AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Wed Sep 24, 2014 9:42 pm Post subject: My 1623cc. 36hp challenge engine. Bonneville type 2 |
3 years in the making. It,s done and runs. 83 by 75. Chev h beam con rods 5.4 inch with small bolts narrowed to fit the porsche crank. Porsche 1960 era crank taken to chev 2in journals and found an extra mm in stroke.A new 36 cam reground to porsche specs.
The case is an 1958 date alighn bored by JR Herity in Edmonton. I used an 365 lightened flywheel (aa) ,Power pulley,1700lb kenedy clutch with a unsprung 200 mm F&s disc, Piston and cyls are 83mm dome top of a 63 type 3(S) I used a WW dual port kit, ported by myself,And used dual valve springs from a jaguar 1956-1985 .Compression is 9-1 plus whatever is in the dome tops.
The stock pushrods were removed and with work a set of 3/8 chromemoly empi pushrods were install to set up the geometry on the 1.25 speedwell rockers. Stock valve covers were modified to clear the rockers (yes we welded spoons in ) I,m presently running the 28mm WW carbs and a 1&3/8 header with stinger.
I never got to use this engine at Bonneville this year due to an oil leak from a gallery plug.(my f-up) But weather permmiting on Sunday I,m taking it to the last street legal race of the year to get a 1/4 mile time. The time to beat on the drag race sticky is 15.8.I,m going to give it a wirl.
It,s going to be a long winter without something to talk about. Brad has photo,s of the engine assbly that I will be posting so I can explain our reasons for doing what we did.I,m wide open to tell any speed secrets I have.
Wish me luck on Sunday. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Sep 25, 2014 5:30 am Post subject: |
Good luck on Sunday
Should have looked a little closer at stuff out on the salt EH?
Just wasn't a real good year at the salt for some this year. The expanded World Finals/ Speed Week was rained out also. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
tobiasax Samba Member
Posted: Thu Sep 25, 2014 11:30 am Post subject: Re: My 1623cc. 36hp challenge engine. Bonneville type 2 |
AirCooledClassics wrote: |
Wish me luck on Sunday. |
Wow! Great engine. I wish you good luck! _________________ __________________________________________ |
Posted: Sun Sep 28, 2014 8:24 pm Post subject: |
Today's 1/4 mile results 17.03 at 75.93 mph. The carbs and okrasa linkage must be improved upon .The engine ran well but I felt like I was sipping thru a straw. It"s short of what I wanted but I plan on developing a pair of holley bug sprays for the engine. I will try to start posting pics and build story tommorow night. _________________ 2010 Bonneville record holder Type 2, 36hp
My You-tube video
bruce cook Samba Member
Posted: Mon Sep 29, 2014 4:43 am Post subject: |
Sounds like a great engine, we found problems with the ww carbs and linkage on our 1493cc 36 we ran in Ohio on Sat. _________________ land speed nut |
Posted: Tue Sep 30, 2014 11:24 am Post subject: Did we just set a 1/8th mile record? |
I just noticed Our time slips give the 1/8th results. 10.60 at 61.76. Is this a new record? the engine is ww challenge legal. Does anyone know if drag racing records are recognized in the ww challenge. Now we are happy! _________________ 2010 Bonneville record holder Type 2, 36hp
My You-tube video
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Thu Oct 02, 2014 3:18 am Post subject: |
so you ran okrasa heads and 28mm carbs? why not the 32pcib's? _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
Posted: Thu Oct 02, 2014 7:10 am Post subject: |
This was the last afternoon at the track as the onset of winter is near. I.m sorry I never had the chanche to flip on the 34's. HAVE YOU EVER RUN A SET OF THESE. I just ran out of time.What do you think of the dual holley idea,It's real simple to make manifolds and they are a 36mm throtle plate. _________________ 2010 Bonneville record holder Type 2, 36hp
My You-tube video
grueni Samba Member
Posted: Thu Oct 02, 2014 12:55 pm Post subject: |
okrasa used 32pcib's. i like the 34 pci more at all.
with your engine 28 pci will limit you specially when it comes on rpm.
how big are your valves if stock okrasa valves your engine is limited in rpm at all. you have alot displacement. that needs more cam and more carb to breath. its' powerful but your rpm range is not that big to go fast but nicely go strong!
nice build btw!
congrats
the last build i did is an original okrasa tsv 1300
with a little love on the heads. i build dome pistons and rised the compression ratio to 10.4:1, stage 2 cam with 1.25:1 rockers from speedwell.
ratio rockers and more cam and bigger carbs will make your engine run. _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
