912 engine swap
Gordon Lewis
Gordon Lewis is offline
PostPosted: Tue Sep 23, 2014 8:05 pm    Post subject: 912 engine swap Reply with quote
I'm thinking about restoring a 1965 to 69 912 on a budget. There are a few cars for sale minus the motor. If I rebuilt the body and installed a vw motor initially to reduce costs, would the type 4 or beetle motor be compatible ?
Thanks for any advice
jt912
jt912 is offline
PostPosted: Tue Sep 23, 2014 9:57 pm    Post subject: Reply with quote
In the grand scheme of things, the difference in price from using a used, good running 912 engine and using a VW engine + the needed mods to make it work will only be a small portion of your project. What are you figuring for your budget?
Danwvw
Danwvw is offline
PostPosted: Tue Sep 23, 2014 10:21 pm    Post subject: Reply with quote
If you go with the VW engine which will bolt in ok but the clutch and flywheel may be different, then consider a 74mm stroke VW engine which is what the 912 was. With dual carbs and a similar cam it would make similar power around 90 hp! My VW bus engine is like that!
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Danwvw
Danwvw is offline
PostPosted: Wed Sep 24, 2014 11:45 am    Post subject: Reply with quote
Found this link for you! http://www.aircooledtechnology.com/cooling/fit/912.shtml The Type 4 Engine was apparently used in the 912E Cars.
914werke
914werke is offline
PostPosted: Thu Jan 22, 2015 11:08 pm    Post subject: Reply with quote
The challenge is finding the 912e specific bits to perform the swap!
As only 2000 or so were available stateside you can imagine how many are still around nearly 30 yrs later.
Cool
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Fri Jan 23, 2015 9:10 am    Post subject: Reply with quote
Either will work. Out of the box the T4 (1.7L, 1.8L and 2.0L) have near double HP of a stock T1 engine. They are more costly to modify and rebuild. You'll have to make or adapt engine compartment cooling tin. Not sure what you consider a budget rebuild as Porsche parts (even used) are not cheap.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
