rcproductions Samba Member
Posted: Fri Sep 12, 2014 11:24 am Post subject: Transmission does not shift into 2nd or 4th???? |
I have a manx meyers dune buggy on a 1969 beetle frame. I have 1968 motor and drivetrane. I have a standard "H" shift pattern with reverse push down and to driver and back. What does it mean when I can shift into 1st and 3rd, but not into 2nd and 4th? I should note that it has been poping out of gear (mostly 2nd) for the last 2 weeks. When I shift into position for 2nd or 4th, it is as if it is in nuetral and just revs. |
Brian Samba Moderator
Posted: Fri Sep 12, 2014 11:33 am Post subject: |
Either your shifter lock out plate is worn down, the hockey sticks are broken in the nose cone, the nose cone is cracked or your nose count mount is damaged. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Fri Sep 12, 2014 1:19 pm Post subject: Re: Transmission does not shift into 2nd or 4th???? |
rcproductions wrote: |
Also some type of linkage or adjustment problem. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Fri Sep 12, 2014 3:05 pm Post subject: |
Your shift rod in the tunnel is too long. Nothing in the trans is in common between 2 and 4th. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Sep 12, 2014 4:42 pm Post subject: |
mcmscott wrote: |
Your shift rod in the tunnel is too long. Nothing in the trans is in common between 2 and 4th. |
Except the are both in pull back position... Check adjustment of shifter, might try loosening it up and nudging it forward a bit ... Yes forward because it moves pivot point to where it pulled shift arm(fork) in trans further into gear...
Also might have shift coupler failing or broken trans mount (either nose cone or rubber mount) as mentioned above...
Posted: Fri Sep 12, 2014 5:18 pm Post subject: |
Dale M. wrote: |
mcmscott wrote: |
Dale |
Exactly. The rod is too long, so the shifter cannot move it FOWARD enough. Remember the rod goes foward for 2, 4 and reverse. Typically reverse will not use as much throw as 2 or 4. Also this is a shortened manx, so some one had to shorten the shift rod as well. Probably not correctly _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Fri Sep 12, 2014 6:58 pm Post subject: |
On ever buggy I build I take axact measurements and ALWAYS put a adjustable end on shift rod to ab-solutely avoid problems with shift rod angle and length...
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Fri Sep 12, 2014 8:56 pm Post subject: |
If it worked before, then it there is something wrong with the linkage. Remove the shifter to look at it and to check the shift rod bushing. Look at the coupler for the tranny. Check the tranny mounts to see if they broke. |
mark tucker Samba Member
Posted: Sat Sep 13, 2014 9:04 am Post subject: |
I would say the joint is dead. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Sat Sep 13, 2014 9:07 am Post subject: |
mark tucker wrote: |
I believe there are pills for that... |
