kikkegek Samba Member
Joined: September 27, 2014 Posts: 23 Location: Netherlands
Posted: Sat Jan 17, 2015 1:36 am Post subject: |
hi guys, just to be sure the BB wasnt causing my rough idle and hesitation during take off, I swapped distributors last night. An voila..idle is now rick steady and take of has no more hesitation. So I guess the BB is for some reason causing this. I have absolutely no idea why.
For now I wont put the BB back for a while, but sent a report to CB Perfomance...the product doesnt seem to be plug-and-play..far from that...they told me recently they are working on an update and email me when its available...they didnt have a ETA yet. |
Porsche60 Samba Member
Joined: December 27, 2007 Posts: 210 Location: Far East
Posted: Mon Jan 19, 2015 7:12 am Post subject: |
i believe many people are running their black boxes without an issue.
but too many situations to consider what would cause a problem.
this item is not just a auto electrical but a micro computer.
it will take some time to debug. |
Dale M. Samba Member
Posted: Mon Jan 19, 2015 8:17 am Post subject: |
Porsche60 wrote: |
Quit making excuses for CB-P and the BB, the buying public should not have to debug a P&P product...
Posted: Mon Jan 19, 2015 11:02 am Post subject: |
I actually did some more testing and found that its probably not the BB that is causing my rough idle and hesitation during take off. Its also there with the replacement distributor (this without the BB).
Guess I have to do some more research |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Mon Jan 19, 2015 6:48 pm Post subject: |
Probably just as many excuses for Megasquirt not working for some.
A marginal install will cause problems on most anything.
Most of it is probably a rats nest wiring job. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Mon Jan 19, 2015 7:17 pm Post subject: |
Dale M. wrote: |
Porsche60 wrote: |
Dale |
CB should make an excuse and buyers should agree it.
nothing improves without public opinions. |
tstevenson Samba Member
Posted: Tue Jan 20, 2015 5:54 pm Post subject: |
I followed this thread since the CB Black Box was released. Back in November, I decided to buy a Black Box to upgrade my ignition. I tried to get it working over the course of 2 months. Long story short, I was having extreme kick-back, no-start issues. Both Pat and Mark at CB provided assistance, including bench testing my exact setup in their shop. They also had issues with the Pertronix Billet distributor and Ignitor II module working with the Black Box.
For full transparency, I wanted to post my experience here after trying to solve my issue with CB directly. An amazing product in theory, however I don't think it's ready for all applications as a universal upgrade.
Below is my support email to CB documenting my experience:
I'm having trouble starting my motor after installing the CB Black Box inline with my ignition. I've tried just about everything I can think of and I'm at my wit's end. I wanted to ask you guys before posting on theSamba for help. Hopefully you can give me a few more things to try before worst case scenario, packing it up and shipping it back.
Motor Specs:
- 2276cc type 1
- DRD L6 heads
- Pertronix Billet Flamethrower Distributor with Ignitor II module
- Pertronix Flamethrower II Coil, 45KV, 0.6ohm
- Pertronix 8mm plug wires
- NGK DPR6EA-9 resistor plugs (new)
- NGK D6EA non-resistor plugs (new)
Installation Steps:
1. Locked out Pertronix distributor advance by making aluminum plate to go across all 4 posts.
2. Tested motor running with dist locked at 10 degrees. Started up, runs fine.
3. Installed vacuum kit under carbs. Started up, runs fine.
4. Wired Black Box correctly following "Ignition Module Wiring" diagram. Distributor neg wire now goes to Black Box first, then from Black Box to neg terminal on the Coil.
5. Grounded pins 3 and pins 6 to secure chassis ground.
6. Indexed crank starting at TDC, dist rotor pointing at #1. Rotate crank to 70 BTDC. Rotate dist CCW until rotor points back at #1.
7. Software connects successfully, does not ever disconnect. Loaded dual carb timing map successfully. Can read back map at anytime. Reads pressure correctly from vacuum plates.
8. Cranking shows about 180-200RPM on software
Failure Mode:
1. Engine cranks with starter, timing light on and blinking, timing blinks at 10, 70, blank, 10, 10, somewhere in between, 10, blank, 70. Kicks back.
2. Engine cranks with starter, starter kickback
3. Engine cranks with starter, add gas down carb throats, backfire out exhaust, backfire out carbs.
4. Ultimately, engine will not start, due to very bad mistiming.
Troubleshooting Steps:
1. Put everything back to stock: Disconnected Black Box wiring, distributor wired directly to coil, indexed distributor back to TDC with rotor on #1. Starts up, runs fine. Timing light blinks immediately and consistently on 10 BTDC.
a. Eliminates distributor cap, rotor as suspect. Also, eliminates spark plugs as suspect.
