ehale3 Samba Member
Joined: February 23, 2011 Posts: 40 Location: McCalla Alabama
Posted: Sun Sep 28, 2014 11:48 am Post subject: buggy build |
I have started a buggy project about 2 months ago,(not sure of buggy type) I am to the point of fitting the body to the pan and hood to the body.
When I get the hood in place there is a good 3/8" gap on both sides of the hood where it should meet the fender. Has anyone experienced this and how do I fix it? This is the best picture I have right now.
jsturtlebuggy Samba Member
Posted: Sun Sep 28, 2014 12:16 pm Post subject: |
Welcome to the Samba.
You may be able to pull the edges of the hood out to fill gap.
If you want to fill the gap with something, go to a upholstery shop and have them make a piping (like what is around the edge of a seat) only larger.
Depending where you are, Tom Thompson "Tijuana Customs" in Long Island, New York can make something for you. He knows buggies.
If gap was less I would use the fender beading for a VW Bug. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
bim55 Samba Member
Joined: February 11, 2005 Posts: 438 Location: Dennis Port, MA
Posted: Sun Sep 28, 2014 4:10 pm Post subject: |
I have to agree that it might actually pull together when bolted up, check this in mock-up before final assembly. Pull it together slowly and evenly, use washers and do it in the sunshine for warmth if thats possible?
Severe cases of shrinkage will require some build-up of your choice of glass, cloth, resins and fillers.
And there's no reason to go find someone to make up custom "piping", normal VW fender welting is all that is supposed to go there. _________________ Boston Bob E.
www.bimelliott.com www.deserterownersgroup.org |
jspbtown Samba Member
Posted: Sun Sep 28, 2014 5:53 pm Post subject: |
Have you tried the body on the pan with those seats?
I think your head might be well above the windshield. Maybe not...just asking.
And to answer your question....you should easily be able to snug up 3/8" of space. |
ehale3 Samba Member
Posted: Mon Sep 29, 2014 4:49 am Post subject: |
Here is a better pic of the gap
ehale3 Samba Member
Posted: Mon Sep 29, 2014 5:12 am Post subject: |
[quote="jspbtown"]Have you tried the body on the pan with those seats?
After I read this I put the seat in and tried it out and looking straight ahead I'm looking thru the middle of the windshield. Ive never been in another buggy so I don't know what is the correct height but it seems fine to me. |
Posted: Mon Sep 29, 2014 6:16 am Post subject: |
Wow..thats great. My seats are usually about 1" or so off the floor and I am looking out the top third of the windshield. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1423 Location: Toronto, Ontario. Canada
Posted: Mon Sep 29, 2014 1:19 pm Post subject: |
try to assemble the car completely. The gap will change over age. The 'hood ' has been separated from the body & the fenders are pulling apart. Piping or fender welting will fill the gap. Almost any upholstery shop could do this for you. If it bothers you still, masking tape the hood & apply filler to the body. As it starts to set, lift off the hood & sand the filler until you are happy with the gap. _________________ I think he meant "rare", as in "not well-done" |
ehale3 Samba Member
Posted: Mon Sep 29, 2014 2:58 pm Post subject: |
Thanks for all the replies, i ordered some rubber bubble seal I hope that works for me. |
ehale3 Samba Member
Posted: Tue Sep 30, 2014 7:49 pm Post subject: |
Per request here are pics of how my seats are mounted and the seats came out of a 90's mitsubishi
ehale3 Samba Member
Posted: Tue Sep 30, 2014 7:50 pm Post subject: |
ehale3 Samba Member
Posted: Tue Sep 30, 2014 7:52 pm Post subject: |
ehale3 Samba Member
Posted: Tue Sep 30, 2014 7:55 pm Post subject: |
tgodber Samba Member
Joined: May 02, 2004 Posts: 410 Location: Okanagan Falls B.C. Canada
Posted: Tue Sep 30, 2014 9:11 pm Post subject: |
Good job on the seats. I think you will be happy with them. My butt like some additional padding. Both my buggies have seats like those. I think that the gap will close up nicely with some bolts and fender washers. _________________ My wife said I never listen to her.
Or something like that! |
ehale3 Samba Member
Posted: Wed Oct 01, 2014 5:26 am Post subject: build pictures |
I thought I might as well post some build pictures
Old pans gone
All cleaned up
Fixed emergency brake
Rebuilt front beam
New pans
Disk brakes all around
Battery box
Posted: Wed Oct 01, 2014 6:34 am Post subject: |
Wow...you are so lucky that you fit in that seat set up. If it was me I would be catching bugs in my teeth on every drive.
You can see how much lower the seats were on my Deserter and I was still looking out the top of the windshield:
And on my manx I was at the top third of the windshield even with them this low:
ehale3 Samba Member
Posted: Wed Oct 01, 2014 6:41 am Post subject: |
I thought it worked out good
ehale3 Samba Member
Posted: Tue Oct 28, 2014 6:32 am Post subject: |
I haven't had time to do much lately but I did find me a good set of used
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Tue Oct 28, 2014 8:27 pm Post subject: |
Nice wheels!!!!
What is the width on the front ones??
I have a set of 8 inch Welds in the back and want to switch my fronts to chev lug pattern and Weld Wheels.
I have some 185/60-15's on my 3 1/2 inch wide Centerlines but I really need some 5 inch wide wheels for them. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
ehale3 Samba Member
Posted: Fri Oct 31, 2014 5:07 pm Post subject: |
I think there 5" wide |
