alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Wed Sep 17, 2014 5:05 pm Post subject: 2004 jetta with broken key |
Hey there. I have an 04 jetta. Somehow my wife broke the switch blade. No damage to any other part of the key fob. With a little research i found that i can purchase just the upper half of the key fob that contains the metal switch blade portion. It is a blank and has to have the grooves machined in it. I contacted a locksmith in anchorage who says he can do that. Is it correct that only the bottom half of the key fob needs programming? So is there anything wrong with this plan? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Sep 17, 2014 6:20 pm Post subject: |
Depends on what part the "pill" is in for the Imobilizer. Been a while since I have had to look at a key for one of those. |
VolkswagenVMan Samba Member
Joined: September 25, 2003 Posts: 186 Location: Valparaiso , Indiana
Posted: Thu Sep 18, 2014 11:29 am Post subject: |
The key will have to be programmed to the car. The Immobilizer chip is in the flip key half. Only the remote is in the bottom half. _________________ Master Tech at Team Volkswagen
VW's at work , VW's at home!!!!
1967 EMPI GTV
1966 Bug early
1966 Bug late
2000 New Beetle 2.0l 200,000 miles and going! |
ps2375 Samba Member
Posted: Thu Sep 18, 2014 1:57 pm Post subject: |
In the past, I have been able to swap the blade, you just need to remove small roll pin to do the swap, but it sounds like you need more than just the blade swapped. |
