c.ruber Samba Member
Posted: Thu Sep 11, 2014 4:15 pm Post subject: So you run zero deck.... |
So I'm having a bit of a dilemma. When I first built my engine I set the pistons and cylinders up for zero deck. I had to tear down the top end of my engine to correct a cylinder with low compression. I had all the cylinders honed for new rings and the pistons cleaned up. I'm mocking everything up and I have a problem with #3. I've swapped around pistons and cylinders and cylinders and pistons....still have the piston sticking out of the cylinder. Not much at all, but enough to feel when rolling the crank over to check the deck with a deck plate. Maybe at the most it's .002" I'm running a set of .045" copper head gaskets to get the compression ratio I want. I don't want to risk the piston smacking into anything...So what to do?? Should I take the piston to a known flat surface with some wet dry paper and gently remove enough of the face to make the clearance right (also considering the balance of the piston if it would be enough of a change to effect the balance)? Or should I find a machine shop to machine the face of the piston and rebalance the other pistons to match? Thanks for the input... _________________ ...and progress is not intelligently planned... |
Posted: Thu Sep 11, 2014 4:18 pm Post subject: Re: So you run zero deck.... |
List the #s of all 4 cylinders; the deviation is what you are looking for. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Thu Sep 11, 2014 4:24 pm Post subject: |
Could also swap to .050 gaskets on that side, or replace rod bushing to have the rod shortened a few thou.
Or just run it. .040 won't hit if it's really .040 |
Posted: Thu Sep 11, 2014 4:33 pm Post subject: |
I'm a little concerned about expansion at running temp with the piston sticking out of the cylinder even that small amount... Am I crazy? _________________ ...and progress is not intelligently planned... |
Posted: Thu Sep 11, 2014 4:36 pm Post subject: |
It doesn't matter if the head gasket is bigger than the piston on the ID. I have run .028" clearance to 8k RPM.
Alternatively you can run a .060" gasket and move forward. _________________ It's just advice, do whatever you want with it!
I'm not sure I'm following what you are trying to tell me John... I've swapped the pistons and cylinders all around and am still having the same issue on that particular cylinder spigot on the case. I'm thinking the case has given way a little since I first assembled the engine some time ago due to wear. _________________ ...and progress is not intelligently planned... |
Posted: Thu Sep 11, 2014 4:37 pm Post subject: |
Did you check the case spigot deck prior to assy? _________________ It's just advice, do whatever you want with it!
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Sep 11, 2014 4:38 pm Post subject: |
On my performance engines I get the deck within .001" of each other, then rebalance. Sometimes you have to get creative _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Thu Sep 11, 2014 4:41 pm Post subject: |
John, I had the case decked when I had all the machine work done prior to initial assembly. The case has a few years of weekend beating on it. I'm not sure how to check the cylinder spigot at this time... _________________ ...and progress is not intelligently planned... |
modok Samba Member
Posted: Thu Sep 11, 2014 4:44 pm Post subject: |
c.ruber wrote: |
Am I crazy? |
yes and no. I've said the deck gets slightly tighter over time, you agree now?
the case expands more than the piston with heat. I think it will hit cold at high rpm if it ever does.
Put some .003 shims(soda can) under the plate and see if it clears then.
.040 won't hit. less can work, but good place to draw the line. |
Posted: Thu Sep 11, 2014 5:02 pm Post subject: |
re-check the case deck NOW. Sure it was close a few years ago, but that's not doing you much good now. Check it!
Once you know, these guys here will give you several solutions to fix it right, quickly. Samba guys are sharp! _________________ It's just advice, do whatever you want with it!
Posted: Thu Sep 11, 2014 5:18 pm Post subject: |
OK John... How do I check the case? _________________ ...and progress is not intelligently planned... |
Posted: Thu Sep 11, 2014 5:35 pm Post subject: |
[email protected] wrote: |
Once you know, these guys here will give you several solutions to fix it right, quickly. Samba guys are sharp! |
Don't know about that, some days I feel as sharp as a bowling ball! _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Fri Sep 12, 2014 8:51 am Post subject: |
If I opt to remove some material from the face of the piston, how much of a difference in weight would require me to rebalance the pistons? _________________ ...and progress is not intelligently planned... |
mark tucker Samba Member
Posted: Fri Sep 12, 2014 9:10 am Post subject: |
what john is saying he has run .028 with no issues. I run .033 with no issues. some people run .08o" with issues...... you may try another set of shims as there may be a varriance of .002 or more between brands/batches. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Fri Sep 12, 2014 9:59 am Post subject: |
c.ruber wrote: |
OK John... How do I check the case? |
Here is my no-precision-tools way.
First make certain the adjacent cylinders are the same length and put them in the case. Make sure they are well seated.
Now place a straight-edge across the tops of the cylinders. If the straight-edge makes contact at all four points and the cylinders are the same lengths, then the case deck is at the same levels on that side.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Fri Sep 12, 2014 10:12 am Post subject: |
Max Welton wrote: |
c.ruber wrote: |
Max |
Yup! And if it doesnt hit somewhere, feeler gauges work great to measure the difference |
Posted: Fri Sep 12, 2014 11:26 am Post subject: |
That works for me.... I'll recheck that. Thanks. _________________ ...and progress is not intelligently planned... |
Posted: Sat Sep 13, 2014 9:27 am Post subject: |
be sure the cylinders are down good and not on bent shim,stud thread,casesavor etc. you should still have some way to hold them down to check this.also be sure there isant any burr or interfearance in any way that might hold one up. |
