laloalien Samba Member
Joined: November 06, 2010 Posts: 8 Location: Apodaca, N.L.
Posted: Thu Sep 25, 2014 7:43 pm Post subject: VW Bike... my own version |
For a long time had been around in my head the idea of making my dream bike, well this is my progress to this day remains a long way to go but I think it was a great start
https://www.youtube.com/watch?v=wqJzKDdc-no[/youtube][/b] |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Thu Sep 25, 2014 8:23 pm Post subject: |
I absolutly love that leading link front suspension, yea, springs would help.
So you just weld the differentual solid and hook up a chain from the backwards spinning axle shaft to the back wheel? Are you going to spin the engine backwards, doing something funky with the oil pump, or are you going to change directions between the transmission and the back wheel? Your clutch arm must be huge. |
Posted: Thu Sep 25, 2014 8:44 pm Post subject: |
Hi [email protected]
it will be a leafer front suspension but not finished yet and itīs correct, i going to weld the spiders gears fron the differential and use a chain to the rear wheel, as well i will change the position of the diferential to make spin in reverse the final gear to the wheel, maybe i use a hydraulic clutch, but not sure yet. |
Posted: Thu Sep 25, 2014 8:54 pm Post subject: |
laloalien wrote: |
i will change the position of the diferential to make spin in reverse the final gear to the wheel |
Brilliant! |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Thu Sep 25, 2014 10:43 pm Post subject: |
[email protected] wrote: |
laloalien wrote: |
Brilliant! |
That's what VW did on split window bus transaxles. The axle reduction gearboxes reversed the direction of the rear wheels so they all had their differential ring gears flipped to the opposite side from the sedan.
I looks like the rear stub axle is mounted backwards? Why didn't you mount it normally and attach the rear sprocket where the CV joint mounts?
Did you use one of these rear bearing housings?
http://www.appletreeauto.com/AXLE-BEARING-HOUSING-17-2707-0/ |
Posted: Fri Sep 26, 2014 4:32 am Post subject: |
I use the same of the car, just cut and weld together
This is my first diagram:
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Fri Sep 26, 2014 7:58 am Post subject: |
Subscribed ! Looks like an offset rear wheel is out of the question? Stock rear wheel offset? This is a very good looking bike. Sits perfect, laid out perfect. Cant wait for this one. |
Bakerby Samba Member
Posted: Fri Sep 26, 2014 10:42 am Post subject: Bike |
Very cool will be following this one |
Posted: Fri Sep 26, 2014 5:02 pm Post subject: |
That's right, the rear wheel and tire (and brake) are from the stock car
Posted: Fri Sep 26, 2014 8:26 pm Post subject: |
laloalien, I really like it! I have a few old Indians, your leaf spring front end will look great. It looks like you might have enough room for some skirted fenders.
It reminds me of this V-8 Indian.
Posted: Fri Sep 26, 2014 8:34 pm Post subject: |
Wow!!!! that Indian looks powerful and heavy!!!! |
Posted: Sat Sep 27, 2014 5:25 pm Post subject: |
It weighed 965 pounds but only had 60 hp.
Dave Edwards and John Bivens have restored it and I'm sure its closer to 100hp now.
WD-40 Samba Member
Posted: Sat Sep 27, 2014 5:49 pm Post subject: |
laloalien wrote: |
Please tell me you're going to run a stock hubcap?
Also, get the poor kid a seat! _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Sep 27, 2014 7:15 pm Post subject: |
For a minute there I saw twin drive chains in your future.
This will be a great looking bike hope to see it at the shows one day. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Sun Sep 28, 2014 2:17 pm Post subject: |
Oh yeah!! of course i will use the stock hubcap
I'm trying to put all the useful parts of the donor car
The rear wheel I'm doing a single side that is easier to replace or repair
I still have not decided if it will be a bagger bike or not |
Posted: Mon Sep 29, 2014 4:20 am Post subject: |
I'll leave that to the end but if necessary i will put electric cooling fans making parts of fiberglass adapting them to the size and shape of the space i have |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1423 Location: Toronto, Ontario. Canada
Posted: Mon Sep 29, 2014 5:01 am Post subject: |
Very cool build, definitely following this. I have a thought for your cooling issue. The Porsche guys use a fan/ gen that mounts reverse to the bug. I have seen a used kit on here in the parts section. The shroud is made of fibreglass & it should be easy to adjust around the down tube. You could also do like the BMW crowd & not worry about shrouding. Keep us posted. _________________ I think he meant "rare", as in "not well-done" |
eyetzr Samba Member
Posted: Mon Sep 29, 2014 7:47 am Post subject: |
XAVW Von Dutch 2013 Volksworld magazine. Notice no cooling tins. Lots of other details. _________________ I think he meant "rare", as in "not well-done" |
