vwrock Samba Member
Joined: September 25, 2014 Posts: 2 Location: graham, wa
Posted: Thu Sep 25, 2014 9:10 am Post subject: new to 67 squareback/aircooled. |
Hello everyone. I bought a 67 squareback 2 weeks ago and I have a couple questions. I need to check/adjust my fuel pressure. How do I remove and change the gaskets on the manual fuel pump on top of the engine? Also I have been reading up on ignition timing procedure. It talks about disconnecting vacuum lines. Since I have electronic ignition do I need to worry about this? I dont see any vacuum lines on my engine. Not to say they shouldnt be there. But I am trying to correct previous owners mistakes. Also do I time it when it is at idle or at 3400 rpms or both. Thank you |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Thu Sep 25, 2014 9:48 am Post subject: |
Welcome!
Take some pics and pull part numbers off your carbs and distributor.
Answers vary depending on that you have, especially since it is no longer stock. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Thu Sep 25, 2014 9:52 am Post subject: |
Quote: |
How do I remove and change the gaskets on the manual fuel pump on top of the engine? |
the gaskets are under the pump itself, you can add or subtract gaskets to get the pressure you need. You can use a cereal box for cutting gaskets a little thicker. I have had to use 2 or 3 thick gaskets to get down to the 2.5-3psi range with some pumps.
sounds like you have a mechanical advance distributor, so you will just need to set the max advance at 3400rpm to 28-30 degrees and let the idle fall where it will. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
vwrock Samba Member
Posted: Thu Sep 25, 2014 10:26 am Post subject: |
009 bosch distributor and empi epc34. Dual ports |
vwfye Samba Member
Posted: Thu Sep 25, 2014 11:33 am Post subject: |
2.5-3.0 lbs of pressure is plenty for that set up. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
