dcheek Samba Member
Posted: Mon Sep 15, 2014 1:12 pm Post subject: Window Won't Go Up! |
2006 Jetta
Passenger front Window went down, now won't go up.
- Tried from Drivers side switch
- Tried from Passenger side switch
- Tried with key in Drivers door to roll up all windows and set alarm.
All the above did not raise the window.
Put on scanner and got the following codes:
00933
01035
What do they mean?
Before I rip it apart, any tips? Much appreciated.
Dave _________________ 1961 Bug
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1981 Diesel Rabbit Pick Up
1982 Diesel Vanagon
2014 Golf (last year German mfr for NA)
2019 Jetta Gli, 35th Anniversary Edition, 6 speed |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Mon Sep 15, 2014 8:14 pm Post subject: |
Does the back lighting in the switches on the door still work? The most common failure is a wire or 2 breaking inside the ribbed boot between the body and the door. It's possible to patch the harness, but a real pain to work in those tight quarters. The lasting repair is to replace the door harness. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
dcheek Samba Member
Posted: Tue Sep 16, 2014 3:57 am Post subject: |
With the information from PS 2375 and 73sports (thanks Bill) I will start to investigate. I will report on my findings. Thanks guys.
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
dcheek Samba Member
Posted: Tue Sep 16, 2014 6:52 am Post subject: |
73sports wrote: |
Does the back lighting in the switches on the door still work? The most common failure is a wire or 2 breaking inside the ribbed boot between the body and the door. It's possible to patch the harness, but a real pain to work in those tight quarters. The lasting repair is to replace the door harness. |
All back lighting on the switches work. I'm going to try replacing the switch to see if that works.
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
dcheek Samba Member
Posted: Wed Sep 17, 2014 4:21 am Post subject: |
Replaced the switch and that wasn't the problem. I brought the car to Foreign Car Werks in Bound Brook, NJ. Jeffrey, the mechanic, proceeded to find the problem- a broken wire in the passenger door that fried the motor. A new motor from VW is on order and will be replaced next week. In the meantime Jeffrey raised the window so I can still use the car until then. Thanks guys!
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
VolkswagenVMan Samba Member
Joined: September 25, 2003 Posts: 186 Location: Valparaiso , Indiana
Posted: Wed Sep 17, 2014 11:08 am Post subject: |
The rubber boot between the a pillar and the door where the wires go through, open the boot and check the wires to see if the wires have broken from normal use of the door. Its a common problem with the Mark 5 Jetta. _________________ Master Tech at Team Volkswagen
VW's at work , VW's at home!!!!
1967 EMPI GTV
1966 Bug early
1966 Bug late
2000 New Beetle 2.0l 200,000 miles and going! |
dcheek Samba Member
Posted: Thu Sep 18, 2014 10:16 am Post subject: |
VolkswagenVMan wrote: |
The rubber boot between the a pillar and the door where the wires go through, open the boot and check the wires to see if the wires have broken from normal use of the door. Its a common problem with the Mark 5 Jetta. |
Wires were all good in the boot. There was a broken wire behind the door panel.
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
Posted: Thu Sep 18, 2014 11:28 am Post subject: |
Did that fix the window? _________________ Master Tech at Team Volkswagen
1967 EMPI GTV
1966 Bug early
1966 Bug late
dcheek Samba Member
Posted: Thu Sep 18, 2014 2:20 pm Post subject: |
Did that fix the window? |
Fried the motor. Had to order a new one. I will install next week and let you know if it works.
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
