MickeW Samba Member
Posted: Wed Sep 24, 2014 7:54 am Post subject: Found an engine |
I bought this bus engine that seems to be a mix of parts. Seamed fanshroud together with later generator and worst of all, on one side there is a 36hp head. I am taking it apart this weekend so what happend will be revealed. Anyway, it seems to be from august -53.
A few questions:
Is the faint square under the number some kind of "Austausch" symbol?
Is it possible to mount a 36hp head on 25hp cylinders?
MickeW Samba Member
Posted: Mon Sep 29, 2014 9:43 am Post subject: |
Yes, it is possible to mount a 36hp head on 25hp cylinders if you "modify" the cover. Luckily I have some spare 25hp heads,studs and tins. The pistons looked quite nice also. A little cleaning up now and store it for the future.
First I just need to find out if the carb and distributor are correct for a aug/-53 BD engine. The generator, I have learnt is more or less same for all 25hp engines.
kalymnos Samba Member
Joined: January 22, 2010 Posts: 112 Location: Hamburg/Germany
Posted: Tue Sep 30, 2014 12:09 am Post subject: |
Nice engine you found.
Yes, it means "AUSTAUSCH".
The crank case (half) was built August, 11th, 1953
The distributor seems to be correct and should read VE 4 BRS 383
The generator has a date code: 1953 would be "J" |
MickeW Samba Member
Posted: Tue Sep 30, 2014 10:30 am Post subject: |
Thanks kalymnos, what I suspected regarding the Austauch. The carburator also looks correct. I understand that it is no vacuum casting for late 52, Blind casting for 53 and plugged vacuum for 54-55.
Today I made an inventory of my 25hp parts. I guess these would also be correct for my aug/53 engine.
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
MickeW Samba Member
Posted: Tue Oct 07, 2014 10:52 am Post subject: |
So the base of the pump is later?
Here are the fuel pumps I have. The lower left one is for the older 8mm. I guess that base would be correct for this pump.
Clara Samba Member
Posted: Sun Oct 12, 2014 7:45 am Post subject: Re: Found an engine |
MickeW wrote: |
I've seen 25hp heads bored out for 36hp. Could have had one of those on one side and a 36hp head on the other, leave the 25hp tin on & trim holes for the 36hp nuts. Run 36hp ps and cs, for the big bore power? |
