emu88 Samba Member
Posted: Mon Sep 22, 2014 1:15 am Post subject: Sprint star torque |
I have a set of Ssp sprint stars, but what torque should i use on the nuts? _________________ 03/1971, 1302 Super Beetle 1600 dual port
Solex 34-pict 3
SVDA Bosch distributor
Long reach heads |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Sep 22, 2014 8:40 am Post subject: |
Very tight with a 1/2" breaker bar. You will probably need a cheater pipe for the 1/2" breaker bar to get them off. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Mon Sep 22, 2014 11:23 am Post subject: |
Why wouldn't you use the factory lug nut torque number for your stock wheel/lug nuts? |
emu88 Samba Member
Posted: Mon Sep 22, 2014 1:49 pm Post subject: |
911pickup wrote: |
because they are Sprint stars? I read somewhere that every kind of rim and nut set vary and they should be to manufacturers spec. I can't find anything on how tight the lug nuts should be on ssp sprint stars _________________ 03/1971, 1302 Super Beetle 1600 dual port
Solex 34-pict 3
Long reach heads |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Mon Sep 22, 2014 3:14 pm Post subject: |
What 911pickup is getting at is they are steel wheels (like the factory wheels) and use factory style lug nuts, so tight like factory will do it. I ran 4 bolt Sprint Stars on my street car for 6? years and it worked. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
emu88 Samba Member
Posted: Tue Sep 23, 2014 5:27 am Post subject: |
ALB wrote: |
What 911pickup is getting at is they are steel wheels (like the factory wheels) and use factory style lug nuts, so tight like factory will do it. I ran 4 bolt Sprint Stars on my street car for 6? years and it worked. |
Oh right. The nuts that came with the wheels are longer than the stock ones though. _________________ 03/1971, 1302 Super Beetle 1600 dual port
Solex 34-pict 3
Long reach heads |
Posted: Tue Sep 23, 2014 9:50 am Post subject: |
Longer lug bolts/nuts don't make any difference in torque needed. _________________ https://imgur.com/user/FisherSquareback/posts
Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1192 Location: MI, MotorCity ManCave
Posted: Tue Sep 23, 2014 1:34 pm Post subject: |
EMPI Sprint Stars are Steel Wheels and use stock bolts and tighten to stock torque.
SSP Sprint Stars are the Aluminum Repop's and I contacted aircooled.net, who sells them and they recommend between 85lbs & 103lbs. Do not go higher or you will over tighten and stretch bolt or ruin taper. |
emu88 Samba Member
Posted: Wed Sep 24, 2014 1:03 am Post subject: |
Typ3nut wrote: |
Thanks! Hmm so aluminium... are they worse than steel? _________________ 03/1971, 1302 Super Beetle 1600 dual port
Solex 34-pict 3
Long reach heads |
