luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Mon Sep 29, 2014 5:52 pm Post subject: |
BavarianWrench wrote: |
Brian I'm looking forward to the updates. Your rig is sweet! I just bought a Reimo Syncro too. I'm curious about how you will convert to US spec, electrical (land connection) and propane are different. Is your propane stored in removable Euro spec tanks that mount in the back cabinet? Also any specs on that fridge? It too is cool like the rest of the rig. Props and Congratulations on a successful maiden voyage. |
Looking forward to info on your rig too - will be interesting to see if it has the same roof profile or not.
o For converting power, I haven't figure out how to access all the wiring yet, whether I need to replace the panel or not, or just the charger and 220V plug housing.
o My propane tank is stored under the sink, but there was no tank as shipped (can't go on the boat apparently), and the fitting doesn't work with any tanks I can find here - likely metric, and need to adapt to 9/16"? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1045 Location: Oceans Edge
Posted: Mon Sep 29, 2014 5:56 pm Post subject: |
Do a quick check of the Turbo. See if it is pushing oil? If it runs well, just burns oil, a seal in the Turbo could be your problem. That is a high rate of oil consumption, or loss? You will be able to see it. Does it Smoke?
Here is a photo of mine. Yours is a newer design? Mine is a 1987 model top is a bunk. A bit tight for me up there but manageable.
Mine didn't come with the propane bottle either. |
Posted: Mon Sep 29, 2014 6:09 pm Post subject: |
No smoking, except on one cold morning. I did see a good sized drip happening from left-hand side of engine somewhere (looking at back of van), after hard freeway miles. With the skid-plate, makes figuring out things tricky.
There is one hose that is unconnected which typically is a loop-back of some kind, and is just dripping to pavement. I have no idea what it comes off of, as I'm mechanically declined. Let me go take a picture.
Nice van! My top is all storage, no upper bunk, just the way I like it. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Mon Sep 29, 2014 7:12 pm Post subject: |
Okay, here are some engine bay pictures and dumb observations / questions:
Small labels in the image above are for:
1. This hose goes nowhere, and aligns nicely to where I saw large drip / small puddle forming after a highway stretch at 65mph. What the heck is this hose, and where is it supposed to go?
2. This is not connected. Is it a turbo-timer or some other pump that is supposed to run after the engine is shut-off?
3. The pressure cap has a hose that goes nowhere. You can see it terminate middle-left of the photo. Normally it tucks over a bit and just hangs down. Shouldn't there be an overflow tank somewhere, or did they not bother with it because the engine-bay is pretty full?
Additionally, this little guy isn't connected to anything (bottom middle of 1st pic, middle of 2nd pic). Where is it supposed to go, or just a test-lead?
And finally, this line seems to be a dead-end. I wonder if this is my fuel-feed for the diesel heater
srmpf Samba Member
Posted: Mon Sep 29, 2014 7:39 pm Post subject: |
# 1 is your return line from the crankcase breather. That should go either in a catch can or back in the block (here's an image of my IDI diesel before installing , you can see the hose going from the puck down into the block: https://www.flickr.com/photos/srmpf/9113575120/in/set-72157626192344066) EDIT: looking closer at your pictures it looks more like the other hose going from the puck to the intake.
#2 is a electric pump for the coolant system. some european vanagon diesels came with it. connect it to your alternator via a relay so that it runs when the engine is on.
#3 should go to an overflow tank. the idea is that the coolant flows in the overflow tank when hot (expand) and sucks back the coolant when it cools down so that you don't have any air in the system.
#4 if don't have any idea
#5 i would check where it starts - if it's really for your diesel heater you should double check if it doesn't squirt diesel when you want heat
srmpf Samba Member
Posted: Mon Sep 29, 2014 7:41 pm Post subject: |
oh and congratulations - that syncro looks awesome! |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4086 Location: East Kootenay, British Columbia
Posted: Tue Sep 30, 2014 11:54 am Post subject: |
#2 is an aux water pump that will run AFTER the engine is shut off to help cool things down. Only the turbo diesels came with these along with a fan and ducting to cool the turbo after the engine is shut down. There is a relay and wiring behind the drivers taillight.(and the fan) No idea if the conversion to TDi kept the relays that make this system work.
If the relays and fan have been stripped from the van you may want to eliminate the pump and excess hoses. _________________ Currently:
Posted: Tue Sep 30, 2014 12:27 pm Post subject: |
Another note - despite new harness+glowplugs, the glow-plug light is on dimly all the time. Ideas?
