aaaronw Samba Member
Joined: October 19, 2010 Posts: 57 Location: So. Cal.
Posted: Fri Sep 05, 2014 10:38 am Post subject: 2180 Bus Engine Build |
I've decided to build an engine for my '58 PGSG bus.
This will be my first stroker and I feel like I'm already over my head. My last VW was a '57 oval window that I rebuilt in high school 22 years ago. Things have changed! I grew up in Chula Vista near Pauter's shop and was part of a pretty cool VW community at the time. I know from keeping up on the forums that the community is as strong as ever. That's one of the main reasons I've been itching to get back into a VW for quite a while and so I finally picked up a bus late last year. I've driven it a lot around town and had a lot of fun, but now it's time to put some power in this thing.
I'm not looking to race or do wheelies, I just want some more power with reliability and drivability my main goals. With some help from John at air-cooled.net, I think I've decided to go with a 2180 (82mm x 92mm thick wall P&Cs).
I plan to document my entire build here, and hope to get some advice as I go. I'm sure that I'll make some mistakes here and there, so I really value any input you guys are willing to give.
First decision I need to make is wether to use my old case or buy new. I'm almost certain that everyone here will tell me to go new, but thought I'd ask anyway. Is there any point trying to reuse this case? It's an AS41 from Mexico. I haven't split it open yet, but I did take a close look around cylinder 3 and I don't see any cracks.
Looks like it needs new case savers...
Is it even worth considering keeping? Should I dig deeper and clean it up and see how it looks inside? Or is it a waste of time? |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Sep 05, 2014 10:51 am Post subject: |
First off, sweet bus brother. Secondly, you need to come to an understanding that the safe route would be to buy a new case. After saying that, there's absolutely no reason why you couldnt use your mexi case-after getting it checked out or inspected fully by yourself. Depending on the available ma hine shop sources nearest you, you would be looking at 35$ or so each way for shipping. 60$ for opening bore, 25 est inspection fee (unless this is offered free), linebore if required w/thrust clean est 100$. F/f 35$ and clean and tap galleys 50-60$ optional. So right at 300.$ give or take.
There are nothing wrong with those cases. I have built a few engines in them. Have it cleaned and checked. This seems the cheapest route. Tell them to call u on status before completing any work. I suggest you first check the end play if u possess a dial indicator and mag base or endplay attachment tool. A ghetto quick way would be a depth gage reading to compare differences. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Brian71 Samba Member
Joined: January 22, 2005 Posts: 183 Location: Prineville, OR
Posted: Fri Sep 05, 2014 3:57 pm Post subject: |
Provided that there are no cracks or major defects in that case, there's no reason you can't use it. Even if there are some issues, its just a another piece of metal and as such very workable. If your case savers aren't stripped or cross threaded, theres no reason you can't reuse those as well. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Sep 05, 2014 5:11 pm Post subject: |
If it hasn't been line bored too many times, then there is no reason you can't use that case. Fitting a stroker crank can be a bit of extra work, and I personally wouldn't invest the time or money on anything past 20 over and the first thrust cut, but that's just me. Some guys don't want to build on a line bored case ever. Chevy journal rods will fit much easier than VW, but that has probably been mentioned. Very nice bus! Just joined the bus club myself.. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Fri Sep 05, 2014 10:47 pm Post subject: |
You won't see cracks just by looking at the outside... it must be disassembled and inspected by someone who knows where (and how) to look, inside and outside |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Sat Sep 06, 2014 2:58 am Post subject: |
I don't see anything wrong with the case savers btw. The one in the 3rd photo is the "deep sunk #3" and you can't see that case saver without looking in there with a flashlight. _________________ 1965 Beetle sedan
Click to view image |
Posted: Mon Sep 08, 2014 5:10 pm Post subject: |
Thanks for all the replies. I'm going to break it down and split the case. Brothers VW Machine Shop is close by, so I plan to drop it off there to get it inspected and bored. |
Posted: Sat Sep 13, 2014 3:32 pm Post subject: |
I broke the engine down today and will take the case to the machine shop next week.
Besides the case, what parts should I consider reusing from my old motor? Rods?
