BajAMec63 Samba Member
Posted: Mon Sep 01, 2014 7:11 pm Post subject: 1600cc Turbo 1/4 mile results |
Last May at BOR I ran my first passes ever in my Turbo 1600dp street bug. heres the specs it had then:
Stock 1600cc DP:
Stock-
Crank
Rods
Pistons
Camshaft
Heads ( except single hi rev springs)
Ignition:
Locked 009 20* timing
Points
autozone coil
autozone plug wires
ngk stock plugs .025 gap
Turbo:
T25 from DSM 2g eclipse
Carb:
holley 350 2bbl
custom intake
custom exhaust
ebay wastegate 5 psi spring
On 10psi heres what it ran:
15.3@90mph
2.3 60 ft
NOW... This time i made some changes and added this only:
MSD BTM
MSD 2 step launch control
MSD Distributor
MSD wires
Snow Performance stg 2 water/meth injection
15 psi wastegate spring
Custom Kafer bar
Oil cooler
100 octane gas
and....18psi of boost
my last pass when I cranked the boost heres my results:
14.1@95mph
2.0 60ft
With better launch i knew i could have reached the 13.99 mark.
every run i improved in the following times:
15.4@90
14.9@92
14.5@92
14.7@93
then 14.1@95
I ran faster then my dial in time on last pass but didnt care when I saw my time. im making a few adjustments and will go back again to get that 13.xx _________________ Turbo 69' street bug - 1600cc, t25 turbo, holley 2 bbl, custom header, full msd w/ btm, water meth, 18 psi, single hi rev springs, stock cam, stock heads
14.1@95 mph |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Mon Sep 01, 2014 10:46 pm Post subject: |
Nice. Do you remember how much was spent on the turbo specific or parts modified for turbo use BEFORE the changes and after? I saw the pic of your engine. You might benefit from an inexpensive Moroso crankcase evacuation system. You'd need a sand seal and an air/oil separator or a good oil baffle that's completely sealed (e.g. without a breather). The whole system could cost you under $150, and free up some crankcase pressure, thereby freeing up a few HP. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Sep 02, 2014 5:24 am Post subject: |
Awesome,but u need to work on the 60ft times,, Slicks?????? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Tue Sep 02, 2014 9:13 am Post subject: |
I think I spent around 800-1000 dollars on it. Wasn't too bad.
Yeah I need ventilation, its in the works. I was trying to find slicks in time but I just used my street tires and lowered the pressure. My 60 ft kept improving as im still learning how to launch the car. _________________ Turbo 69' street bug - 1600cc, t25 turbo, holley 2 bbl, custom header, full msd w/ btm, water meth, 18 psi, single hi rev springs, stock cam, stock heads
14.1@95 mph |
OldSlammers Samba Member
Joined: January 29, 2014 Posts: 18 Location: Reno Nevada
Posted: Thu Sep 04, 2014 11:42 am Post subject: |
I have the same set up going for me in my ghia but with a single port. T3/t4, has a lot of top end on boost, 38mm wastegate with 7psi spring. Everything is stock didn't even lock out the timing. I haven't tried race gas yet, will soon |
Posted: Thu Sep 04, 2014 2:35 pm Post subject: |
Crank up the boost! Youll never run less then 15psi again _________________ Turbo 69' street bug - 1600cc, t25 turbo, holley 2 bbl, custom header, full msd w/ btm, water meth, 18 psi, single hi rev springs, stock cam, stock heads
14.1@95 mph |
