Iguana Samba Member
Posted: Tue Sep 30, 2014 2:46 pm Post subject: |
Tube was 1 1/2 as Joe said.
Pin is used over bolt as it can't fall out, is easy to visually inspect, has a flat side to get in close and it is on or not no half solution or mistakes.
Peening has failed so many times I wouldn't consider it a good option. Out of the last 6 buggies I have had on the lift none of them had pivot bolts that were tight and 3 of them had washers installed incorrectly. I never thought it was such an issue but it certainly seems to be.
You can still use 1/2" tools to get it out it does not interfere at all.
Safety wire has also failed to many times to bother and needs to be done correctly by someone with the correct wire and tools. Use wrong wire and it will give you a false sense of security.
I use to do the 17mm hex inside the head with a small tab as suggested by Joe but then I had a car which has seen beach work and the hex bar rusted into the pivot bolt and end result was that we had to cut the bolt out, never again. |
jsturtlebuggy Samba Member
Posted: Tue Sep 30, 2014 3:11 pm Post subject: |
Here one on a project I am working on.
As you can see there is room for a 1/2in tool and ratchet.
This a setup KarTek sells for retaining the pivot bolt.
_________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
jrailer Samba Member
Posted: Tue Sep 30, 2014 3:37 pm Post subject: |
how is this got it done
Posted: Tue Sep 30, 2014 3:54 pm Post subject: |
hay joe your ratchet is broken |
Iguana Samba Member
Posted: Tue Sep 30, 2014 6:21 pm Post subject: |
jrailer wrote: |
Looks good |
Posted: Tue Sep 30, 2014 8:12 pm Post subject: |
You need to get those photos up iguana |
Posted: Tue Sep 30, 2014 10:00 pm Post subject: |
jrailer,
Yes the lever is broken and has fallen out. A #1philups screwdriver works for changing direction on the ratchet until I can get to a Snap-on dealer. _________________ Joseph
Elrod Motorsports
Iguana Samba Member
Posted: Tue Sep 30, 2014 10:56 pm Post subject: |
jrailer wrote: |
Sorry man I missed your response with all this Pivot Bolt stuff but I see back on Page 1 you said cool to post ....
Incoming |
Iguana Samba Member
Posted: Tue Sep 30, 2014 11:09 pm Post subject: |
I think it is being picked up Thursday. |
herkster Samba Member
Joined: February 14, 2013 Posts: 428 Location: Boca Raton, FL
Posted: Wed Oct 01, 2014 5:47 am Post subject: |
looks good! get to work! |
Posted: Wed Oct 01, 2014 7:29 am Post subject: |
sweet ya I got told Thursday for pick up it should get to me Friday or Saturday |
Posted: Wed Oct 01, 2014 2:32 pm Post subject: |
update now its oct 11 for delivery |
vincent9993 Samba Member
Joined: November 09, 2006 Posts: 2025 Location: Montreal
Posted: Wed Oct 01, 2014 2:35 pm Post subject: |
jrailer wrote: |
Don't despair, the best Dune Buggies are build from kits delivered on Oct 11... j/k. Can't wait to see the unboxing video! |
Posted: Wed Oct 01, 2014 2:43 pm Post subject: |
ha ha thanks for the laugh its still better than the November date Winnie gave me in the first place |
dbsmith Samba Member
Posted: Wed Oct 01, 2014 7:35 pm Post subject: |
GREAT COLOR _________________ dbsmith
SoCal
#127 Manxter - 99.5% done.... |
Posted: Wed Oct 01, 2014 9:40 pm Post subject: |
Is there enough room for a single 40 carb under the deck on a manxter I don't want to run dual carbs and don't really want a progressive |
Posted: Sun Oct 05, 2014 4:59 pm Post subject: |
well it has been one month to the day
still waiting on rear brakes and spring plates I did get heater holes welded up
still waiting on body this weekend |
Posted: Sun Oct 05, 2014 5:05 pm Post subject: |
couldn't do the gold calipers
Posted: Fri Oct 10, 2014 7:11 pm Post subject: |
Big day tomorrow. What did you get done this week? _________________ dbsmith
SoCal
manxvair Samba Member
Joined: January 11, 2011 Posts: 231 Location: Arizona
