joshuabiles Samba Member
Joined: November 23, 2007 Posts: 81 Location: Turner Oregon
Posted: Mon Sep 15, 2014 7:27 pm Post subject: 73 baha headlights one works then I hit the high beams |
So only one of my head lights is currently working(on the drivers side). Until I hit the high beam switch then it switches. My other head light works an now my current one no longer does Whats my problem any info or help would be great for a fast solution. Thanks |
Brian Samba Moderator
Posted: Mon Sep 15, 2014 7:32 pm Post subject: |
1. Is it plugged in
2. Is there a fuse
3. Is the filament still good _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Tue Sep 16, 2014 4:49 am Post subject: |
I've had this happen with two good headlights while I was rewiring. I can't tell you exactly where the problem is but all you need to do is follow the wiring diagram while tracing the wires on your car. I'll post up one I use for my 70. Hopefully it is close. There should be two wires coming off the fuse block with terminal connectors on the end to hook two headlight leads too. One is a white wire other is yellow. One high beam one low. You prolly have one high lead and one low lead hooked into the low from the fuse block and the same thing with the high lead from the fuses. Or a wire is loose in both these connectors and not making contact.
_________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Fri Sep 19, 2014 10:54 pm Post subject: |
Thanks it was simple replaced the bulbs problem fixed. |