2. Wire Black Box back up, index distributor and crank to 70 BTDC. Same failure mode.
3. Set timing map to a constant 10 BTDC for every cell to match crank timing which is fixed at 10 BTDC for all RPM, all MAP. Same failure mode.
4. Thought it could possibly be interference or noise affecting the distributor signal that goes to the Black Box.
a. Ran shielded cable from distributor, to Black Box. Ran shielded cable from Black Box to coil. Shield grounded on both ends. Same failure mode.
b. Disconnected alternator from starter. Also, removed fan belt so alternator no longer spins. Same failure mode.
5. Thought voltage drop from battery when cranking could affect power supply to Black Box. Batt voltage is 12.5V nominally, when cranking it drops to 10.8V-11.0V.
a. Connected Black Box to external 12V car battery as power source. Connected external battery ground to chassis ground.
b. When cranking, same failure mode, however Black Box power source never changes from a constant 12.5V.
6. Pulled wires off of plugs in motor. Hooked wires up to external spark plugs, each with their own ground in engine compartment.
a. When cranking, I see sparks on all 4 plugs. (Interestingly, spark on plug #1 takes 2 full rotations of the crank before it sparks)
b. Timing light is consistently blinking on 10 BTDC. (Again, timing light blink takes 2 full rotations of the crank to blink)
c. Timing light on crank matches timing indicated on PC while cranking.
7. Probed distributor output (input to Black Box pin10) while cranking with high impedance probe and digital oscilloscope. Waveform captured.
a. Frequency of waveform of distributor pickup pulses are very consistent with constant cranking RPM.
b. Frequency of pluses is 6.6Hz, which equates to 198RPM. (using 1Hz=30RPM). Software shows about 200RPM.
c. Timing light on crank consistently blinks on 10 BTDC. Also matches software 10 BTDC.
d. This is the attached filename: Dist_Output_to_BB_Input_Pin10_GOOD_cranking_pulses.jpg
e. Proves distributor pickup is working correctly, also distributor is indexed to match software timing number.
f. Keep in mind, my wires are pulled off the plugs in the head and hooked up to external spark plugs.
8. Probed the Black Box pin7 output to the Coil neg side. Waveform of coil voltage pulse captured.
a. Ignition voltage pulses from coil look good
b. This is the attached filename: BB_Output_Pin7_to_Coil_Neg_GOOD_coil_fire_cranking_pulses.jpg
c. Also, a zoomed in version of the ignition voltage pulse: BB_Output_Pin7_to_Coil_Neg_GOOD_coil_fire_cranking_pulse_ZOOM.jpg
9. Went back to probing the distributor output (input to Black Box pin10) while cranking, however this time I plugged the spark plug wires back onto the plugs in the motor. Waveform captured.
a. Frequency of distributor pickup pulses are not consistent with constant cranking RPM.
b. Frequency of pulses on waveform seem to match strange timing light blinks as 10, 70, blank, 10, 10, blank, 70, etc.
c. This is the attached filename: Dist_Output_to_BB_Input_Pin10_BAD_cranking_pulses.jpg
d. This is why I am not able to start the motor due to bad mistiming.
So, the Black Box is not able to get a constant pulse from the distributor with the spark plugs are firing in the cylinders. External grounded plugs seem to be ok, but not the plugs in the head? Very strange.
It seems as though when cranking, the Black Box can't decide when to fire the coil. This is when the timing light shows 10, then 70, then somewhere in between, then 10, then nothing, then 70, etc. Either due to the random input pulses, or corrupted output pulses? Have you ever had anyone run a Pertronix Billet distributor with your Black Box?
After trying a few more things, I gave up on the CB Black Box and bought the Magnaspark Digital Distributor. Had it installed and hooked up in 30 minutes, motor started on the first crank. No problems since. Now, I'm playing with my timing maps. Excellent product, it's exactly what I was hoping the Black Box would do for my existing ignition setup. |
Posted: Tue Jan 20, 2015 7:48 pm Post subject: |
Thanks for detailed post.
It would help many people.
So, you found that the black box may not work with some distributors?
Is it the tightness or accuracy of the distributor shaft?
I've run 2 distributors with my black box.
1 - Treuhaft 010 (Mallory single point) with Pertronix Ignitor II
2 - Brazilian Bosch 009 with Pertronix Ignitor (I)
Both run ok but I feel 009 is better.
