ChrisFred Samba Member
Joined: June 11, 2014 Posts: 322 Location: Boulder, CO
Posted: Wed Nov 19, 2014 9:31 pm Post subject: |
Wonderful craftsmanship! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Thu Nov 20, 2014 2:32 pm Post subject: |
Yeah, besides the tenacious hankering, super attaboys for all the upsidedown and overhead head scratching, fitting, welding, and grinding. |
esde Samba Member
Joined: October 20, 2007 Posts: 5967 Location: central rust belt
Posted: Mon Nov 24, 2014 11:09 pm Post subject: |
Too many projects in the shop to turn it around today, but I at least got it puller away from the wall enough that I could start on the back. It's a bit more work that I realized. Filthy dirty from the torsion housing back, so first pull the trans. All 4 nuts on the front mount are rusted tight, and some hack mechanic welded the drivers side reduction box to the spring plate
after I broke the welds loose
The trans is really, really filthy.
It's getting a straight axle swap, so the trashed box doesn't matter. I'll pull the diff and intermediate housing to see if the trans needs a rebuild, after it gets power washed..
Hard to see, but the back has been hit pretty hard in the past
The inner luggage are panels are buckled, and the tire well is now trapezoidal
There's this pressure gauge, hanging from a loop of copper that runs to the engine bay. You just have to wonder..
I pulled the fuel tank, and it is the only part of this bus that's pristine. Apparently it was being heavily guarded by lots of mice
Here you can see where the luggage floor was buckled
The hinge carrier is trashed as well, as is the driver side pillar
Oh, and my shop light
To move forward, I've decided to replace both rear corners all the way to the belt line, the hinge carrier, and the drivers side rear pillar, so another order to Klassic Fab has been made. I'm not sure how to straighten the inner rear luggage side panels, and spare tire well. It may be best to carefully cut it out, straighten, clean, and then weld it back in.. a lot of work. Next though, tarp and sandblast the rear, and prime the underside.
SD |
esde Samba Member
Posted: Mon Dec 08, 2014 12:03 am Post subject: |
chopped a bunch out of the rear in anticipation of the new corners and pillars arriving. The tracking shows they're in Philly, should have them tomorrow. As I was taking it apart, I'm seeing it was hit pretty good, and it's going to be a big more than I wanted to get it straight. Here's the first cut
look closely you can see the rear pillar is pushed in
It's been cut open and hacked back together
look closely, the vertical support from the luggage floor to the wheel tub it bent..
Ugliness
I didn't hold much hope that this inner panel could be salvaged, but I had to at least try. Here's as much effort as I was willing to put forth
It actually was doing something
But then it started to pull stuff I don't want it to, so it will have to go
I got a rusty, but straight corner with the bus, and salvaged the part from it.
I'll start cutting the old part out of the bus, now that I've been able to see how it's welded on the donor panel. Man that thing is hemmed in there..
Got the trans cleaned. The case has a lot of corrosion and pitting, and I think it might be best to replace it
The first set of fulcrums was ok
The second set was shot, and the axle trashed
And that side gear was seized in the differential. Great.
Nothing to lose, so I tear it down
And press out the side gear which is cracked in three places
I've taken the gear stacks apart, and everything looks nice. I'll replace the syncros, and the 1-2 slider maybe as it shows signs of a rough life. Had to make a wrench for the pinion nut. I love making tools, especially when someone wants to charge me a mint for something simple. It's even better when I can use crap I have sitting around, better still if I can recycle old car parts..
Here's the nut
And the tube I found that is PERFECT to make the socket. Ironically it's from the front beam of a friends car, chopped out when I narrowed it 4".
Notched
Sketch the wrench body
Ta da
In action. I used a trashed slider hub in the vise, and slid the pinion in to hold it
Waiting on some parts from Geno, Long, and Berg to put it all back together. I tore apart another bus trans, that was in shit condition, but had a good diff.
