boston63boston63 Samba Member
Posted: Mon Sep 15, 2014 7:33 am Post subject: need some guidane. |
I own a 63 beetle and recently purchased a used 1300cc engine that has been converted to 12v with a 12volt fly wheel and clutch kit.
I was wondering if some one could guide me to buy the right throw bearing as i believe my old one won't work with this pressure plate.
I know i need a new sarter and i'm just going to get a 12 v starter and i was wondering if any one new of a company that sells a 12v swap kit minus the alternator. I need the bulbs and relays.
thanks you so much for your time
PHIL |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Mon Sep 15, 2014 8:28 am Post subject: |
That doesn't look like a 12v (200mm) clutch. Could be one of those Bus flywheels. "6v center (180mm) with a 12v ring". Early style T.O. bearings work with that center ring. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Sep 15, 2014 8:39 am Post subject: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=148307
Read thru here for clutch info
And if you are changing to 12 v
http://www.thesamba.com/vw/forum/viewtopic.php?t=233946
get a auto stick starter then you don't have to mess with the stater bushing _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
