brs1997 Samba Member
Posted: Thu Sep 11, 2014 8:22 pm Post subject: baja's in the snow?? |
i have been i always wondering are baja bugs good in the snow? i have heard yes's and no's but mostly yes's. so i figured i would ask it here! thank you in advance! |
Brian Samba Moderator
mrbajadude Samba Member
Joined: July 12, 2002 Posts: 148 Location: Yerington, NV, home of the VORRA 300 mile off road race
Posted: Thu Sep 11, 2014 8:31 pm Post subject: |
If you haven't baja'ed in the snow, you don't know what you're missing. So much FUN. _________________ Panic, Chaos and Disorder, My work here is done! |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
dustymojave Samba Member
Posted: Thu Sep 11, 2014 11:36 pm Post subject: |
http://www.thesamba.com/vw/forum/index.php
I know there isn't much snow under the tires in this pic, but it was taken to show how deep the snow was. The bulk of the day and night were spent on uncleared trails. Tire chains help.
Well I suppose this post will have to wait until either photobucket or the Samba Gallery wants to earn their keep. Right now neither one is working. _________________ Richard
SoCalBajas Member
Mexicant Samba Member
Joined: December 31, 2010 Posts: 99 Location: Colorado
Posted: Fri Sep 12, 2014 6:55 am Post subject: |
The problem I've had in the snow is not enough weight in the front. A lot of times it'll just plow forward instead of grabbing. Goes good with just all terrain tires tho |
sloboatnova Samba Member
Joined: September 20, 2009 Posts: 989 Location: Broken Arrow, Ok
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
sicksforeveedub Samba Member
Joined: August 28, 2008 Posts: 68 Location: Central CA
Posted: Fri Sep 12, 2014 11:56 am Post subject: |
Ever wonder how the snow plow driver gets to the snow plow? _________________ "...What, like the back of a Volkswagen?" |
Posted: Fri Sep 12, 2014 1:22 pm Post subject: |
There it is _________________ "...What, like the back of a Volkswagen?" |
Ian Samba Moderator
Posted: Fri Sep 12, 2014 5:06 pm Post subject: |
My buddy's car goes great in the snow. Driven it no problem in two feet of fresh powder. Drop rear PSI to around 10 and you're off.
http://www.thesamba.com/vw/classifieds/detail.php?id=1560252 _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
bugdewde Samba Member
Joined: November 11, 2006 Posts: 77 Location: East Tennessee
Posted: Sat Sep 13, 2014 11:18 am Post subject: |
Mostly, yes.
As mentioned, depends on tires..... and snow type.
Powder is usually pretty easy... it's more like sand.
Wet snow is more slick.
Ice is.... well, ice.
So each really depends on your tire air pressure and tread design.
I've had a LOT of fun in the snow with my VWs/Bajas.
Plowing the front tires is pretty easy, just like any other type vehicle in snow. Light front end combined with brakes equals front wheel lock-up and front end slide.
So, driving style also comes into play. Slower turns, to keep from plowing the front tires and enhance the turn with some rear steering by applying some more throttle...... FUN! It's just like off-roading. |
bgs Samba Member
Posted: Sat Sep 13, 2014 11:26 am Post subject: |
Lol,,I tried it up in Big Bear with my old 69. Went ok
until I high sided on snow pack with the pans, frame
horns and tranny engine bottoms.Had the dog with me
who was freaking out a bit when we came to a sudden
stop. and I do mean SUDDEN ! It was like hitting
a big old pool of cement.
I had to get out and dig as much
snow out from under the ride as I could, then I jacked
it up so I could place wood limbs and rocks under the tires so
when I backed up the pans, etc would be free from the
snow as much as possible. Took me about an hour to
get out and all I had on were some jeans, a t-shirt, and
some bedroom slippers.
The ride was raised up a bit and was running
31 x 10.50-15 Cooper Discover SST type tires.
So if you're going play in the snow, bring a GOOD
shovel, a GOOD jack, and make sure there's lots of
dead branches and rocks around to help get ya out. _________________ Hmm, ruff.
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5411 Location: Holland, MI
Posted: Sun Sep 14, 2014 5:56 pm Post subject: |
Where I live we get lots of snow each winter. This past winter we had 338+ in of snow. Very hilly here too. It's funny, if you are not familiar with 6-8in of snow each night, the cars you may expect to do great actually suck. Pickup trucks are freakin' worthless on the hills unless you put a few hundred lbs of ablest in the bed. A snowmobile or atv in the bed is just about right. Jeeps are another surprising one, they work ok in the flat ground but don't drive worth a hoot on any hills. Subaru vehicles are awesome. Great traction. Some 2wd front drive cars are ok as well. Manual transmissions are good. Automatics are aweful hard to control. Snow is awesome fun if you learn to drive in it. Believe me when I say it has more to do with how you work your feat and the steering wheel, and less to do with the tires you have. As long as your tires aren't balled, it doesn't really mater what tires you have. Big mud tires can sometimes be problematic if it gets slushy, but not to bad.
A kid up here drives a baja bug around from time to time. It takes the hills great. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Sun Sep 14, 2014 6:20 pm Post subject: |
bgs wrote: |
I had to get out and dig as much snow out from under the ride as I could, then I jacked it up so I could place wood limbs and rocks under the tires so when I backed up the pans, etc would be free from the snow as much as possible. Took me about an hour to get out and all I had on were some jeans, a t-shirt, and some bedroom slippers. |
That's why I don't leave home without one of these. Just make sure that you keep a bit of oil on the hinge and the locking wheel. Otherwise it will rust up on you.
_________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Tue Sep 16, 2014 11:02 pm Post subject: |
I've dug many tons of snow with a US Army folding shovel like that. The newer versions don't work near as well. I bought mine at a surplus store in the early 70s. It was wrapped in brown waxed-on-the-inside paper with military jargon M-1 or whatever the number was, shovel, bivouac-folding, and was dated "1943". Mine came with the canvas holster. The snap on the holster broke many years ago and my friend put velcro on to replace it. But I've carried it in each of my offroad vehicles over the years and used it many times. I like how you have yours mounted in that Baja Multi69s.
This is one of the pics I was going to post above, but Photobucket and the Samba Gallery weren't cooperating at the time.
Later that nite, we were heading for home and passed over a place where there was a concrete cross drain for a wash to cross the dirt road we were following. The concrete drain is 4' deep with fairly steep banked sides. The surface of the snow was level and we did not realize we were at the cross drain until after we stopped. We were sitting on top of 8' of drifted snow and the tires had nothing but snow to push against. It was well after dark when the car stopped and we dug with that little Army shovel until the tires were sitting on snow thin and hard packed enough to get traction on. We tossed the snow over the left side of the hole down the steep wash bed. When I finally got in to drive the car out the "ramp", the snow beside the car was way higher than the roof of the Baja. In the stone dark we had shoveled a couple of dump trucks worth of snow to get it out. A winch might have helped if we had buried the spare tire in snow deep enough to pull against. _________________ Richard
SoCalBajas Member
Bad Hippie Samba Member
Posted: Wed Oct 01, 2014 7:07 pm Post subject: |
Heck! Only problem I had with my baja in the snow was all those people with their 4wd's getting in my way. Got to the point where I was looking for deep stuff to plow into so I could get stuck. |
Ed Chenal Samba Member
Posted: Wed Oct 01, 2014 8:37 pm Post subject: |
A few years ago, I was in Death Valley with some other folks and we drove up into the snow. The folks that did the best had BFG All Terrains on their Buggies and Baja's . The rest of us just slid around.... I had Mud Tires on at the time but they didn't help me much. |