And lastly, some windshield frame repair
The standard rust on a standard bus, getting chopped out
the Auto Craft repair piece after fitting
And the inside. I'm going to get the inner repair done, using the new outer as a guide.
I'm on the hunt for an entire rear luggage floor, to replace from the hinge carrier to the back seat. Pictures suggest that they are the same up to 71, though I will have to salvage my tire well to re use, if I find a bay window bus to donate metal. Next to cut out the old floor, and sandblast what's left!
SD |
Stocknazi Samba Member
Posted: Mon Dec 08, 2014 5:40 am Post subject: |
Nice work on the trans nut tool. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
esde Samba Member
Posted: Mon Dec 15, 2014 11:25 pm Post subject: |
burning the night oil..
drilling spot welds to free up the rear side panel
I've got an air drill, nice for this job, and a few different bits. The right bit is an 8mm spot weld cutter and works great. It would be better if it didn't leave an 8mm hole. The pilot point bit on the left, works well IF you can find and center it over the weld.
Here's the wrinkled floor without all of the crap in the way
I may have found a replacement, fingers crossed
The rear pillars are a little different from the original
Here I'm comparing new left to old right, but you can see the difference. I've emailed the supplier about the difference, but no reply yet
Did get these chunks in the mail. 2 days from Columbia to my place, wow!
Hung a corner to make it look more like a bus. I think it's going to be important to fit the corners with the floor, as it all ties together. And then pray the hatch still closes..
Moved on to the drivers side B pillar and mid wall pillars. Oh and the inner rocker
Working on the B pillar
Patch on the inside
One of the mid pillars. They are a bit thin and hard to weld
Backing the weld up with a scrap of copper sheet works wonders. It makes a great heat sink, and keeps the weld from falling out
Here's #3
I had looked at Ken Shapiro's pics where the panel wasn't lining up with the pillar. The profile on these wasn't perfect, so I made sure to match the contour to the outside skin, and let the inside fall where it did. One is a bit proud of the original pillar inside, I built it up with weld and blended it.
Finally dropped both floor pans in and promptly loaded it up with shit
And more tomorrow. Procrastinating the sandblasting, but it has to happen sooner or later.. |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
Posted: Tue Dec 16, 2014 5:10 am Post subject: |
Awesome Seth.
Really appreciate you sharing all of these details. I went out to the garage to work on the single cab last night and decided to shut off the heat and watch netflix instead. You've motivated me to get out there tonight. Also, really appreciate the details of the rear puzzle pieces since I should be at that stage in early 2015 after I wrap up front end and outer rockers. Keep on keepin on. _________________ Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
esde Samba Member
Posted: Wed Dec 17, 2014 11:32 pm Post subject: |
Found a rear floor clip, but no time to look at it till after Christmas, so I'm focusing on the other end of the bus. Plus, the nose of the bus is right in front of the heater..
Continuing with the passenger side windshield frame repair. The flange that retains the windshield rubber is two layers. My Auto Craft piece replaces the outer layer, the inside layer is actually the edge of the dash, so I got started repairing that.
patch needed
Patch clamped, copper backing
Tacked
Ground
Repeat, over and over
After it got ground flat, cleaned, and primed with weld through primer, The repair piece was drilled with for welds, and clamped in place. The Clekos made this job so much neater than if I had just used pinch clamps
Completely welded. Finding the right voltage was a bitch, I had to really fight one corner that wanted to burn through no matter what.
And after grinding with the 2" roloc discs. I absolutely LOVE these things for grinding small welds
And finishing the real pain in the ass spot, that is right in front of you, where the rubber will meet the dash
I got the little christmas tree shaped carbide burr for my die grinder. It doesn't come to a point, but a really small rounded end.
really the perfect tool for the job
I imagine the driver side will go a bit faster, now that I have figured out a system, but still it is tedious work. I estimate this side was about 7-8 hours total.. |
BarryL Samba Member
Posted: Thu Dec 18, 2014 11:47 am Post subject: |
That right there is some mighty impressive work. I admire the effort and applaud your progress. |
esde Samba Member
Posted: Thu Dec 25, 2014 11:56 am Post subject: |
A few minutes for an update after a Christmas nap..
