pickledBus Samba Member
Joined: October 05, 2012 Posts: 79 Location: portland, or
Posted: Fri Sep 26, 2014 10:56 am Post subject: Ghia purchase advise |
Hi,
I have a 1977 bus so I comfortable with mechanical/interior work but not very experienced on the body side. I am now looking to get a Ghia, I have read all the purchasing/inspection guides I could find here but I wanted some specific advise on a potential purchase. Pictures and craigslist description are below. Thanks in advance!
Craigslist description, he is asking $2100:
Quote: |
1969 Karmann Ghia
Engine starts every time, idles and runs great. One of the better ones out there. I bought it as a Subaru swap project but have no time to get to it. It has some rust issues mostly located on the drivers front fender area. This is probably from the front left air intake. The brakes start to swell up when the car is driven. I will be attempting to loosen up the brakes as I can get to it. Clean title. |
The brake swelling I think is just old rubber lines so I am not too worried about that.
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 371 Location: Calgary, Alberta
Posted: Fri Sep 26, 2014 11:35 am Post subject: |
The lack of side trim is always a red flag to me. Usually means someone has filled in the holes with bondo. If they have done this, they very well may have covered rust in the usual areas (rocker panels, etc). best bet is to get a magnet on it to see what might be lurking.
I can almost guarantee you will have to replace the lower quarter panels, rockers and quite possibly heater channels given where this car is from. _________________ 68 Ghia Regatta Blue Convertible
69 Ghia Toga White Coupe
74 Westfalia |
mfitzsimor Samba Member
Joined: May 09, 2004 Posts: 171 Location: Portland, OR
Posted: Fri Sep 26, 2014 12:01 pm Post subject: |
Pickled,
Let me know if you'd like a walk-through of my 69 coupe. I can show what to look for on a car that's relatively rust-free. I'm in Milwaukie.
Mark _________________ portland, or
69 cypress green ghia coupe
82 vanagon TD
86 quantum syncro |
c21darrel Samba Member
Posted: Fri Sep 26, 2014 12:06 pm Post subject: |
^^concur about the side trim.
Front looks like generous bondo on previous repairs. She may have been an 80's/90's cal looker...cal look window rubber, side mirrors, sans side trim and bumpers plus alum sheet on the rear firewall.
Rust that is showing thru will be much worse on the underside. Hows the interior? Always better to find something thats mostly complete so you dont get nickel and dimed finding parts (like bumpers).
What are your plans? Driver, restore, original, custom??? How much work can you do yourself? Paying someone to do anything more than moderate rust repair and you can get underwater quickly. Buy the best candidate you can to start with and you will be ahead in time and $$. _________________ GhiaBuild
1967 DC build
Posted: Fri Sep 26, 2014 12:11 pm Post subject: |
Yeah I am worried about the lack of trim but I haven't seen a ghia under 8k around here that has the trim without having much larger problems.
When I talked to the seller on the phone he said he thought there was a lot of bondo on the front left side around the fender and headlight bucket. I was planning on looking at the underside through the trunk with a flashlight and bringing magnets. He also said that there was rust near the left front drivers foot by the heater channel. Is that an automatic run away?
I can do any mechanical and interior wiring/clean/install things. I have done some rust repair but only on superficial rust and simple painting. My goal is to clean it up enough to be a decent daily driver without going full restoration on it. Also as a project to learn welding |
retrowagen Samba Member
Posted: Fri Sep 26, 2014 12:13 pm Post subject: |
Lots of potential for disaster there.
Do be careful. Inspect with a magnet; a flashlight, and a very critical look all over the vehicle. _________________ David Ruby
President, Karmann-Ghia World Club |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Fri Sep 26, 2014 12:56 pm Post subject: |
If he'll let you, take off the chrome headlight ring and look at the headlight buckets, pretty hard to make those look new once they're all smashed up. You can also feel along the edge of the wheel well, is should feel smooth and not ripple-y at all. Might also feel around behind the rear side panels for rust, corrosion down where the heater channels are.
And if you're in Milwaukie examining mfitzsimore's ghia, you can swing by after and look at my 67 (also in milwaukie) that has all those sneaky rust repairs 1/2 way uncovered, easily showing just how good those bondo guys were at covering things up back in the 80's! |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Fri Sep 26, 2014 2:11 pm Post subject: |
The passenger side rocker looks like it has issues. _________________ Ghia Owner Emeritus |
Karly Samba Member
Joined: August 01, 2002 Posts: 641 Location: Australia
Posted: Fri Sep 26, 2014 8:48 pm Post subject: |
pickledBus wrote: |
Yeah I am worried about the lack of trim but I haven't seen a ghia under 8k around here that has the trim without having much larger problems. |
The problem is at least those cars you can SEE what you are getting into.. this ghia is most likely the same its just hiding it's rust under a coat of bondo and fresh paint.
I went at looked at a older resto (7 years old) the poor guy who bought it thought he was getting an awesome ghia... down the track the bondo had all cracked plus plenty of rust bubbles all over the bottom half of the car, still shiny paint all over it though!
I guess as others said.. if you don't mind the work and plan on doing it yourself it'll be fine, but costing out repair panels/welding etc the cheap ghia often isn't so cheap. It is definitely hard to judge them from photos though so good to have a look with a flashlight and magnet and start learning all the problem areas. _________________ 1960 Beetle ''Heidi" daily driver
1964 Karmann Ghia project |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
O2COOLED Samba Member
Posted: Sat Sep 27, 2014 3:38 am Post subject: |
I just saw this in CL:
http://seattle.craigslist.org/see/cto/4687646119.html
You may want to check it out before making a decision. Has a 1641, dropped etc _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
"At my age time is too short to respond to people with short minds"
Current: '69 Ghia Coupe
VW History:'63 Bug;'70 Bug;'73 412;'83 Rabbit;'86 Golf;'76 Fat Chick; 67 Ghia Coupe; '70 Bug |
NWGhiaGuy Samba Member
Joined: March 16, 2005 Posts: 700 Location: Bellingham, WA
Posted: Sat Sep 27, 2014 2:14 pm Post subject: |
Yeah, I was thinking this '63 looked like a better deal too. |
kingkarmann Samba Member
Posted: Sat Sep 27, 2014 2:53 pm Post subject: Re: Ghia purchase advise |
pickledBus wrote: |
Hi,
I have a 1977 bus so I comfortable with mechanical/interior work but not very experienced on the body side. |
You will be if you buy that Ghia !! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Sun Sep 28, 2014 10:53 am Post subject: |
I went to look at it and decided not to buy it. The highlights are a 1/4 thick layer of bondo over the front left quarter. The heater channel by the drivers left foot completely rotted away. At least one square foot section of pan was going/gone from under than drivers seat. Rust bubbles/rust along the drivers side rocker. I didn't even get to the passenger side inspection before deciding I didn't want it.
Here is the craiglist post if anyone is still interested: http://portland.craigslist.org/wsc/cto/4684520948.html |
Posted: Mon Sep 29, 2014 8:23 am Post subject: |
pickledBus wrote: |
So much for "One of the better ones out there" and "...some rust issues.." _________________ Ghia Owner Emeritus |
DorianL Samba Member
Posted: Wed Oct 01, 2014 1:03 am Post subject: |
Take a few magnets with you of varying strength.
The thicker the bondo, the less the magnets will cling to the panel eaxmined. |
