How do you repair this fiberglass
0BudgetProductions
0BudgetProductions is offline
PostPosted: Sat Sep 27, 2014 11:40 pm    Post subject: How do you repair this fiberglass Reply with quote
A question for all the fiberglass fraternity....
How do you repair this kind of damage to fiberglass?
Dale M.
Dale M. is offline
PostPosted: Sun Sep 28, 2014 8:18 am    Post subject: Reply with quote
Sand/grind it down to fresh material, lay a layer (or 2) of resin/glass as filler and sand it out.... What ever you do you need to expose fresh base materiel for repair to stick....
As for hole, feather edge out hole, use masking tape to create platform to hold new materials and lay on a patch of resin/mat till you have create a new build of material equal to or thicker than surrounding material and grind/sand smooth....
Its not a hard repair, just messy to do...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
0BudgetProductions
PostPosted: Sun Sep 28, 2014 11:16 am    Post subject: Reply with quote
Any particular brands that you can recommend for the filler??
Dale M.
Dale M. is offline
PostPosted: Sun Sep 28, 2014 1:17 pm    Post subject: Reply with quote
I do not recommend "filler" (filler to me is body putty) ... I am strictly a glass and resin build up person... That would be polyester resin and mat...
Brand names are TAP or Evercoat or Bondo (a 3M product) several others......
If you are not familiar with process, suggest a lot of reading on "fiberglass body repair"...
Dale
0BudgetProductions
PostPosted: Thu Nov 20, 2014 2:31 pm    Post subject: Reply with quote
Dale...that hole is filled...but now I'm wondering how to tackle the "pitting" thats in the body next to it. What would you do?
Dale M.
Dale M. is offline
PostPosted: Thu Nov 20, 2014 2:47 pm    Post subject: Reply with quote
Grind it down to fresh material and lay a layer or two if cloth/mat and then shape it out.... Almost all repairs are generally same procedure, all start with getting down to good base....
Dale
vwracerdave
vwracerdave is offline
PostPosted: Thu Nov 20, 2014 2:50 pm    Post subject: Reply with quote
Just to help, The Samba has a dedicated forum "Body/Paint" You need to spend some time reading and learning about basic body work.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
monomanx
monomanx is offline
PostPosted: Fri Nov 21, 2014 9:33 am    Post subject: Reply with quote
Ultimately it depends on what you want to do with the car and how much work you are willing to do.
For pits, I would actually recommend Slick Sand or other Polyester primer. To prep, I would sand it down with 150-220, VACUUM it off...do not blow it off as most compressors will blow oil or condensed water (or both) if there is no drier or water trap. At that point, spray the polyester primer and start sanding.
For more damage, (broken glass, spider web cracks etc), you need to grind and get down to good glass as Brian mentioned.
0BudgetProductions
PostPosted: Fri Nov 21, 2014 7:00 pm    Post subject: Reply with quote
Thanks Monomax...
the old chestnut of "grind it down and fiberglass it" only goes so far with me... Cos That's what I've been doing. The "Pitting" is in areas (edges etc) that would require a lot of "sculpting" and quite honestly I am looking for alternative solutions.
I posted another photo of "chunks" of fiberglass that have fallen off the edge of a headlight well...and have left holes that would require a lot of sanding and fiberglassing....all of which I can do...but that would require alot of sculpting of the edges...and that I would need more advise on!
joescoolcustoms
joescoolcustoms is offline
PostPosted: Fri Nov 21, 2014 7:22 pm    Post subject: Reply with quote
Sorry to say, but, advice can only go so far on those type of repairs. That type of repair comes down to experience, which can only be gotten by grinding it out, filling with resin/glass and sanding. Sucks, but for that area and type of repair, there does not exist a short cut, (other than paying some one else to do it for you).
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
monomanx
monomanx is offline
PostPosted: Fri Nov 21, 2014 7:27 pm    Post subject: Reply with quote
SInce you have started two threads for this, my response was aimed at the pitted/UV riddled body post.
You COULD get away with slick sanding these areas although it will take a few coats.
Regarding the big cracks and chunked out areas, those must be repaired with glass and resin. You cannot primer out huge voids and damage like that.
in viewing the image again of the pits, I actually change my position and would recommend using a mixture of resin and cabosil or microballoons mixed into a paste. YOu can then scree that miture onto the pitted areas with a squeegee. The challenge will be as you scree that in place, the little pits will trap air in them and as you scree the resin/filler mix over the holes, the stuff will kind of pop back out. To avoid this, I take raw resin, and lightly brush/stipple the resin it over the area being repaired. I then take the resin/cabosil mix and scree it on.
Once this is dry, you wll need to sand it.
This is of course my opinion and what I have done. you will likely get as many opinions as there are viewers of this post.
Best of luck.
joescoolcustoms
PostPosted: Fri Nov 21, 2014 7:31 pm    Post subject: Reply with quote
Thanks Chris!!! That just taught me a new trick to keep in my tool bag.
0BudgetProductions
PostPosted: Fri Nov 21, 2014 8:04 pm    Post subject: Reply with quote
Thanks Monomax....thats the kind of info that I was looking...priceless! I will try it...Cheers!
Dale M.
Dale M. is offline
PostPosted: Fri Nov 21, 2014 8:17 pm    Post subject: Reply with quote
Many years ago professional fiberglass man told me about "fumed silica" as a "filler"........ And wouldn't you know I promptly forget what it was.... Been about 8 years and this thread finally kicked brain in gear and now I have the words (product) again...
http://en.wikipedia.org/wiki/Fumed_silica
Also I believe Cabosil is a "brand name" not a product...
Dale
monomanx
monomanx is offline
PostPosted: Fri Nov 21, 2014 8:40 pm    Post subject: Reply with quote
Dale,
you are correct...Cabosil is a brand name. I have used other materials as well (Urefil and micro balloons).
One thing to keep in mind..as you mix the fumed silica/cabosil/urefil/micro balloons... really any of the ultra fine powdered filler materials, it wbecomes airborne quickly and is not so nice to your health. Mix slowly and evenly to keep dust down.
joescoolcustoms
PostPosted: Fri Nov 21, 2014 9:48 pm    Post subject: Reply with quote
One of my former customers is a explosive manufacture and they used the micro balloons by the cubic yard, and box trailer full at a time. (a micro balloon is just that, a tiny glass air bubble and when mixed in with a explosive, gives oxygen in the initial reaction helping it happen quicker).
I went to see them about recycling all the used cardboard Gaylord Boxes that formerly contained the micro balloons, (one cubic yard thick cardboard box). We were standing about halfway inside a box trailer full of these empty Gaylord boxes talking and another salesman that was with me dropped one of the folded up boxes. When it slapped the floor, all the spilled micro balloons went airborn all around us.
I ended up in the Hospital for a week with a severe respiratory infection.
The fumed silica works great for what we use it for. But, like Chris states, it can cause physical harm. So, use the same personal protection when mixing the material as when you would be grinding and sanding the fiberglass and filler(s).
Dale M.
Dale M. is offline
PostPosted: Sat Nov 22, 2014 8:32 am    Post subject: Reply with quote
monomanx wrote:
Dale,
Respirator or dust mask!
Dale
monomanx
monomanx is offline
PostPosted: Sat Nov 22, 2014 8:19 pm    Post subject: Reply with quote
One more suggestion re making a putty type material out of the materials and resin...
Mix the resin and coice of filler material in an airtight or sealable container. Let it sit at least overnight once mixed.
You can then pour out or scoop out the amount you will use and mix your hardener in.
This way you can be prepared ahead of time and not be caught with not enough material.