Took the plunge and cut out all of the bad sheet metal
The driver side engine "D" pillar is beyond salvage
The passenger side is a little better
The angle of this brace shows how far everything had been pushed in
Also, broke out the sandblaster and made a damned mess. A lot of pitting, but fortunately everything you see is solid
The black is rust neutralizing paint, I use it after sandblasting to treat the areas where pitting makes complete removal unlikely
After that messy job was over, I decided to work on something clean, and got back to the transmission. Tookm the old differential, which had an exploded side gear and was trashed, and made a tool to measure ring gear center to pinion gear
Essentially bushed where the cross shaft would fit down to 5/16" to accept a mini metric indicator. Measuring the diff is the hardest part
In place, minus side cover #2
Also with the indicator to determine differential side shim total
More later, someone just brought out fresh cookies.. |
esde Samba Member
Posted: Sat Dec 27, 2014 9:41 pm Post subject: |
Christmas gift for the project: a nicely salvaged rear luggage floor section
Major thanks to samba member poptop, who had been hanging onto this, and made a deal to help me along with my project
Very little rust, aside from surface rust. It's not a walk through section, so no tire well, but it does have seat belt brackets!
I'll see about straightening my tire well, or finding another, or making one..
but first I'll get this blasted clean, and drill out a zillion spot welds to get it lined up. Also made some headway on the transmission. Got the mains haft and pinion shafts assembled
I was feeling pretty good about the job, after setting the shims for correct gear free play, and then I realized that I left off the pinion bearing retainer flange.
Doh!
Back to the press, at least it gave me a chance to clean everything one more time
I'm hoping to get them installed into the the intermediate housing tomorrow, so I can get the shift forks adjusted, and free up my bench. I need it clear so I can get started freshening up an engine for this mess.
SD |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
esde Samba Member
Posted: Sun Dec 28, 2014 8:02 am Post subject: |
brettsvw wrote: |
Great job saving a bus that most would have cut up for parts. |
Yeah, it sure does seem like I've replaced just about everything at this point. I'm really hoping to get into an earlier 13-15 window someday and figure this is a good trial run if nothing else. Worst case scenario is that I have a nice, totally solid 11 window to enjoy. Best case is that I find my dads old zebra strip 58 panel, it's maybe still hanging out behind a barn in south east Pa somewhere. |
esde Samba Member
Posted: Fri Jan 02, 2015 10:35 pm Post subject: |
Either the cold, or the holidays have slowed me down a bit. Fortunately my assembly bench is down in the basement, so i could work on the trans when there wasn't time to head over to the shop
Gear stacks in the intermediate housing
I chopped the original case to use as a shift fork jig. Here it is being used. Note the reverse relay lever. Every picture I've seen shows a stamped one, this looks cast or forged
Into the trans case with it. I used a chopstick in one of the holes for the pinion bearing retainer to align it with the shim and case holes while I shoved the whole thing together, worked like a charm.
Figured out what shims gave me the proper back lash on the ring gear, got a big ol assortment from Long, plus some I had
Marked the gear to check the pattern
It looked good, you'll have to take my word for it as I had yellow compound on my hands and didn't take a flick.
in
closed. I used some three bond on the gaskets, as I hate leaks
This is the stock 4.37 ring gear with all stock gears, no RGB's. I had wanted to hold out to find a 4.12, but the early ones are scarce. I hope it drives ok with my 1835. Hell, I hope it works, period.
Lengthened some axle tubes to go with the long spline-long axles last month. Just put the boots on and pressed the short ends on
Now it's ready to haul over to the shop, install the axles and type 3 brakes. Only thing I might change is swapping on a new bus nosecone from Rancho so I can add a reverse light.
