53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Mon Sep 15, 2014 2:57 pm Post subject: D Regulator |
Anybody in here re-build six volt D regulators? I understand it can be done, but I don't have the knowledge to do it. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
bwaz Samba Member
Posted: Mon Sep 15, 2014 3:12 pm Post subject: |
not exactly close to you, but these guys would do it. Rebuilt my original generator and it works great.
http://www.aersltd.com/en/ |
Loren Samba Member
Posted: Tue Sep 16, 2014 7:15 pm Post subject: |
Thanks! Does he only do solid state re-builds? _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Wed Sep 17, 2014 12:11 pm Post subject: |
Original regulator contacts (the vibrating contacts that eventually wear to nothing) are not available anywhere that I am aware of, and believe me I looked. There is some detail on which contact this is and how to inspect them in the Zarwerks Spy Cam thread.
If you find a shop the "rebuilds" them, make sure you ask what they do and how they replace worn contacts. 90+% of the dead ones I have had may hands on have worn-to-nothing contacts. It is kind of sad because the regulator was designed to have this contact/reed replaced with removal of a single screw.
Likewise, if you considering purchasing a "worked when taken out" regulator, make sure you inspect this contact, and do the resistance checks mentioned in the Spy Cam thread. I see dead regs selling for $250 and up now.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Suboval Samba Member
Posted: Wed Sep 17, 2014 1:18 pm Post subject: |
Loren suggested him as well...........I was concerned if he could re-bulid it "stock" of if he converted them over to solid state.
I'll call him when I get back into town. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Wed Sep 17, 2014 1:28 pm Post subject: |
Rick "outsources" the rebuilds and they are solid state conversions. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Wed Sep 17, 2014 1:50 pm Post subject: |
johnshenry wrote: |
Rick "outsources" the rebuilds and they are solid state conversions. |
This is the way I thought I had to go. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Thu Sep 18, 2014 6:43 am Post subject: |
Here you go Bob.
Quote: |
Posted: Tue Jan 08, 2008 8:14 am Post subject:
The D Regulator was by far the hardest thing for me to find for my Split ... I finally found one at the Vintage Treffen (a core unit I was told for 40.00)... I actually spoke to the gent you referenced John who retro-fits them with new hardware (chips)... but 275.00 seemed a little out of whack.
I did a quick search and found a Master Rebuilder of Generators and Voltage Regulators.....
http://www.acewichita.com/index.html
Guys name is Glenn Cheaney.. and frankly he is amazing..I sent him my 6/52 Generator and my new acquired "core" Voltage Regulator.. and he rebuilt them both!! Part of the service is to perform all the balancing between the Reg and Gen... which he does with original 60's rebuilding machinery... Took about 10 days and I had it back!!
http://www.acewichita.com/06_vintage.htm
I know.. this should be in the buyer and seller feedback.. but I think in many instances rebuilding a Regulator will work.
He rebuilt my Regulator and Generator for 275.00.... and frankly, my lights are brighter than I have ever seen on a bug.... Generator runs barely warm to the touch. I chose to have him NOT re-plate my gen. case and parts, just bead blast them as I didnt want a shiny generator standing out on my "survivor" style engine. However, this service IS included in his rebuild package..
I would personally prefer a real regulator than a chipped one.... but I can tell you this.... if John had 100.00 chipped regulators available when I was looking.. I would have bought one!!
I didnt even know you COULD rebuild regulators.. the guys at my local Gen. shop laughed at me when I asked.
http://www.thesamba.com/vw/forum/viewtopic.php?t=271780 _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Posted: Thu Sep 18, 2014 7:45 am Post subject: |
Suboval wrote: |
Here you go Bob.
http://www.thesamba.com/vw/forum/viewtopic.php?t=271780 |
Thanks Kurt................still chipped, but I guess that's it, unless any of you guys have a good extra one you want to sell. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
*Darren Samba Member
Posted: Thu Sep 18, 2014 8:14 am Post subject: |
FWIW, I contacted Glenn @ Ace in 2013 to have a thin slot rebuilt - he stated he no longer works on Bosch. He referred me to Dan Smith @ DPS in Ashby, MA who rebuilt my thin slot. I believe he does VRs (since I run a later square, didn't need a VR done), you can check with him. |
Posted: Thu Sep 18, 2014 8:52 am Post subject: |
Thanks, I'll check with him. My generator is great................it's a just a slave to the burned up regulator. I can re-build the generator. I really need a new regulator. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1272 Location: Lamorinda CA
Posted: Wed Oct 08, 2014 9:04 am Post subject: |
This is correct. Glenn Cheaney no longer does any VW or Porsche stuff as he said its just "far too boring" and that he can make more money on the older Detroit stuff.. He is also out of the store of original parts he had stashed and so he isn't offering those services.. Now.. if you have like a 35 Packard one you want rebuilt... I bet he can help.
He cursed me for putting his name in these forums as he was innundated with work for a couple of years... one person sent him like 8 D regulators!! He is semi retired, and I'm happy to say I got his last Porsche work... a beautiful quality 912 12V he is making for me.
Great guy, Amazing stories, You could spend hours talking to the guy.... One of those quality workman we just don't see as often anymore. _________________ DB
9/1950 Hoffman Standard
11/1966 Porsche 912
10/1966 Porsche 912
7/1968 Type 265 Double Cab
10/1958 Type 117 |
Posted: Fri Oct 10, 2014 6:32 am Post subject: |
53 0val wrote: |
Thanks, I'll check with him. My generator is great................it's a just a slave to the burned up regulator. I can re-build the generator. I really need a new regulator. |
If you find Dan Smith does those, and especially has reg parts, let me know. Ashby is about 45 mins from me, would be worth the drive out to chat..... _________________ John Henry
'57 Deluxe
'56 Single Cab |