I also use Beru cap & rotor, Mallory 29217 1.4ohm coil, Flamethrower 7mm wires, NGK BPR6HIX (resistor, iridium), 0.8mm gap |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Tue Jan 20, 2015 8:13 pm Post subject: |
tstevenson wrote: |
tstevenson,
Awesome post, very detailed.
I was with you for your entire post and feeling your experience was very similar to mine until your last few lines. I have all of the same starter kickback issues others in this thread are talking about with the digital distributor.
Please update this thread after you have more time on the digital distributor and verify it is not having the same exact issues. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
theDrew Samba Member
Posted: Tue Jan 20, 2015 11:03 pm Post subject: |
tstevenson, thanks for the detailed post as well.
This confirms what I was running into on startup as well. Random firing which resulted in hard starts and kick backs -- I just dont have a fancy oscilliscope to prove it! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
BBMV8 Samba Member
Joined: September 26, 2014 Posts: 12 Location: The Netherlands
Posted: Wed Jan 21, 2015 3:49 am Post subject: |
Very nice write up.
When sparkplugs are put back into the engine, the engine's compression make it harder for the ignitionsystem to bridge the plug-gap, so ignition coil output will increase.
Perhaps this stronger sparksignal is somehow still interfering with the BlackBox?
Or maybe it's just the electrical groundsignal is becoming 'dirty' and causes flowcurrent issues?
Anyone ever used a different ground for the Blackbox? Perhaps grounding it to the engine only or battery?
Might be there is a need for the BlackBox housing itself to be grounded somewhere as well.
I know the Megasquirt-installation manuals are very finicky about electrical grounding. |
Posted: Wed Jan 21, 2015 5:16 am Post subject: |
tstevenson,
you tested DISTRIBUTOR -> BLACK BOX signals, right?
NOT Black Box -> Coil.
then, some how the Ignitor unit is interfered by something, I guess.
How about to run a POINT?
Guys having kick back problems,
what pick up module do you use? |
BBMV8 Samba Member
Posted: Wed Jan 21, 2015 5:59 am Post subject: |
I didn't have kickback issues in the beginning.
Only during my last 2 attempts I started having them. I try to remember if I changed anything in the system that might have an origin to this issue.
I'm using a stock Chrysler distributor with 'vr'-pickup (V8 engine). |
Posted: Wed Jan 21, 2015 9:31 am Post subject: |
BBMV8 wrote: |
to help with troubleshooting, I ran the black box wires directly to the battery. Did not change anything. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
eshenbaugh Samba Member
Posted: Wed Jan 21, 2015 10:47 am Post subject: |
Been running my BB since October 2013, absolutely zero issues. Draw through turbo setup with 009 and pertronix. |
Pat D Samba Member
Posted: Wed Jan 21, 2015 12:47 pm Post subject: |
Dale M. wrote: |
Porsche60 wrote: |
Dale |
For the record Dale, we do not use customers to debug products. We tested the Black Box in the field for 6 months before releasing it to the public. Never at any time did we see a kick back issue on start up. To date, we have sold over 300 units. Out of these 300 units, less than 15 people are having kick back issues, about 2%. Mark and I are working on a new code to alleviate the kick back problem. Once we have something, we will make it available to customers. We are close on an update, Mark and I work on it every day.
Again Dale, Problems can exist after a product is released. You think it has been tested thoroughly but once it is in the field, problems can pop up. Mark and I are doing everything we can to get a fix released as quickly as possible, again we are very close. _________________ Pat, Im too fast slow me downs! |
Pat D Samba Member
Posted: Wed Jan 21, 2015 1:34 pm Post subject: |
We found an issue when the Black Box transfers from cranking timing to the spark table. Different brands of distributors add to the problem, some don't have it at all. Replicating it has been a challenge. Then there is the noise issues that some distributors have like an MSD and our magnetic trigger magnaspark. They are very good distributors but are susceptible to noise in some situations. _________________ Pat, Im too fast slow me downs! |
Posted: Wed Jan 21, 2015 1:56 pm Post subject: |
Pat D wrote: |
We found an issue when the Black Box transfers from cranking timing to the spark table. Different brands of distributors add to the problem, some don't have it at all. Replicating it has been a challenge. Then there is the noise issues that some distributors have like an MSD and our magnetic trigger magnaspark. They are very good distributors but are susceptible to noise in some situations. |
so is what you found consistent with tstevenson's findings? _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
