bigjl71 Samba Member
Posted: Fri Sep 19, 2014 11:24 am Post subject: Please help from anyone familiar with '74 Super Beetle? |
Hello everyone, I have another issue I need some help with on my '74 Super. There is a wireing harness under the back seat that runs from the drivers side to the passenger side, it contains 3 wires which are a brown wire with a white stripe, a plain brown wire, and a yellow wire with 2 red stripes(one on each side). Can anyone tell me what these are supposed to go to, and do they need to be hooked up? Thanks for any insight anyone might have... |
sb001 Samba Member
Joined: May 19, 2011 Posts: 10399 Location: NW Arkansas
Posted: Fri Sep 19, 2014 11:35 am Post subject: |
They're just wires that went to your factory diagnostic terminal plug, probably no longer in the car. They are of no consequence, might want to tape up the ends or whatever just in case but it's fine. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Fri Sep 19, 2014 11:43 am Post subject: |
Thank you sb001, I've already had all the nightmares with the wiring in this thing that I ever want to have, so I'm sure glad they don't matter... maybe you can tell me what the little square relay is under the back seat on the drivers side also? I'm still having problems getting my tail/brake/turn signals to function like they are supposed to so I'm trying to make sure not to overlook anything that could be an issue... |
sb001 Samba Member
Posted: Fri Sep 19, 2014 11:48 am Post subject: |
bigjl71 wrote: |
Little square relay should be your rear window defrost relay. You should have a constant 12v power coming in from the battery, a switched power lead coming in from the switch on your dash, a wire going up the rear pillar to the rear window, and either a ground wire or it could just be bolted to chassis which would also provide the ground. _________________ I'm the humblest guy on this board.
1600 SP engine
