augestwest Samba Member
Joined: June 28, 2013 Posts: 49 Location: portland oregon
Posted: Sun Sep 14, 2014 1:53 pm Post subject: braking noise |
so i have what sounds like a speedometer cable noise, but is not?
only happens when braking!
is coming from under driver seat!
i have replaced wheel bearings and seals!
have rebuilt calipers and new pads, all parts are there(shims)
new shocks!
and removed speedo cable!
and it makes a clicking sound when braking?
had wife pinpoint noise to be coming from under driver seat?
"master cylinder" ? maybe?
no leaks all hoses in great shape
help _________________ 73 bay
71 beetle |
1967250s Samba Member
Posted: Sun Sep 14, 2014 2:19 pm Post subject: |
You said the speedo cable is out and you still have the noise? Check the bearings on that side carefully, as they are new. They often loosen up a little. You could raise the left front and rotate the tire and listen. |
Posted: Sun Sep 14, 2014 2:25 pm Post subject: |
noise is the same as before the new bearings, only makes noise when braking,
tried it on jack stands but it wont make noise as no momentum for the brakes to slow down they just lock. _________________ 73 bay
71 beetle |
Posted: Thu Sep 18, 2014 1:25 pm Post subject: |
so i was reading about a proportioning valve in another post and i think that might be the sound i hear. is that a replaceable or rebuildable part? _________________ 73 bay
71 beetle |
SGKent Samba Member
Posted: Thu Sep 18, 2014 4:13 pm Post subject: |
look for a crack in the rim. Try it with the hub cap off to see if it is clicking. Won't be the proportioning valve. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Sep 20, 2014 7:43 am Post subject: |
No cracks, but on inspection of rear brakes ,found drums to be past specs. So I will replace them and see if that helps. _________________ 73 bay
71 beetle |
