splitpetersen Samba Member
Joined: August 04, 2014 Posts: 21 Location: Prince George British Columbia
Posted: Tue Oct 14, 2014 8:39 am Post subject: |
Way better after the wash, lol. Almost looks drivable. OK, not even close. I will post pics after work of the troubled spots, prepare for lots of pictures. |
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Tue Oct 14, 2014 2:10 pm Post subject: |
I did the front floor, lower dog legs, etc. first so I could drive her without doing a Fred Flintstone. Then I did the cargo side rockers, outriggers, jack points, outer floor, etc. Now I'm on the long side. When I finish that all that's left is the battery tray! Little by little and eventually it's all done. _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Thu Oct 16, 2014 11:55 am Post subject: |
I can totally see why getting it moving and stopping would help to keep the rest of the build motivated. But I think I can strip it and rebuilt it with enough motivation.
Another question, is it worth saving any window rubber or seals, I would imagine these things are readily available. And the headliner, has a tear. This will not be a restoration, in terms of a total original factory rebuild, but rather a cool, safe bus to cruise around in. |
Posted: Thu Oct 16, 2014 6:31 pm Post subject: |
Heres a roof shot
Posted: Thu Oct 16, 2014 6:35 pm Post subject: |
Should this look like this, or has a lapped repair been done at the windshield?
Posted: Thu Oct 16, 2014 6:37 pm Post subject: |
I posted a bunch of pics in the standard micro bus section of the gallery, under gregs 67 project. |
GTV Samba Member
Posted: Thu Oct 16, 2014 8:09 pm Post subject: |
Windshield area is correct. _________________ EMPI Power Rules! |
Posted: Thu Oct 16, 2014 9:50 pm Post subject: |
OK, glad its supposed be like that. |
Posted: Sun Oct 19, 2014 9:59 pm Post subject: |
Well, got her all gutted and engine pulled. Roughly lined up and tweeked door alignment so she would button up tighter for outside storage for a bit. Shoulder checked the major dents out of the roof. At least water wont puddle.
Posted: Sun Oct 19, 2014 10:06 pm Post subject: |
Gotta love the previous repairs, tar sheetmetal screws lol
Posted: Sun Oct 19, 2014 10:14 pm Post subject: |
Death by dust......maybe.
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Sun Oct 19, 2014 10:46 pm Post subject: |
it looks like a decent start. being a walk through is nice too.
can I make a suggestion as someone who is currently learning sheet metal work. before you start trying to shrink bits on your car get some crappy old panels and learn on them. as I have just found out, trying to learn on a car you want nice isn't the smartest way. thankfully the car I'm learning on is just a 90's runabout and only needs to be functional (because it certainly won't be as nice as I intended ). |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Mon Oct 20, 2014 3:41 am Post subject: |
That's a pretty solid bus! Congrats on the Find. I know that restoring one is not a easy task but I was there once, particularly last year when I personally restored by split bus. But as you go along you will come to realize that how exciting and wonderful to restore a split bus. Keep us posted!
Thanks,
Dong _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
Pinetops Samba Member
Posted: Mon Oct 20, 2014 4:00 am Post subject: |
The floors have some rust but they don't look that bad from the pics, got any pictures of the frame rust? (edit: just saw some in your gallery) That all looks fixable to me. It's going to take a lot of work but that bus is worth saving. _________________ "A rolling bus gathers no rust." |
Posted: Mon Oct 20, 2014 5:19 am Post subject: |
The roof section is damaged with considerable depressed area. However, it can be fixed with the proper skills to be applied and a bucket of patience it can be brought back to its former glory. Hope to see the progress of your restoration... _________________ '67 KG Cabrio (Mickey) ;
'72 Type 2 Homey
'67 Splitty Bus
Posted: Mon Oct 20, 2014 10:33 pm Post subject: |
Im thinking of starting with the cross members and main frame rails first. Then the outriggers and other floor supports. Moving onto inner rockers then floor sections? Sound like a reasonable order to attack it?
I'll be fabricating a 1/4 turn rotisery to make welding much easier. And im hoping to safe some costs by producing some pieces myself, have acces to a well equipped sheet metal shop.
As far a glass removal, cut the old seals? They're faily weathered. |
543fold Samba Member
Posted: Mon Oct 20, 2014 11:51 pm Post subject: |
DONGKG is correct, the roof can be fixed....
I fixed this 23 window roof damage without pulling the headliner. Since you're able to access both sides, it should somewhat easier.
Good luck with the build!!!
_________________ https://www.instagram.com/w.a.r._wills.auto.restoration/
______________________
....even the rust has rust!
How "NICE" do you wanna spend?
W.A.R.
Will's Auto Restoration |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1220 Location: Eerie PA
Posted: Tue Oct 21, 2014 4:58 am Post subject: |
Pick up the book titled "The Art Of Metal Bumping" its an old book used to teach auto body and available through Amazon pretty cheap.
I went from this.
To this without removing the headliner or damaging the OG paint by using the information in the book.
Still a few little spots left, but I feel its a good compromise to avoid damaging the OG paint.
Warning the book is a bit on the dry side so read while enjoying a good microbrew. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
