kreissig Samba Member
Joined: May 30, 2009 Posts: 105 Location: Costa Mesa, CA
Posted: Tue Sep 16, 2014 6:55 am Post subject: Proper Antenna placement question? |
How I bought it:
The holes seem a bit close together - as well as out of round. What is the proper distance between the holes?
1961 _________________ Auch aus Steinen, die in dem Weg gelegt werden, kann Mann etwas schoenes bauen. - Johann Wolfgang von Goethe |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Sep 16, 2014 7:24 am Post subject: |
antenna's were dealer or owner installed so it could be anything/anywhere.
do a site search, plenty of threads on this. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Tue Sep 16, 2014 7:50 am Post subject: |
Agreed, search the threads and figure out which kind of antenna you like, as well as the placement, and go with that. I have seen them placed together and apart, also straight up and down as well as angled back. _________________ Plate of shrimp |
stale air Samba Member
Joined: August 23, 2007 Posts: 5151 Location: Senoia Ga, formally NorCal
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Sep 16, 2014 2:34 pm Post subject: |
The only "proper" location.... is the one you like... or are stuck with thanks to a Vw dealer..
Dual mounts look the best...
but...
Looks more like fat holes for for a single mount..
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=ZVW6
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Sep 16, 2014 9:00 pm Post subject: |
I have an antenna like the one stale air pictured, but the holes were close together, like yours. I was in for a tear down and repaint anyway, so I welded the lower hole shut, and used a step bit to drill a new hole further down. You could try the one like volkswagenut pictured and see if it matches your existing setup; it looks pretty close. I prefer the two-mount, but that antenna would look fine.
This is the dual mount with 7.5 inches between centers, oriented vertically.
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Wed Sep 17, 2014 8:19 am Post subject: |
kreissig, that location looks perfect, and like something that was done originally at the time of sale in US. I like the pass. side location for the antenna.
Looks like the single-mount antenna will fit right in there and was there before someone put in an older style double-mount one at one time. |
