dansivilli Samba Member
Posted: Wed Sep 17, 2014 2:47 pm Post subject: |
Sorry if this is a dumb question - do these work on the rear only? I have a 72 super and bought them as I'll be installing new shoes anyway. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Sep 17, 2014 2:49 pm Post subject: |
Yep--rear only!
Tim |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Tue Oct 14, 2014 5:58 am Post subject: |
Welp. Finished the brakes this past weekend,
After bleeding, and adjusting, and torquring down the nut to specs,
I'm getting a knocking sound in the rear, Which normaly means a out-of-round drum. (maybe machined off center from the spline)
BUT, Im not getting the pulsating pedal that you get with that type of drum/warped drum.
I'll pull it off sometime this week and measure..
Maybe the e-brake is too tight?
_________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Posted: Tue Oct 14, 2014 12:48 pm Post subject: |
Thomas, when I installed my rear Zimmerman's, I adjusted the hand brake according to Haynes (for 1973 on, lift handle 3 clicks, adjust until the wheels barely turn).
That information didn't work well, since my new drums were heating up each time I drove (handbrake not on, of course). So I loosened them up a little.
Even with the handbrake adjusted too tight, however, I got no "knocking" noise. I just happened to notice that the drums were too hot after driving a while--using the index-finger-touching-the-drum-ouch method.
It would be a drag if your reasonably-priced Zimmermans were causing this issue.
You might just have a CV that's acting up.
Tim |
Posted: Tue Oct 14, 2014 12:59 pm Post subject: |
Tim Donahoe wrote: |
Tim |
Ill loosen up my parking brake to 5-6 clicks, then stomp on the brakes to center the shoes, then re-adjust shoes again and hope that fixes it.
all 4 CVs are new, and have less than 5k miles on them.
I Really hope it is.
Since ive:
Changed old worn out pads and drums for: New pads/ New drums, WITHOUT adjusting my parking brake.
SO im pretty sure its "tight" causing one shoe to "clap/slap" around with the drum _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Oct 14, 2014 1:07 pm Post subject: |
back off the e brake cables then adjust the brakes then the e brake cables.
Some times people adjust up the cables with out adjusting the rear brakes as they wear and get things out of sink. Also looks like you might have wear on the spreader bar _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Mudpump Samba Member
Posted: Tue Oct 14, 2014 1:31 pm Post subject: |
Long shot but it doesn't look like you chamfered the ends of the pads. I always do that to reduce squeaking and it also helps if the ends are chipped and/or not flush where they are attached to the shoe |
Posted: Tue Oct 14, 2014 1:37 pm Post subject: |
Mudpump wrote: |
Never had an issue before hand. ends of the pads look nice. High quality pads.
(they pre-fit the drums nicely.) _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
birddog1 Samba Member
Posted: Tue Oct 14, 2014 3:06 pm Post subject: |
I always chamfer the ends,just the way I was taught.
I must say I've been running into some real garbage shoes lately. The last set was I think called Enduro. Pads were chipped and just looking at them made me winch. The pad bonding to the shoe looked like crap.
What brand do people consider good shoes these days? |
Posted: Tue Oct 14, 2014 4:55 pm Post subject: |
birddog1 wrote: |
Wagner thermoquiet. Check the last page of my rebuild thread in my signature below _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Tue Oct 14, 2014 5:00 pm Post subject: |
Update on the issue, After un-hooking the parking brake cables inside the cab to make sure its not causing ANY pressure/tension on the parking brake assembly, I ran back and forth under my car adjusting each shoe until the drum dragged, then ran into the car, stomped on the brakes.
Then ran back, and re-adjust the shoes again and repeated this about 10 times per wheel.
This indicates the parking brake was the cause of brake shoes not being aligned correctly in the drums.
and MAN wow my pedal feels better than ever, and the braking was AMAZING.
However, now, under REALLY HARD braking, I still get that Dull Knocking noise.
I'm going to get a new torque wrench tomorrow, and use it on my Torque master tool (i think my old torque wrench may be damaged) giving me a false reading. So hopefully its really just a axle nut issue. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Wed Oct 15, 2014 8:57 am Post subject: |
birddog1 wrote: |
I got Rayspestos brand re-lined shoes. The price was nice, relined in Canada using proper fitting VW shoes. My Zimmerman drums feel fine so far.... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
BUGGED11111 Samba Member
Joined: February 03, 2006 Posts: 1821 Location: Oregon
Posted: Wed Oct 15, 2014 5:06 pm Post subject: |
birddog1 wrote: |
I recently put a set of Raybestos 392PG on my Super fronts. no complaints. I had similar experience with the Enduro's.
Posted: Wed Oct 22, 2014 2:19 pm Post subject: |
turns out there were high spots in my brand new drums...
I cut them a bit, and the issue went away.
1966 Ghia (sold)
1966 Red Beetle |
talljordan Samba Member
Joined: January 10, 2012 Posts: 968 Location: San Francisco, CA
Posted: Wed Oct 22, 2014 3:03 pm Post subject: |
Mr.Duncan wrote: |
I guess we know why they were so cheap... _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Posted: Wed Oct 22, 2014 3:34 pm Post subject: |
It is not uncommon to have to true up a new brake drum with the way they are packed, shipped, dropped _________________ Rick
tasb wrote: |
sb001 wrote: |
wcfvw69 Samba Purist
Posted: Wed Oct 22, 2014 5:08 pm Post subject: |
Wow, I guess I'll just stick to my original VW drums on my 69!
I was surprised recently to see it had the original drum on the RR along with the original wheel cylinder. I took the drum w/the non-oe drum to be turned and it was still in spec. Got lucky.
Thanks for posting this link Mr. Duncan. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Oct 22, 2014 7:34 pm Post subject: |
I wouldn't make any sweeping conclusions based on one experience.
Nothing wrong with Zimmerman drums. They're about best you will find. I've put many on many cars and had 1 drum that I turned and was a minor clean up. I've also used Brazil drums and they all need to be turned before use. |
