions system. Does anyone know?
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Mon Sep 01, 2014 6:36 pm Post subject: |
Its a plugged vacuum port for the vacuum retard of the 061 distributor. _________________ Glenn
Member #1009
#BlueSquare |
mtnroads Samba Member
Joined: December 06, 2006 Posts: 403 Location: Minkler, CA
Posted: Tue Sep 02, 2014 11:09 am Post subject: |
Back in the 80"s " I think it was the 80's" here in cali to meet smog we had to install a "nox" reduction kit. Seems to me it had a vaccum plate like this as well. "I knew I was going to miss those brain cells" _________________ pax
No Good Deed Goes Unpunished.... |
