Irvinec32 Samba Member
Posted: Tue Sep 16, 2014 7:22 pm Post subject: Did I connect the wires right to my coil? |
Stupid me forgot to mark the colored wires before I disconnected the old coil.
The left side is + and the right is -
Thanks!
_________________ 78 convertible |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Tue Sep 16, 2014 7:33 pm Post subject: |
On the + (#15 terminal) side you should have the :
black incoming ignition wire that provides 12v+
black output wire that powers the choke and idle cutoff solenoid
black output wire that goes to fuse holder and reverse lights
On the - (#1 terminal) there should be the green wire from the points/condenser. If you have a tachometer, it will also connect here. Nothing else should connect here or it will short the ignition circuit.
There might be a diagnostic wire that connects here, but since the diagnostic plug is no longer used it is not needed. _________________ AshMan40
Posted: Tue Sep 16, 2014 7:40 pm Post subject: |
Thanks! I think it is correct then. _________________ 78 convertible |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Sep 16, 2014 7:59 pm Post subject: |
ashman40 wrote: |
On the - (#1 terminal) there should be the green wire from the points/condenser. If you have a tachometer, it will also connect here. Nothing else should connect here or it will short the ignition circuit.d. |
fuel injected do also have an extra wire on the negative low tension side which runs to the ECU _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Tue Sep 16, 2014 8:16 pm Post subject: |
Running rough with the new coil. Anyone know if the ecu needs time after the coil is replaced? _________________ 78 convertible |
missourimark Samba Member
Joined: December 01, 2013 Posts: 111 Location: Tennessee
Posted: Fri Sep 19, 2014 4:39 pm Post subject: |
Ashman you say later models had a diagnostic wire to the negative side of the coil. My 73 standard has a white with green tracer wire connected to the negative side would this be the diagnostic wire? |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
