vwracin2win Samba Member
Joined: December 04, 2005 Posts: 363 Location: Palmdale, CA
Posted: Wed Sep 10, 2014 6:17 pm Post subject: Master cylinder question for disk brakes |
i have the cheaper 2 piston disc brakes on the rear of my baja with drum front brakes and a stock type 1 master cyclinder with stock pedal assembly. i bled the brakes and i dont have any pedal it seems like my master cylinder isnt pushing enough fluid to compensate for the dic brakes. just curious if i should be using a larger bore master cylinder or something. could be my master is bad too but i want to make sure i get the right one to replace it. _________________ 69 VW baja 1914
73 F-100 built 302 |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Fltblkbaja Samba Member
Joined: June 24, 2014 Posts: 88 Location: Kelowna B.C
Posted: Thu Sep 11, 2014 5:57 pm Post subject: |
Agreed, if your lucky it needs a little more bleeding, if not new MC. But the MC is fairly cheep and easy to do, let us know what you find _________________ Everyone chops and drops,
We chop and lift!!! |
Posted: Thu Sep 11, 2014 6:43 pm Post subject: |
They will touch the discs but the pedal is almost to the floor with the adjustment push rod from pedal to the master cylinder adjusted pretty close to all the way out. _________________ 69 VW baja 1914
73 F-100 built 302
Posted: Thu Sep 11, 2014 6:47 pm Post subject: |
They will touch the discs but the pedal is almost to the floor with the adjustment push rod from pedal to the master cylinder adjusted pretty close to all the way out. I had it sitting for a couple weeks or so and now it has no brakes at all. Master is most likely bad. Everything is brand new lines, hoses, wheel cyl, disc brake kit, even the master is new. Wouldn't surprise me if it's bad it's happened to me me before but I have never run disc brakes. It just seemed to me I needed a master that would pump more volume? I once heard the bus master cyl is higher volume is this true? Plus it's a little cheaper. _________________ 69 VW baja 1914
73 F-100 built 302
Posted: Thu Sep 11, 2014 6:48 pm Post subject: |
Yeah I'd chuck a new MC in there might be pooched _________________ Everyone chops and drops,
Posted: Thu Sep 11, 2014 6:50 pm Post subject: |
Not sure about the bus MC, maybe ask the bus guys. _________________ Everyone chops and drops,
Posted: Thu Sep 11, 2014 8:30 pm Post subject: |
The thing about disc brakes in comparison to drums, is that the discs do not have return springs to suck the wheel cylinders back in. With disc brakes, they are designed to be pushed out to the disc, and the only thing that pulls the pads away from the discs, is the flex in the piston seals. So the pads only return a very short distant from the discs. Therefore, if everything is correct, MC bleed, etc, you should get a firm pedal before it reaches the floor. Now with dual pistons, the pedal may be a little lower then stock, but you should still get a good pedal. Also, just because the MC is new, doesn't mean it is good. Been down that road before. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Thu Oct 16, 2014 12:36 pm Post subject: |
Started messing.with the brakes again today. Still can not get enough pedal to even bleed. Went around and checked all fittings again to make sure they are tight. I used a rig job vacuum set up and it broke but I got a little pedal then I had my wife give it a few pumps then held it while I let the fluid out and she pumped it again and the pedal never came back up. Wondering if the only way is to vacuum bleed. But then.I wonder is something is wrong with the master so when we pump it it sucks in air. Or maybe it just has a crap load of air in the system from not bench bleeding and it being a new system. _________________ 69 VW baja 1914
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Thu Oct 16, 2014 5:11 pm Post subject: |
You need to bench bleed it. You'd be surprised how long you can bench bleed it till all the air is gone. I don't u sees tans why people don't think it's nessecary and wonder why their brakes don't work. _________________ foam cowboy hats aren't good helmets. |
Posted: Thu Oct 16, 2014 6:00 pm Post subject: |
I just noticed it looks like some of the paint is eaten away a little right under where the master goes through into the car. Wonder if I should try bench bleeding or just get a new master. _________________ 69 VW baja 1914
Posted: Thu Oct 30, 2014 7:12 am Post subject: |
Just wanted to update this thread. I put a new bus master in it and bench bled it and everything's perfectly and the brakes work great. Hard to say if it were the new master or the bench bleeding. I'm thinking a little bit of both. Thank you to everyone for their advice and help. _________________ 69 VW baja 1914
