ule Samba Member
Joined: September 16, 2014 Posts: 30 Location: catalonia
Posted: Tue Sep 16, 2014 4:45 am Post subject: Help!!new engine 1679 perfo!! |
Hi all,
I have some questions about the new engine we're doing.
It is a 1679 with 88 AA pistons with a tree 110 On "ignitor1" pertronix. with dual Weber carburetion 40
CB pump full flow
All this in a T2A crew cab, 67 '
I have a too high pressure! 7 Bar, as I can download it?
That should work pressure, minimum and maximum?
That should get compression? To have a good performance and is reliable?
I was thinking of changing flywheel lightened by one? you think? should then mount poised ciguaņal?
help
thank you |
ule Samba Member
Posted: Tue Sep 16, 2014 4:51 am Post subject: |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13843 Location: White Mountains Arizona
Posted: Tue Sep 16, 2014 7:13 am Post subject: |
What is all of the welding on the muffler? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Sep 16, 2014 9:36 am Post subject: Re: Help!!new engine 1679 perfo!! |
What oil pump and oil are you using? _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
ule Samba Member
Posted: Tue Sep 16, 2014 10:26 am Post subject: |
The pump is cbperformance full flow with in/out
The oil is 20/50 mineral
The temp. ext. 28°c |
ule Samba Member
Posted: Tue Sep 16, 2014 10:32 am Post subject: |
Welding is silent because open and clean all the plugs. Now is free exhaust |
Posted: Tue Sep 16, 2014 10:37 am Post subject: |
change oil to 10-30 or 5-30. _________________ It's just advice, do whatever you want with it!
ule Samba Member
Posted: Tue Sep 16, 2014 12:48 pm Post subject: |
Original by cb pump change because I had low pressure problems. Besides I have mounted radiator and Farm external filter. 20/50 is perfect for my weather conditions. -15 / 35. It is possible to have a problem with the oil bypass spring? |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Tue Sep 16, 2014 2:12 pm Post subject: |
Yes, it is possible you have a problem with a spring, or a stuck valve. When are you getting 7 bar? Hot, cold, idle? You could easily get 100psi at revs when cold using 20W50. By default the CB filter pumps come with 30mm gears. With that in mind you could switch to 15W40 or even 10W30 in your climate, but I suspect this is not the root cause of your problem.
We can make better guesses if you can provide more information about what is happening. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Tue Sep 16, 2014 2:43 pm Post subject: |
That is a great ride. I love it. Stay with the stock weight flywheel. Heavy car, heavy wheel. Light car, light wheel. I too would switch to 10/30 oil. |
ule Samba Member
Posted: Tue Sep 16, 2014 3:02 pm Post subject: |
thank you,
7 bar was cold at 1500rpm
then hot (only 70 / 80ēc oil temperature) to 4bar perhaps under 1500rpm ... but if ascended to 3000 / 3500rpm up more + 5 bar ...
I could only prove that, another tube problem in the engine and tube be removed. my question So if it was the bypass valve or could be...
thanks!! |
