Bohdan Samba Member
Joined: November 21, 2007 Posts: 143 Location: Venice, Florida
Posted: Mon Sep 15, 2014 5:52 am Post subject: What if I pulled a spark plug wire while it is running.. |
Greetings Fellow VWers'.
I have a rough idling Thing and in theory it idles as if it is running on three cylinders. So I take off the spark plug wire off of number 1. No difference. I take the plug wire off of 3 no difference. But if I take it off of 2 or 4. It basically dies. I checked compression and it is a bit low on one. I tested spark and I get spark. I got even new plugs. One thing I didn't check was timing. What do you think is the issue? Any help would be appreciated. Have a Great Day! |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 212 Location: Norristown, PA
Posted: Mon Sep 15, 2014 6:23 am Post subject: |
When you say cylinder 1's compression is low, how low? Like 10 lower than the rest, or 40 lower than the rest?
If you consider only the spark plugs as a culprit, my guess would be cylinder 3 is the one not firing.
If you look at it systemically, it sounds to me like a timing issue caused by a worn rotor/distributor, or a cracked distributor cap. |
Bohdan Samba Member
Posted: Mon Sep 15, 2014 8:39 am Post subject: |
Cylinder one is 135, 2 is 150 3 is 145 and 4 is 155. but it must be both since the engine revs don't change. Thinking about it, maybe I switched 3 and 1 at the distributor cap? How stupid would that be? I should check that. |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Mon Sep 15, 2014 12:52 pm Post subject: |
Bohdan wrote: |
Yeah, check that.... Very easy to do... These buggers will run on 2cylinders.... Drove my'73 Bug on Okinawa that way for a week while I was trying to figure it out... Had a fresh set of eyes take and look and the first thing he did was trace plug wires and found them swapped.. I was too involved and "obviously" checked that already.... _________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
SilverThing Samba Member
Posted: Mon Sep 15, 2014 5:44 pm Post subject: |
I got my Thing up to 45mph running on two cylinders once! I was flooring it in third gear, but still... Very easy to get wires backwards. _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Bohdan Samba Member
Posted: Tue Sep 16, 2014 4:54 am Post subject: |
Interesting enough. It wasn't switched spark plugs. I switched them anyhow to see what would happen. Definetely runs better the way it was originally. I tweaked the timing and runs much better. However, if I still pull the plug wires, still no difference. Weird.... |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Tue Sep 16, 2014 5:03 am Post subject: |
Check for a vacuum leak on a gasket or hose. You can use propane on med/low through a rubber hose and aim it around all the connections. You will need to clear the air once in a while. If there is a vac leak the rpm will increase instantly until you remove the hose |
60GULFVDUB Samba Member
Posted: Tue Sep 16, 2014 7:58 am Post subject: |
What carburator(s) are you running? It will do that with some single throat dual carbs , but clears up at higher rpm. |
Bohdan Samba Member
Posted: Fri Sep 19, 2014 5:14 am Post subject: |
I got a single 40IDF. I am definitely going to get somebody elses opinion on this too. See if they see what I see. Maybe I am gojng nuts. thx |