Any further thoughts on the hose routing / unconnects above? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
lloydy Samba Member
Joined: September 15, 2010 Posts: 715 Location: cheam surrey
Posted: Tue Sep 30, 2014 12:29 pm Post subject: |
number one is the breather and on a standard set up joins to the air intake to turbo (hard plastic pipe)
number two is the aux water pump, only comes on with ignition off and very high coolant temp
number three, pressure cap hose should run to a top up tank situated behind the numberplate flap (as per petrol engines)
loose wire, don't know
fuel hoses, i can't quite see where they all cross over. but the two spigots facing the back of van on the filter are the fuel flow and return to pump. It looks like you have something t'd into one of these with a little filter? if so, yes that could be the supply for a heater. _________________ 16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.” |
hans j Samba Member
Joined: May 06, 2006 Posts: 2714 Location: Salt Lake City UT
Posted: Tue Sep 30, 2014 12:39 pm Post subject: |
MsTaboo wrote: |
If the relays and fan have been stripped from the van you may want to eliminate the pump and excess hoses. |
Yup. If you have an extra coolant temp sensor hole in your system, you can use a Eurovan afterrun temp sensor to activate it when it's at temp and the car is off. It's a really nice feature on cars with coolant cooled turbos, but you might want to remove it since they are prone to leaking. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
?Waldo? Samba Member
Posted: Tue Sep 30, 2014 12:52 pm Post subject: |
#1 is the crank breather and the typical connection would be in the intake between the air filter and the turbo compressor inlet. Take great care with connecting it, though. If your engine has excessive oil in the crank case vent, it can cause a runaway situation where the engine runs on its own crankcase oil. When that occurs, the engine will run on its own at FULL POWER. The ignition key will not turn it off and if the clutch is depressed or the trans placed in neutral it will rev uncontrollably with internal damage very likely. In that situation, the thing to do is to keep it in gear and stomp on the brake to drop the rpms until it stops running away or stalls.
I had that occur on one engine of mine and despite keeping a clear head and reacting properly it was quite frightening to have the vehicle take off on its own at full power. I was jittery for the rest of the day. |
Posted: Tue Sep 30, 2014 1:39 pm Post subject: |
Andrew A. Libby wrote: |
Well, that scares the bejesus out of me, thanks
I'm pretty sure that hose is where some of the oil droppings are coming from, and if so that would likely cause "excessive oil in the crank case vent" as you mention above, thus leading to a scenario where my uncool head would result in catastrophe
I guess obvious follow-up questions would be "are these normally hooked up as stock?", and if so "why would mine be expelling too much oil, potentially leading to issues"? Is there something that should be fixed first, before even *contemplating* plumbing that line "properly"?
So much to learn... Thanks for the ongoing contributions Andrew! _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Tue Sep 30, 2014 1:42 pm Post subject: |
hans j wrote: |
MsTaboo wrote: |
Yup. If you have an extra coolant temp sensor hole in your system, you can use a Eurovan afterrun temp sensor to activate it when it's at temp and the car is off. It's a really nice feature on cars with coolant cooled turbos, but you might want to remove it since they are prone to leaking. |
Do I have a coolant cooled turbo? How can I tell? Also, I seem to have a second filler - is that for the turbo?
For diesel oil, what are people running in their TDIs? I'm on 5w-40 right now. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Zeitgeist 13 Samba Member
Posted: Tue Sep 30, 2014 2:34 pm Post subject: |
I don't quite understand why there's a pre-filter fitted to either the outflow or return side of the main filter, since it has fairly large mesh meant to nab large chunks of rust and algae being expelled directly from the tank. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
hans j Samba Member
Posted: Tue Sep 30, 2014 2:52 pm Post subject: |
luVWagn wrote: |
For diesel oil, what are people running in their TDIs? I'm on 5w-40 right now. |
I doubt it is a water cooled turbo but I haven't seen it. If it only has one line in and out, it is only oil cooled.
I run Shell Rotella T6 5-40 synthetic in my TDI. 3000 mile changes and tire rotations. Overkill based on reviews of that oil but it's simple and cheap preventative maintenance. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Tue Sep 30, 2014 7:14 pm Post subject: |
The crank vent will always blow some oil. The real question is how much is coming out of yours. You can run it into a catch can and place a crank vent filter from a V8 on the can so that you can see how much. The engine I had that ran away was running an absurd amount of oil through the crank vent. I'm not exactly sure how much as I didn't drive it much before it ran away and immediately took it out of service. It was definitely more than 1 qt in 500 miles. My concern in posting was the possibility that the engine ran started to run away on the previous owner and that they disconnected the crank vent in order to prevent the issue from recurring.
Can you get pics up of the turbo and oil return line? |
srmpf Samba Member
Posted: Tue Sep 30, 2014 7:56 pm Post subject: |
MsTaboo wrote: |
#2 is an aux water pump that will run AFTER the engine is shut off to help cool things down. |
ok dumb question of the day: if the engine is shut down, why would i continue moving the coolant around? better for the block if it cools down quickly? |
lloydy Samba Member
Posted: Wed Oct 01, 2014 1:39 am Post subject: |
the block will cool down quicker with the pump running as it circulates the water(removing heat). The water is likely to boil if just left sitting in a very hot block _________________ 16" syncro multivan pop top AHU TDI
Posted: Mon Nov 03, 2014 7:57 am Post subject: |
Hello Brian
How is the rig? Do you have any updates? I got mine and got busy doing other stuff. I did use it a few times but have not built it out much. I am a bit bummed with the cabinets. The middle cabinet requires the seat to be in the bed position to access its' contents. Other then bedding in there is a pain. How are you liking yours? |
Posted: Mon Nov 03, 2014 8:05 am Post subject: |
Hello Brian
Not yet registered in WA, due to various notarized translations being required. Should be done this week! However, after sitting for a month, the TDI is extremely smokey, and low on power - as I found out when moving it around the block. A cop even popped by and told me it was an environmental hazard _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