Back to the body. Drilled out many, many spot welds, and checked to see that the new luggage floor section would actually fit into the bus without taking it further apart. Thankfully it does, barely.
if only it was a walkthrough floor..
took it back out and started stripping it down. No sense installing it any way other than rust free and clean
and that is where I left it tonight. There are a few spots where the pitting is deep, and I'm concerned about getting the rust out and stopped. Might actually go old school with some naval jelly on those spots, before priming the underside and getting it ready to install. |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Sat Jan 03, 2015 6:13 am Post subject: |
You guys in the split forum are incredibly skilled and talented. Awesome work. _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
wrenchnride247 Samba Member
Joined: August 17, 2010 Posts: 251 Location: Cleveland, TN
Posted: Sat Jan 03, 2015 8:56 pm Post subject: |
esde wrote: |
This is the stock 4.37 ring gear with all stock gears, no RGB's. I had wanted to hold out to find a 4.12, but the early ones are scarce. I hope it drives ok with my 1835. Hell, I hope it works, period. |
You are doing an amazing job! But, what size tires will you be running? That 4.37 will have you screaming in 4th to do 70mph. That's with a 195/65/15. _________________ SPL
'62 SC 69x90.5 SP TI
'70 T1 84x105 DP T4 |
esde Samba Member
Posted: Sat Jan 03, 2015 9:28 pm Post subject: |
70? hahaha
I will be happy to manage a reasonable rpm at 60. My thoughts were to run a slightly larger tire in the back, like a 205/65/15, but I haven't even looked to see whats involved to fit them. Or thought about wheels. I started a set of 16x5.5" smoothies based on wide 5 beetle wheel centers for my bug, and I was thinking they might be right for this. Actually, I have longer range plans that involve putting a stroker crank into an 1835 that I have, megasquirt, and a stronger trans with different gearing to match, but that's for next winter. If this one isn't ideal it won't upset me too much, rarely do I find something to be exactly to my liking the first time around. As fate would have it most of the parts for a different 4.12 trans sort of popped up, and I'll just sit on it till I need it. Right now I'm just gunning to get it welded together and primed to drive out of the shop this coming summer. believe it, money has been bet on it. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Sat Jan 03, 2015 11:25 pm Post subject: |
205/65/15 are not larger than stock, just wider _________________ regards
Uli
esde Samba Member
Posted: Sun Jan 04, 2015 9:44 pm Post subject: |
Soaked the floor in phosphoric acid for a bit, neutralized it, sanded again, and epoxy primed.
In place and somewhat fitted
As I had suspected, everything was scrunched forward a bit. I ended up using some large bar clamps to push the sides back some, maybe a 1/4"
Starting to see how it is all going to line up
SUre feels nice to just have something there
Welded up some holes at the flange that holds the tank spout. Felt strange welding with the mig gun shoved in the filler door
And then I found the strange part. The sloped section, behind the seat back, where it meets the wheel well is curved at the outer corners
And because the wheel well insn't curved, it pushes the part up and creates a wrinkle. The part I cut out was already bent badly and honestly I didn't pay a ton of attention when I was removing it. So, what is the story behind the difference? It seems like the wheel well would have to curve down at the rocker for this to fit. I'm sure I can cut it straight and make it fit, but it's driving me nuts trying to figure it out..
Anyway, to move forward, I'm going to clamp this all in place, and then get the rear corners fit next. There are a few welds on the corner panel upper edge that will be best to do with the luggage floor removed, but of course I need the floor in to help line up the corner. Never easy right? Also, got a nice year end deal on a new mig machine, Miller multimatic 200
200 amp wire feeder, runs on 110 or 220 volts, got the spool gun, also does DC tig and stick. My Esab MM260 does all of the same, but it's 250 pounds and hardly portable, and needs some repair. The new machine is 38 pounds with a 10 pound spool loaded! I'm loving it! |
Daniel G Crazy Amish Guy
Joined: April 23, 2004 Posts: 828 Location: Central Alabama Amish Country