Posted: Mon Sep 15, 2014 5:45 pm Post subject: |
I'm trying to put together a parts list and need some advice. Here is what I'm looking at so far:
SCAT Volksracer Crank - 4340 Forged Chromoly - 82mm Stroke - Chevy Rod Journals
Web Cam Type 1 Camshaft, Grind 163, 105LC
AA 92mm Thick Wall P&C Set
ACN Road Warrior Dual Port Cylinder Heads 40 X 35mm
5.4" Forged Chromoly H-Beam Connecting Rods, Chevy Journals, Balanced
CB Performance Super Stock Rockers, 1.25:1
Keep in mind that my first priorities are reliability and drivability. More performance is a bonus, but not critical. To save a bit of money, should I consider:
CB Super Race Crank - 82mm Stroke - Chevy Journals
Norris 330S Crankshaft
Any other advice is greatly appreciated. |
Posted: Mon Sep 15, 2014 6:06 pm Post subject: |
A cb crank will be cheaper than the Scat for sure. For your combo, the CB should be just fine and perform. Remember the more you spread out your vendors, the more shipping that equates. You dont need H beams for this set up. I suggest AA 4340 5.4 I beams.
Buy the crank, flywheel and rockers from CB.
Buy the heads, rods, cam, p/c's, and small stuff thru John at ACN.
Get the rotating parts balanced thru both vendors. imo _________________ 2276 IDA's 86C 11-1 DD !
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Tue Sep 16, 2014 9:23 am Post subject: |
I'm a big fan of John and AC.NET, why not get everything from him?
Check out the Bugpack and DPR cranks, he carries both _________________ 1974 Thing |
Posted: Tue Sep 16, 2014 10:49 am Post subject: |
MConstable wrote: |
Check out the Bugpack and DPR cranks, he carries both |
Even better. I like dpr cranks. It will be a few more dollars for the crank and flywheel combo, but well worth it. Im pretty sure john can get you scat pro comps instead. Dont forget to get it all balanced. _________________ 2276 IDA's 86C 11-1 DD !
The_Troupster Samba Member
Joined: May 21, 2006 Posts: 44 Location: Lancashire, England
Posted: Tue Sep 16, 2014 11:46 am Post subject: |
Stick with the VW rod journal.
Jim _________________ '72 Type 1
'71 Type 2 |
Posted: Tue Sep 16, 2014 3:58 pm Post subject: |
Quote: |
I'm a big fan of John and AC.NET, why not get everything from him? |
John has already answered a bunch of my questions. I'm trying to get whatever I can from him.
Quote: |
I like dpr cranks. It will be a few more dollars for the crank and flywheel combo, but well worth it. |
Looking at John's site, the DPR crank is $320 and the Bugpacks are $350. Just want to make sure I'm not looking at the wrong parts?
Quote: |
Stick with the VW rod journal. |
Can you explain why? |
Posted: Wed Sep 17, 2014 8:05 am Post subject: |
It's stronger (less crank flex). You will have to clearance the 'case a little more and perhaps the cam. But this shouldn't be too bad on an 82mm crank.
'71 Type 2 |
Posted: Tue Sep 23, 2014 2:09 pm Post subject: |
My case is going to Paradise Motorsports this afternoon for inspection.
I have narrowed down my shopping list:
DELUXE Type 1 Stroker Crankshaft, Type 1 Rod Journals - 82mm
ACN Billet Straight Cut Cam Gears, Steel
SCAT 5.394" I-Beam Connecting Rods, Type 1 Journals, 3/8"
ACN Road Warrior Dual Port Cylinder Heads, (L5 heads) 40 X 35mm
SCAT Lightweight Lifters
CB Performance Super Stock Rockers, 1.25:1 Ratio
DPR Chrome Vanadium 12V 200mm Stock Weight Flywheel
200mm Racing Pressure Plates, Economy, “Late” style, 1700lb
Bugpack Chromoly Gland Nut & Washer, 36mm Head
Any comments/suggestions? |
74 Thing Samba Member
Posted: Tue Sep 23, 2014 2:11 pm Post subject: |
Get rid of the Scat lifters and run CBs 2 piece ones. |
Posted: Tue Sep 23, 2014 2:52 pm Post subject: |
Yep.
Can't go wrong with john. Gonna be a nice motor
'71 Type 2 |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Tue Sep 23, 2014 3:17 pm Post subject: |
I agree with the CB lifters, been running them for years with no failures.
For about the same money you can get a set of Steve Tims Heads that are fully ported and run great.
Be sure to check the PC set because most of the AA sets that I have installed were a bit tight on piston to cylinder clearance.
I have had great luck with the thick wall 92's once I fine tuned the bore size.
It sounds like a nice solid engine, enjoy |
