George Stimson Samba Member
Joined: April 04, 2011 Posts: 54 Location: California
Posted: Sat Sep 13, 2014 4:55 pm Post subject: Mystery gas line blockage, '64 Beetle |
So I finish the six to twelve volt conversion on my '64 Beetle and go to start it up -- and I'm getting no gas back at the engine (specifically, none coming out of the metal line that goes into the cloth line to the fuel pump). I took the tank out and replaced the cloth line from the tank to the metal line and gas is flowing through that just fine. I put compressed air through the metal line (rear to front) and it seemed to be totally clear. So what could the problem be? (There's about two gallons of gas in the tank.)
I hope I don't have to replace the metal line, as it looks like getting that thing through the tunnel is a real tough job.
Any help is appreciated! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Sat Sep 13, 2014 5:09 pm Post subject: |
That's odd.
Here's one little trick I do when I get vapor lock on my 62 - I lightly pressurize the gas tank by blowing (just by mouth!) into the vent hose, then plugging it off with a small Phillips screwdriver... you might try that and see if you get any flow then |
Posted: Sun Sep 14, 2014 2:39 pm Post subject: |
Nobody yet? Okay, here's my new theory: The car is parked at a slight angle downward in the front. With only two gallons of gasoline in the tank there's not enough gas for it to rise over the highest point of the metal fuel line where in comes out into the engine compartment. If I add a few more gallons of gas it should raise the level enough that it makes it over the high point of the line and into the fuel pump. Sound logical? |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Sun Sep 14, 2014 2:56 pm Post subject: |
I suppose your theory could be right but did you try what Andy suggested? You can try either moving it or jacking it up to get it level. Or, you could try putting some suction on it at the back end somewhere. |
Posted: Sun Sep 14, 2014 3:38 pm Post subject: |
Andy's trick didn't do it. I'll put some more gas in it (after I'm able to go to a gas station tomorrow) and try it again. |
kingsfanrob Samba Member
Joined: December 24, 2007 Posts: 126 Location: San Dimas
Posted: Sun Sep 14, 2014 4:53 pm Post subject: |
Make sure the new line at the tank isn't kinked. |
Posted: Sun Sep 14, 2014 6:47 pm Post subject: |
You could also try taking it loose underneath the car and see if you get any flow there. I happen to have my fuel line filter installed there - where it exits the body underneath before going to the engine.
Posted: Mon Sep 15, 2014 10:25 am Post subject: |
Well, I added three gallons of gas and that didn't do the trick. There's still no fuel coming out of the metal line in the engine compartment. I guess the next thing to do is examine the area referenced by Big Dog. |
vdubmyk Samba Member
Joined: October 24, 2008 Posts: 508 Location: Corona, CA
Posted: Mon Sep 15, 2014 12:16 pm Post subject: |
Remove the fuel line at the pump and pressurize the tank by removing the cap, forming a seal with your hand and blow gun attached to an air compressor. Fuel should start to run out of the hose. Once it does, hook the line up at the pump and squirt some starter fluid into the carb and crank the key. On mine, it didn't start to "suck" gas to the carb until the car started to run, I'm assuming it helped undo the airlock. _________________ 64 stock bug, 12V (converted 6v unit), 40 hp, all documents even sales contract and dealer window sticker! |
buggin65 Samba Member
Joined: April 14, 2011 Posts: 70 Location: Conejo Valley
Posted: Mon Sep 15, 2014 7:19 pm Post subject: |
I think fuel filters should always be on the pressure side of the line after the fuel pump and before the carb, obviously. You don't want to have to "suck" through a dirty filter. It is much better to "push" through a dirty filter just until you can change it. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Sep 15, 2014 8:31 pm Post subject: |
kingsfanrob wrote: |
What happened when you heeded this advice? Just replacing this line and turning your (boy I sure hope regasketed while in there!) fuel pickup tube a few degrees can cause a kink here.
The pressure of three gallons of gas alone is enough to push fuel through to the engine bay. Remove the gas cap- and unhook your fuel line from your pump and suck the line- easy peasy. Ever syphon gas before? Piece of cake. _________________
EverettB wrote: |
FU#5 |
Posted: Mon Sep 15, 2014 8:48 pm Post subject: |
I can reach in and feel it. It doesn't feel kinked. |
WD-40 Samba Member
Posted: Mon Sep 15, 2014 9:03 pm Post subject: |
bigdog1962 wrote: |
Might be time to clean the transmission? _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Posted: Tue Sep 16, 2014 4:51 am Post subject: |
*Hijack alert***
I've since cleaned the transmission - got to get another pix.... |
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Tue Sep 16, 2014 12:44 pm Post subject: |
Do you have a compressor? If so, disconnect the line after it comes out of the body and push air up to the gas tank and see if you get bubbles. You may also have to crimp the line under the gas tank and disconnect that line from the body and see if you can get air blowing the other way. I had the same issue and it was sediment that got blocked in the line but compressed air got it out. I bet you have a blockage in the line from all the tinkering. It may be an air bubble but I doubt it.
Did the line work prior to being disconnected? _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
cory464 Samba Member
Joined: November 25, 2010 Posts: 659 Location: kokomo in
Posted: Tue Sep 16, 2014 3:50 pm Post subject: |
pull the tank, snake a thick piece of weedeater line through the fuel line in the body. you will be surprised how much comes out. also, jack up the front and look at the hose. coming out of the tank, any kinks? |
Posted: Wed Sep 17, 2014 6:52 pm Post subject: |
"Did the line work prior to being disconnected?"
The car was sitting for a few years before I started working on it. When I disconnected the line to install the new fuel pump, nothing came out of it. The tank seemed practically empty (but the gauge needle was still in the reserve area). Before that the car wouldn't start, so I don't know how well the line was working. |
hitest Samba Member
Posted: Thu Sep 18, 2014 8:44 am Post subject: |
Holy shit that changes everything. As I loosely quote from you, "so I finish the 6 to 12 volt conversion and go to start it up," sounds like it ran one day and didn't the next! You sir need to give your car an enema and maybe consider providing people who try to help you with all the information. You owe everyone an apology. _________________
EverettB wrote: |
FU#5 |
Posted: Fri Sep 19, 2014 11:50 am Post subject: |
Hitest is angry but details do help.
My suggestion is to take everything off that is a flex tube and either put a line in the metal line(weed eater line) and make sure they are clear and verify the flex lines are clear also. You also need to clear the tank of fuel and wash it out (don't use water). verify that rust has not started i nthe tank also. High probility your tank is fouled and sludge has settled. Setting for a while can cause all kinds of issues. Let us know when you have verified that all the individual componts allow fuel to run freely. Start at the tank and move back. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
dantrefethen Samba Member
Joined: April 28, 2004 Posts: 729 Location: Boise Idaho
Posted: Fri Sep 19, 2014 3:55 pm Post subject: |
If your car has been sitting for several years:
Replace all the rubber fuel lines.
Clean your tank. Chain lengh and kerosene.
Replace the copper sock in the fuel tank.
Get a power drill and some old trottle cable, or similiar wire, and run it
front to back.
Read this
http://www.thesamba.com/vw/forum/viewtopic.php?t=606650&highlight=fuel+line
Should be clear now.
Dan |
